Thread: 4L80E Won't Shift into OD
Results 1 to 17 of 17
    Ding Fries Are Done!
    Oct 2003
    Over there
    I was out driving my 94 fullsize today and the 4L80E wouldn't shift into OD, any idea what the problem could be? TPS maybe?
    Registered User chrisk1500's Avatar
    Canada
    Re: 4L80E Won't Shift into OD
    Not sure about the gassers, but on the diesels the 4L80E won't shift into OD if the coolant temp sensor is shot...
    07.5 LMM DMAX 2500 HD, ext cab, 4x4
    Oct 2003
    Over there
    the temp sensor on the engine????
    Oct 2003
    Over there
    What about the VSS? I checked it with a meter and it's not putting out any voltage (Hayne's book said it should put out 1/2 volt) and my speedo also isn't working.
    ASE/GM Cert. Technician
    Pembroke, NH
    If the vss isn't working, the computer doesn't know whn to electonically shift into OD. the first 3 gears work off the old Hydra-matic and then the TCC and OD works off the ECM. Change your VSS and check your temp sensor too. Some truck have 2 sensors, 1 for the gauge and 1 for the ECM.
    Oct 2003
    Over there
    where are the temp sensors located at?
    St. Paul, MN
    Quote Originally Posted by tucks20s
    what year 350 do you have? There is one right in the front of the engine, just below the thermostat..
    Registered User Escadually's Avatar
    TN
    ....and the other one should be down on the drivers side of the block in a water jacket.
    97 C3500 CC 7.4 Vortec Auto
    Pearl White/Candy Red
    Bagged,Cowl Hood, Escy front end, more to come...
    04 Dodge 3500 QC SRW Laramie
    Cummins Diesel, Auto
    BDPP stacked w/Edge EZ, 2* timing, Donaldson muffler, BD RFI w/CAI mod
    Oct 2003
    Over there
    ok thanks guys.
    Which one controls the temp gauge on the cluster?
    Also which VSS should I replace since the 4L80E has two of them, the rear one?
    BTW it's a 94 model engine.
    St. Paul, MN
    ok thanks guys.
    hmmm..well somebody correct me if im wrong, but a 94 only had 1 temp sensor right?
    my dads 94 4.3 just had the one on top of the intake, just to the left of the thermostat housing..
    Oct 2003
    Over there
    Mine has the one to the left of the intake and the one on the d.s. head. I THINK my 4.3 was the same, but I'm not forsure.
    Oct 2003
    Over there
    oh yea I just got the truck down off of the lift after testing both VSS's and the one in the back isn't working. Now I get to play the waiting game since no one around here carries anything for a 4L80E and it's the weekend
    Pembroke, NH
    The temp sensor on the intake is the one you want to change I believe. To make sure, unplug the one on the head and use a test light, hook it upto the battery positive post and have someone in the cab watching the gauge, and put 12v power to the 2 prongs, one at a time. If it's the correct plug, the gauge will spike instantly to hot. If it doesn't, then you have the wrong temp sensor and check the other one out the same way.
    rollin the nasty D's!!! Double Dueces's Avatar
    Apr 2006
    Minnesota
    ok thanks guys.
    replace both, if it still does it then your ineed of a rebuilt tranny,
    I bought my truck with a bad tranny. I would start out in 1st gear then when about to go into 2nd gear it owuld skip it and hit up 3rd then 4th gear. The tranny shop was it was the 1-2 band then said that the 3-4 band was going out too and said tey would rebuild it for a $$$$ of change. So I looked around and got a rebuilt one for a deal then its been like a new truck ever since it! After 100K on the tranny it then goes to hell is what all GM fans told me about the tranny, they were shocked that it got 150K out of it though!!!
    '01 XCSB a few mods done to it.
    truck parts http://www.supermotors.net/vehicles/...ry/10422/66312
    Mar 2006
    StL, MO
    Engine Coolant Temp sensor (input to ECM) is located on intake manifold. Coolant Temp Sending Unit (to guage) is in the left head.
    Is your Check Engine light on? Should be, if VSS is shot. Start by replacing the suspected faulty VSS.
    1991 K1500 - 'Red'
    350 Roller Cam TBI, 5-speed manual
    1995 Chevrolet Caprice 9C1 LT1
    Former Arkansas State Police
    Oct 2003
    Over there
    no the check engine light is not on, but I did a check on the VSS and it is not working.
    I ordered a VSS and it will be in today so I'll see if that is the problem...
    The tranny has around 20,000 miles on it so I don't think it needs to be rebuilt.
    I'll go ahead and pick up a temp sensor incase that is messed up as well.
    Oct 2003
    Over there
    I checked the temp sensor and it's fine.
    I installed the new VSS and the speedo now works, but when I got out and drove the truck it shifted into OD, but wouldn't downshift so now it's stuck in OD. Any suggestions?
