Thread: How To Get Unstuck from Mud, and a scary story
Results 1 to 19 of 19
    Jun 2004
    Michigan
    I was stuck in a little mud this weekend. Bad timing as I received a call that my wife was being rushed to the hospital for emergency surgery. She was near death, but is ok now.
    I am replacing the stock tires this week with Bridgestone Revos
    I ordered a 48" high-lift jack with all the accessories today.
    I was stuck in a very small amount of mud, but the soil was soft because I think it was a farm field.
    I tried to jack up the truck and put some 8 foot long 2" x 6" under the tire to drive out.
    The boards provided NO traction, so I couldn't drive out.
    My friend got stuck trying to pull me out with a tow strap.
    No trees around, and no winch anyway.
    I won't be buying a winch as I never offroad, but I want to be better prepared if I ever get stuck again.
    Questions:
    1. What else can I put under the tire for this situation that would allow for good traction? One source suggested jacking the truck up and putting pieces of carpet under the tires.
    2. Would a come along help? I have a 2 ton one that wasn't with me at the time.
    3. What else can I do in this situation?
    4. Are there any videos or online sources to tell how to get unstuck?
    5. Do you know of any 4x4 or offroading forums that I can go to and do a search?
    Thanks.
    Jeff
    4PLAY OFFROAD - (owner) 01maroonz71's Avatar
    Oct 2005
    bradenton, fl
    Re: How To Get Unstuck from Mud, and a scary story
    well, i know people who have gotton stuck with street tires, not really stuck, but tires just get clogged and spin on top of the mud....well, about 3 guys later pushing on the tailgate, batta boom batta bing....OUT!!!!! if you have balled street tires, that may help some, but maybe not depending on the terrain. im sure others will chime in.
    1983 K10... D60/14bolt/4.56's/detroit/Goodwrench 350/TH400/NP208 and 40TSL's
    It gets the job done.
    "You See The Bigfoot?" TexanZ71's Avatar
    Apr 2006
    Austin Texas
    I always mud with street tires and every time I get stuck there is no way in hell I can get out nor can any truck pull me out so out comes a tractor to the rescue. I guess I am no help but I can relate to your problem.
    1996 Z71, 6.5" DC lift, 3" summit BL, 1 ton springs with AAL, SF 14-bolt, 4.10 gears, posi-lok, 35" DC Mud Countries on 16" Black DC-1's, ranchhands front and rear, and a homemade headache rack
    "Switching to Guns" opsbear7's Avatar
    Mar 2006
    MD
    wow i am glad to hear your wife is alright and all the best to her!
    As far as your situation goes...i have never been stuck (knock on wood), but then again i nevr do anything too extreme just some stuff up to about the bottom of the rim. Anyways to answer your questions my buddies have come up with some crazy but good ideas...
    The ultimate rescue boards
    Supplies
    2 2x6x8foot boards
    2 1x1x6-8foot boards
    Some Screws
    A Screw Driver
    Instructions
    Take the 1x1 board and cut it into 6" lengths. Then screw each length across the 2x6 every 8-10" untill you have a "Ladder" type set up. Then take a 4" length of the 1x1 and screw it vertically into the ends of each 2x6...these you "drive" into the mud to try to keep the board steady.
    Those boards are awesome and i have seen them in action. The only trick is you have got to get your tires on it. Now that may be with a jack or something, but that is up to you. Here is a quick diagram
    What do you guys think of my buddies idea?
    :biggun:
    Feb 2005
    tx
    Quote Originally Posted by 01maroonz71
    im assuming you meant bald? lol have you ever been off roading much any more? street tires def. arent mad for mud. just get a decent set of mt's and you'll learn more the more you off road.
    SSR Chapter
    Registered User sslamed's Avatar
    Oct 2005
    michigan
    where in michigan? you said no trees so a come-a-long wouldnt help unless you had a spade.. call someone with a bigger truck or dont get stuck! lol..
    glad your wife is ok...
    bagged 97 gmc obs excab SOLD
    lifted 93 z71 obs excab TOTALLED
    93 454 burban on 33's SOLD
    Registered User midnightsun13's Avatar
    Apr 2006
    damascus MD
    those boards look like a cool idea...the 4" pieces on the bottom could be slid into the stake pocket holes if you dont hav bedrails and hav something in the bed
    Registered User Acer2428's Avatar
    Lafayette, IN
    Don't drive in farm fields? lol.
    Every farmer knows that. A good set of tires and a longer tow strap should do the trick.
    '94 Yukon GT: 33" Winston M/T's, 15x8 Chrome Cragar 8 Holes. - SOLD
    '74 C10 SCLB - Drag truck project
    Mar 2006
    MD
    Quote Originally Posted by midnightsun13
    i never thought about the stake hole storage option...i like it. Also i forgot to mention that you may want to cut the edges of the stakes so they are easier to sink into the ground...
    :biggun:
    Newbie silver98Z71's Avatar
    Tifton, GA
    Quote Originally Posted by Acer2428
    Yeah, mud+ farmer's field=
    -Daniel
    1998 K1500 L31/4L60e/241/8.5/9.5
    Bogger Chapter
    Some people are just educated beyond their intelligence.
    -Jerry Clower
    Holland, MI
    Board setups like that work really well in mud or soft sand for helping to distribute weight or just give the tires some bite in the slop. I drive a concrete truck that weights upwards of 74,000 lbs loaded (granted it has 6 wheel drive and 445/65R22.5 tires), and whenever the situation gets bad or we want to avoid having to call a dozer, they just lay out some mats like what you mentioned. The mats we use for the concrete trucks are basically 3 - 2"x8"x8' spaced 4" or so apart with 2"x6"x30" boards nailed crosswise across the 8' boards at a right angle to the long boards. Sometimes if you can shovel a little mud away from the tires and wedge mats in under them, when ya throw it in gear the truck will pull itself up onto the mat.
    2003 Silverado 2500HD, LB7 Duramax, and some skinny ass tires
    Registered User SkyHigh98's Avatar
    Apr 2006
    Smog Valley - California
    In my suburban I used to carry this metal mesh like this:
    It was very heavy duty (weighed a lot but didn't bend with the weight of the truck) and worked very well to get me un-stuck.
    young and stupid er1c43's Avatar
    the heart of DIXIE [*><*]
    cant help u if ur alone, but some ideas above sound good
    as far as gettin pulled out by another truck
    the taller the easier u get out
    lD
    Last night my girlfriend came home earlier than she ever has and caught me, naked, watching porn, and stroking it with a mask and snorkel on.
    3" body lift,G-gaydee 35s, 3" straights dumped, cobra 29LTD cb w/ 102" whip
    Registered User NMBowtie's Avatar
    Oct 2005
    NM
    Only problem with the traction boards like opsbear7 shows is that if you spin your tires trying to get up on them, you can rip the cleats loose. Then, as the cleat pulls out, it rolls up with the screws sticking out of it and punches some nice holes in your tires. Don't ask how I know this.....
    2007 Silverado 2500 HD Classic ECLB 4x4. 6.0, 4.10's, G80, MB Blitz wheels, 255/85/16 BFG MT's, Predator programmer, SOLD! No more gov't motors for me, at least not right now.
    Gun control is not about guns, it's about control.
    Registered User midnite rider's Avatar
    Sep 2006
    right here
    I dont think the boards are a great idea. Heres why, With bald street tires you have to put the board so close together to be able to climb up them. If not you will stay stuck between them. Looks like a heck of alot of work . If the mud is that soft, your gonna play hell jacking the truck up high enough to get this huge contraption under it. I recomment good traction tires. Limited slip differentials, and learning the vcapabilities of your truck first and foremost. Second they make a device that claws into the ground to pull out without having a tree around. A good come along or winch and this small fold up claw will do the trick. Not too sure I have enough spare room to haul half a house in lumber around in the back of my truck to build this big wooden ladder everytime I get stuck.
    Mar 2006
    MD
    midnite...i agree with the tires, limited slip ect... that is definatly the way to go...but that is serious $$$...
    The boards i put up cost like $25 or less so it is just a quick easy idea.
    I do see the problem of the screws going into the tires if one of the cross peices comes off.
    I am curious to know more about the comalong with a "mud clamp" any links?
    :biggun:
    Registered User freyguy's Avatar
    Middletown, DE
    I got stuck once with my factory tires in a farmers field when picking up my goose decoys. One tractor later, I was out. I went out and put BFG MT's on, and never had to worry about it again. I also got like 55k out of them, so they were a good road tire too. Mainly, you also have to remember that momentum is your friend, and make sure you keep going until you know you are on dry ground.
    I'm glad your wife is ok now.
    2002 2500HD CC 4X4 SB 6.0L 6" ProComp, 37" Toyo's, Airaid Intake, Magnaflow, PCMFORLESS 93 Tune
    1995 C1500 SC/SB 4.3L 4/6 Drop and too much to list
    07 Tahoe LTZ - 2/3 Drop and Shaved up
    Middletown, DE
    All this and that again TikiClub2's Avatar
    Nov 2004
    ATX
    I think your best bet is to try some home-made 'boards' like that have been mentioned, a traction device (limited slip), and really a Winch. I know you don't offroad ever, but they are really usefull for other situations. Once you get one you'll start using it more than you think :imo:
