Thread: spider injectors
Results 1 to 16 of 16
    yorktown, va
    Question spider injectors
    i have a 96 k1500 with a vortec 350 and im misfiring on almost all cylinders and my mechanic told me that i need to replace the spider injectors.can anyone tell me a little about these injectors and if there is a way to get around replacing all of them and spending 2,000 to fix it.
    Sep 2006
    Tennessee
    Re: spider injectors
    If you're misfiring on all cylinders, I would think the problem is more likely to be ignition related.
    But to answer your question, there is a much better alternative to replacing the original spider injectors which use poppet valves. The redesigned injectors convert the system from CSFI to MPFI. The MPFI set is also much more affordable!
    Somebody help him out and post the part number.
    Beaner/Cracker Izzy's Avatar
    Aug 2001
    Fort Worth, TX
    St. Paul, MN
    Quote Originally Posted by masintenn
    haha CSFI to MPFI...thats good, I like that. Explain to me how just changing the type of injector changes the ENTIRE intake system? Central Sequential Fuel Injection and Multi Port Fuel Injection are two different things, and just upgrading stock poppet valve/injector to the Multec 2 setup does not do this..
    I'm All Tip thekl0wn's Avatar
    Apr 2005
    Indy
    '03 Tahoe - Blackey
    yorktown, va
    would it fix the problem if i just replace the computer that controls the fuel injectors?
    St. Paul, MN
    Quote Originally Posted by Z71Countryboy
    no, the injectors themselves go bad over time. If indeed the injectors themselves are bad, you will have to replace the assembly. Is the truck throwing any codes?
    Sep 2006
    Tennessee
    It's really not a MPFI conversion, but the injector configuration makes me think more of MPFI.
    96 chevy sub LT
    west babylon ny long island
    well i know what you are go though. i had the the same problem with my 96 . what had happen was the pop it valves in my injector were stuck . my mech took my injector apart and cleand each pop it valve . he soked each tail in cleaner then hooked up to a compresser and made shore that they sprayed right . he only had to change one valve in the end . the cleaning ran for about 350 . you can try to hook up to a injector cleaning system first . see what happens . if not well you can come to long island and see my mech . hope this helps .
    Beauty & Horsepower! SilveradoSexy's Avatar
    May 2006
    The middle of SW-VA
    I had a similar setup on my last vehicle, it was 96 blazer. the I had the same problem you are having, the feul spider had developed or degraded to were it was leaking feul all inside the plenum. The exhaust smelled like raw feul. I believe I got my parts at advance for half the price. I think around $500. I know it's not the exact setup you have but may give you an idea.
    '03 SS AWD 6.0L Radix 112 S/C w/ 3" pulley
    Nov 2006
    Henderson, Co
    Just did this job on one of our trucks, a 97 Chevy C1500 5.0.
    Had to replace all 8 injectors and the pressure regulator. Advance Auto had the injectors for $70 ea, and the regulator was $60. Upper pleneum seal set was $40. Took about 7 Hours total, from drive into the garage to drive out. Includeing changing the plugs and cleaning the Throttle body. Wasn't all that hard to do.
    St. Paul, MN
    Quote Originally Posted by mjwhoopie
    You replaced the stock poppet valves with new poppet valves? Did you have to pay for this out of your pocket?
    8 injectors x $70 ea = $560
    regulator = $60
    TOTAL COST = $620
    gmpartsdirect.com
    93441235
    The whole new assembly with Multec 2 injectors, which includes the regulator = $225
    Advance Auto kinda sucks at this point...
    May 2005
    Broken Bow, OK
    My 96 5.7L is running like crap. rough idle and it stumbles when you put the gas to it. The more load on the engine the worse it is. No codes are being thrown, and there is a gas smell to the exhaust.
    Could the injector spider be my problem too?
    May 2006
    The middle of SW-VA
    Could be, sounds like what I having.
    Supporting Member Chevyboy96's Avatar
    Jun 2004
    Longview, WA
    I installed the new spider injection system for about $360 total including gaskets. You can get the system & gaskets onEbay sometimes. Or you can order from GMPartsdirect.com
    '96 K1500 Ext. Cab, 5.7 w/Upgraded Spider Injectors, S&B CAI, 6" RCD, Flipped BJ's, 35" BFG M/T's On Ultra Xtreme's, Yukon 4.56's & True-Trac, Dual Flow 40's, Wet Okoles, Line-Xhttp://www.cardomain.com/ride/1281046/1 Sig By alphaecho4386
    Dec 2005
    Connecticut
    Quote Originally Posted by Chevyboy96 View Post
    I'm about to replace my spider injectors on a replacement engine I'm going to install in my 96 C/K1500. I got the upgraded kit also.But I have a question? when I removed the upper intake I found a small black O-ring sitting by one of the intake bolt holes and now I not sure were it came from.Is there any spot under the upper intake that has a o-ring.Any help would be awsome I really don't want to go forward with this without resolving this issue.Thanks Ray
