Thread: How to run Power wire!
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 103
    Supporting Member btnhtillidie's Avatar
    I Figured since I see people asking how to run Power with out going thru the firewall I though I would document how I did mine W/ pleanty of pics..
    First off you have to have some idea on how you want to run the wire. In my case I knew I wanted to run it under the truck. I knew exacty where it was going to plug into too.
    I used a drill bit that was a little bigger than the wire. You don't want too tight of a fit.Always make sure to run a groumet when going in and out of metal! (which I havent installed yet!)
    Now that you have a starting point, Look for ways to route your wires away from moving objects and Extream Heat. To secure it to the underside of the cab I used 1/2" cable clamps. Make sure you know what your drilling into, see whats behind it if you can, you don't want to put a hole into something that should'nt have a hole in it!
    at First I wanted to run it along the Passenger side frame, but found I didnt want to drill into the frame.. So I ran it along the drivers side frame utilizing the existing cables and fuel lines to tie wrap too..
    Next I went over the top of the tranny crossmember..
    Quote Originally Posted by btnhfan View Post
    One of my coworkers there was saying how great the optima batteries are, that you dont even need an alternator, they just recharge automatically.
    Quote Originally Posted by ikon
    I am however a guy that is 100% comfortable with his sexuality and see pink as just another color on the chart...clearly not the same on ur end tho
    Registered User jaredcc86's Avatar
    MPLS, MN
    Re: How to run Power wire!
    looks good
    is there any reason you didnt want to go through the firewall?
    next i had to run it up into the engine compartment.. Here is a criticle part. Make sure you do not tie wrap to the steering coloum or you will find it hard to steer. I went up along some wires (I'm not a mechanic) Making sure to keep away from moving parts and heat..
    now thats it is in the engine compartment we have to get it to the battery or fuse. I found it easy to route it along the firewall..
    Then I decided I would go through the Junction box (I think that's what it is called) you do not have to do this step but it was in and out using less wire instead of going around it or under it..
    next I ran it under the intake then to the fuse holder..
    and this is what it looks like when opening the hood...
    why I had the chance I also ran a ground from the Bat. to the frame..
    I tesed the wire inside the cab with a multi meter and its holding 14 1/2 volts..
    I next drove around the block to see if anyting would come loose and test my connections and everyhting is good..
    One step I havent done yet is make sure to wrap the wire in a protecter to keep it from the elements..
    This is just one way of running it with out going thru the firewall..
    I DO NOT RECOMMEND THIS WAY!
    Granted its a car but do you really want to show your PWR wire off?
    Eternal Procrastinator TheOtherSide's Avatar
    Apr 2006
    Atlanta, GA
    Quote Originally Posted by jaredcc86
    looks good
    probably because he is running 1/0 and didn't want to have to snake it through the interior. I am running my 4Ga under the body so that in the future, when and if I upgrade to 1/0, I won't have to modify too much of the install.
    Also, it's tough to hide 1/0 under anything in the cab. Its a pretty hefty wire, I think it's 1/3" internal diameter, so what, 2/3 to 1" external diameter. That's hard to hide.
    03 Silverado ECSB (4.8L)
    Kenwood x979 (w/ Sirius, Aux iPod) - Memphis MCA3004 - Crystal SSCS6 - Memphis 1000D - SI BM 12 (2.25 ft^3@32)
    Lanark, Ontario
    Why not just through the firewall, under the carpet? The edge of the trans hump can pretty well hide anything. Thats how I have always run mine...I'm not a huge fan of wires under my truck.
    Quote Originally Posted by TheOtherSide
    exactly plus if I ran it under the carpet it would look like a garden hose under there
    MPLS, MN
    Quote Originally Posted by Quyonmob
    this was exactly my thought. I would rather not drill into the underside of my cab either.
    I mean, the work he did looks good and i wouldnt be worried about much. But to have high end equipment powered by a wire thats running all over underneath your vehicle doenst seem like the best way.
    Registered User silverado2nv's Avatar
    Jul 2006
    amarillo
    i got 2/0 running in my truck through the fire wall and under the carpet cant even tell it was there
    WOW seems like alot of people have a problem with hideing the wire under the truck.. Through the firewall under the carpet is not they way I wanted to go. Now it's totaly hidden and right where I wanted it to be! I'm allready running two sets of rca's, two sets of cables for the comps, remote wire I did not need a 1/0 cable running through there also.
    Lanark, Ontario
    Quote Originally Posted by btnhtillidie
    Why did u choose to skip using a grommet?
    didnt skip it, just havent put it in yet!
    05 GTO upgrade.
    Apr 2004
    Better hope you never go down gravel roads. That wire would be beat to sh!t in no time.
    Registered User Kim Hanson's Avatar
    Nov 2006
    Canada
    Unhappy Re: How to run Power wire!
    I wouldn't do it like that..........( . )( . )............
    Registered User 99silveradoguy's Avatar
    Nov 2004
    usa
    he will have no problems running it under the truck. he ran it right alone the frame - high from the ground, especially with some wire loom around it.
    - 99 Silverado - retired to spare vehicle
    Black headlights/turnsignals/taillights- 6K HID Low beams, back on stock rims. current project/DD 99 jeep TJ
    Nov 2006
    Canada
    Lightbulb Re: How to run Power wire!
    Quote Originally Posted by 99silveradoguy
    I don't really know much, but the least amount of wire = more power to the system...example........20 feet of cables boosting a truck = crap ...less is better! ..........( . )( . ).......also the clamps that hold it to the truck should have rubber on them :damnit:
    Registered User ///M5's Avatar
    MN
    That needs loom on the underside otherwise you should expect problems. Just so you know NBS trucks have a nifty little hole pre-drilled by GM and a groove in the rubber footboard to run the 1/0. This with carpet is 100% completely unnoticeable.
    No promises on everyone else looking like this, but my 2002 does and took me just a couple of minutes to run. I ran it over the deadening and the ensolite in case I ever want to alter it. GM was nice enough to just use that black tar stuff to seal the hole which I reused to hold the grommet in place and seal everything up. The door grooves are sweet for the speaker wire as well.
    1991 BMW M5 -- Eclipse 8454, Eclipse PA5532, Seas W18E IB, Alpine-Scan D2904/6000, SoundSplinter Rli8 .65 tuned to 30hz
    2002 Chevy Silverado -- 880prs, Seas CA18RNX, LPG 25nfa, Mach 5 IXL-12, JL 1000/1 & 450/4
    The South
    Any reason you couldn't have run it down the passenger side? That way you wouldn't have the cable runnin across the engine compartment. Just a suggestion...
    RegisteredPoorCollegeKid
    Sep 2005
    Baytown TX
    I ran the wire under my truck but thats a waste of wire imo and looks a little wierd in the engine compartment. But I haven't seen any problem running it under the truck.
    What I did was run it on the passenger side and ran it in the channel on the cab. there is about a foot of exposed wire for the entire run. If you look at the bottom of the cab, you'll see rubbber "grommets" that go into the channel of the cab. I'll try to get pics up.
    MKader17
    Pimpin' in style
    lost
    The more wiring that is exposed to the elements the more chance of problems. I don't care how carefully you arte about routing it away from heat and tying it to the frame, there is an enormous amount of radiant heat under the body and the elements will attack the wire covering. Running wire that pulls that kind amperage outside is asking for long term problems.
    By the way, I use welding cable and still route it inside. That pretty stereo power wire is not designed for outside use. The covering is not rated for extended exposure.
    Removing road reflectors in a neighborhood near you- Dennis
    It will have Aircraft loom around it I havent added it yet. I took those pics right after I installed it. Wow didnt know so many people wouldnt like this LOL
