Thread: Check engine Light flickering - HELP!
Results 1 to 7 of 7
    "gadget" lowdown's Avatar
    Mar 2003
    Boise, ID
    Yesterday When I started my truck the check engine light was flashing fast (sort of flickering). I plugged in my diagnostic tester and the computer has no codes stored.
    The engine is idling fast (about 1500 RPM) and doesn't slow down when warmed up. It seems to run fine but there is obviously something wrong.
    I checked under the hood for loose wires or vacuum leaks and found nothing.
    Any ideas?
    Thanks in advance,
    lowdown
    1988 Chevy Silverado Stepside - 4/6 drop, Katzkin Leather
    Click on signature for truck pics and specs.
    http://www.cartoons.kooldezine.com
    Aug 2001
    New Jersey
    Re: Check engine Light flickering - HELP!
    IAC or TPS sensor?
    Mar 2006
    StL, MO
    If the SES light is flashing fast and dim, that signals a failure of the PROM chip in the ECM or the ECM itself. Check connections at the ECM and make sure the PROM chip is firmly seated, if equipped.
    1991 K1500 - 'Red'
    350 Roller Cam TBI, 5-speed manual
    1995 Chevrolet Caprice 9C1 LT1
    Former Arkansas State Police
    Mar 2003
    Boise, ID
    Quote Originally Posted by cletus284
    That is what it is doing, I tested it again and this time I got it to thow a code...
    15 - "Coolant temperature sensor or circuit fault - signal voltage high"
    I'm going to go buy a new temp sensor and see if that fixes it.
    Thanks
    Mar 2006
    StL, MO
    Double check that it is not a code 51 - PROM or MEM-CAL failure. This is consistent with your dim, flickering SES light. I'm getting this info out of my '91 Factory Service Manual.
    1991 K1500 - 'Red'
    "That'll buff right out."
    Apr 2005
    Boston, MA
    sounds like a short. check out that harness while your putting the temp sensor. let us know how it works out.
    2000 Silverado Z71 5.3
    1994 Blazer 5.7 TBI
    Mar 2003
    Boise, ID
    For those interested...
    First of all thanks to all for the suggestions, they really helped.
    It wasn't the Temp sensor, it was only 20 bucks so I started there - No Luck.
    I had an old Hyper-tech chip so I put it in and everything id fine now.
    lowdown
