Thread: OBS Ex. Cab Stock Floor Body Drop???
Results 1 to 20 of 21
    Registered User sj250's Avatar
    Red Deer, Alberta
    I have been wanting to do this for years and finally decided to tackle it. I have checked out lots of posts and Jimmy P's tech thread on his SF. My question is on the size of square tubing. I know Jimmy and most of the reg. cabs use 2x4 (I believe 3/16")but is that big enough for an ex. cab? Would I be better off using 3x4?? Hopefully some one like Jimmy or Low88 that have done this will chime in. Is their anything that will need to be done differently for the 3". Any help or insight you guys have would be appreciated.
    Drive and Enjoy. Low88's Avatar
    Live Free or Die
    Re: OBS Ex. Cab Stock Floor Body Drop???
    I would use 2x4x1/4" should be plenty.
    As far as 3", I would seriously consider doing 2.5", becuase thats all you need to lay rocker. The extra 1/2" can be a pain in the ass for the little things such as trans, steering column, hood fitmet (my air cleaner hits, time for a lower profile one), exhaust manifolds... the list goes on.
    so fresh n so clean clean droppedsierra's Avatar
    Jul 2003
    OK
    when you use the stock frame rails with the tubing welded inside, i think 2x3x1/4 is plenty. ive seen a box style crew cab dually built like that, and im doing mine also. if you have plenty of crossmembers like you should, 2x4x1/4 is somewhat overkill. i mean ya, stronger is always better, but i think 2x3x1/4 will be fine
    too many rides... not enough time
    Live Free or Die
    I have seen a fully built s-10 chassis flex like a wet noodle with 2x3.
    use 2x4. trust me.
    Oct 2003
    St. Albans, Vt
    We did 3x4x1/4 it seems overkill but I wanted it to be safe. Anything over 2.5" on a SFBD makes think super tight under the cab.
    As it was, my 3" exhaust needed to be put in a metal brake and ovaled..
    Live Free or Die
    haha thats why im running 2" exhaust. viva la 4.3L.
    Red Deer, Alberta
    Oh sorry guys, there was some confusion. I meant things done differntly to fit the 3" tubing not for a 3" bd. If you go 4" tall tubing that automatically gives you the 2.5" drop, correct? The frame is 6.5" tall to start with I believe. If I do the 2.5" drop does that put the rocker right on the ground? I would like to do it so there is like an 1/8th to 1/4" clearance so the rockers themselves don't actually touch. I figure with it being that low and the rocker curving under, a 1/4" wouldn't really be noticeable and it would be nice just to have that extra clearance so the paint doesn't get fubar'd. Thanks guys for the response so far. I definately wouldn't have gone any smaller than 2x4 but I didn't know if bigger was really neccessary.
    HHH and Low88, what did you guys do for the rear behind the cab? Did you build a whole new rear clip or just modify the existing frame. I want to have everything figured out before I do it.
    Registered User Jimmy P's Avatar
    Aug 2001
    Michigan
    if you go with 3x4 tubing it gets hard to tie into the front of the frame rail because you cant slip it inside the boxed section. I guess its not hard but just takes a little more work. You could run some additional x members inside the framerails to further strengthen it as well. Measure for yourself exactly how much room there is between the rocker and frame rail currently and bd that much. No need to go any further, not to mention it will make everything else harder
    1989 Silverado Project // 2013 GMC Sierra
    Red Deer, Alberta
    Thanks Jimmy that is exactly what I was wondering about the 3" tubing.
    Live Free or Die
    Quote Originally Posted by sj250
    I did that. The top is stock frame, and i boxed it all together. I did it even further back than jimmy i think, and I still had to notch the cab a little.
    Red Deer, Alberta
    Thanks for the pic, I saw on Jimmy's thread how he angled that down as well. I was meaning more for the rear section under the box. Was it left stock and the bed was cut??? Now that you have done it how did you do yours and would you change it if you did it again? Thanks guys.
    Fear The Pinapple! Toolman's Avatar
    Feb 2002
    Hawaii
    Quote Originally Posted by droppedsierra
    no point in me posting anything else but this...
    Totally not needed.
    Personal Responsibility GO GET SOME!
    Dec 2003
    K-Town
    just raise your bed floor however much you body drop it and your done, and as far as 1/4 wall tubing I know it's safe and blah blah blah but I only used 3/16th wall so that my truck doesn't weigh as much as a tank when it's done, with the proper cross members installed you will be just fine for strength
    Live Free or Die
    Quote Originally Posted by Toolman
    Totally not needed.
    i should get a cookie for ignoring that. normally i fly off the handle and turn threads into lock mode. haha
    Jul 2003
    OK
    whats wrong with my post? just saying that noone will agree with me on how 2x4x1/4 is overkill? just my opinion, but i know it would be shot down by someone else...
    Dec 2003
    K-Town
    I think its overkill too
    Giggity Giggity Giggity comegetsome's Avatar
    Mar 2006
    Baxley, Georgia
    ^WOW that pic is awesome McCustomizer
    everytime i come around ya city
    now offically the three Bs...
    Bagged, Blown, And Bodydropped
    Boost me baby
    Live Free or Die
    i found more pics of mine...
    unmolestered frame rail, minus new body mounts
    before boxing
    outside view
    front Z before it got modified so the core support would fit... oops!
    and even if 2x4 is overkill.. it sure makes the job easier. I would hate to have to put bodymounts on a 2x3 frame. there would be no room for gussets up top, if there is even room for the bodymounts.
    Jan 2005
    ct
    i believe i used 2x4 3/16th for mine.
    Live Free or Die
    you bodydropped yours man? post pics!
