Thread: Changing from column shift to floor shifter ?`s
Results 1 to 8 of 8
    Registered User Escadually's Avatar
    TN
    Has anyone ever done this ? I`m thinking about building a full length floor console and I`m thinking I want to do a floor mounted shifter as well. Anyone (Hurst, B&M, ???) make a kit to do this in a 97 ? How hard is it to change over on my 4L80 ? I know the column will need to be changed, but is there anything else I might have to change out ?
    TIA
    97 C3500 CC 7.4 Vortec Auto
    Pearl White/Candy Red
    Bagged,Cowl Hood, Escy front end, more to come...
    04 Dodge 3500 QC SRW Laramie
    Cummins Diesel, Auto
    BDPP stacked w/Edge EZ, 2* timing, Donaldson muffler, BD RFI w/CAI mod
    Western NY state
    Re: Changing from column shift to floor shifter ?`s
    summit racing has 12 floor shifters for a 4l80. they are for street rod apps. but im sure yuo can make something work if you take some measurements.
    http://store.summitracing.com/egnsea...e+shifter&x=33
    04 Avalanche Z71
    Registered User tpichevy's Avatar
    meridian, idaho
    i have the hurst v-matic 2 in my truck and never had any problems with it....i love it!!
    TireFryr- Built 356ci Ported Accel super ram, Coated LTs,Built 700r4,2800Yenk stall,3.73posi "TractionLess"
    ~MONEY~ Leks's Avatar
    Throwin Sparks Down I-44
    I dont mean to sound like an a$$ or nothing but TPI you have all them mods and your only running a measly 14.9????
    Sorry for the bump!
    09 Maxima - Daily
    05 350Z - Sunday Funday
    85 C10 - Sons Project
    meridian, idaho
    yea thats what happens when you dont have a good tune and your still runnin stock exhaust manifolds and a stock v6 cross pipe thats been smashed flat from the 5-8 drop but that will change this wenter with my longtubes and mayeb a tune!! i have sh*t loads of low end tho i can put on a good smoke show with no use of the brakes!!! should be mid-low 14s come spring
    back on track now....i also got my shifter from summit...i guess the only problem i have had is a shift cable bound up and i broke it...but i had it routed wrong under the truck.
    TN
    I`ve always liked that V-matic, and that might work well with what I have in mind. How much of a pain was it to put in TPI ?
    This is All You'll See Boosted-Z71's Avatar
    Mar 2002
    Greentown, Indiana
    I have a Hurst Dual-GateII in my 98 ex-cab, floor shifter is a great mod, Count on making some brackets, shifter mount and generally just a total custom setup. There are no bolt-in kits that I know of & most of the shifter companies will tell you that xxxx shifter does not fit in a truck, end of conversation.
    There are pics of mine in my gallery.
    Boosted
    98 Ext Cab Chevy-Z71, 5.7, Built Front to Back. 87 SB 5.7 Vortec / TBi Combo, Getting Faster Everyday
    meridian, idaho
    mine was very simple....find out were u want to mount it on the floor, bolt it down and run a few power wires to it... N safty switch and run the shift cable thats it....but i had a 5speed so i didnt have to mess with the colom at all.
