Thread: Testing TBI coil??
Results 1 to 9 of 9
    Indiana
    Testing TBI coil??
    How do I test my ignition coil to see if it is good or junk.
    Nov 2001
    Newcastle, Texas
    Re: Testing TBI coil??
    This testing procedure is valid for just about any automotive coil. Using an ohmmeter, check the resistance between the side terminals of the coil. Do this with all of the wires to the coil disconnected. You should see 0.75 to 0.81 ohm of resistance. Then check the resistance between either side terminal and the center high tension terminal. The reading should be 10,000 to 11,000 ohms. Any significant deviation from these numbers would indicate that the coil is defective.
    up mi
    Quote Originally Posted by 97Silverado
    umm i could be wrong, but that isnt the coil he has. there is a way to test the coil but i don't know how to post it here. there is a procedure in the haynes manual tho.
    Chevy truck owner The_Ogre25's Avatar
    Kewanee IL
    That may not look exactly the same as the coil he has but pretty much all coils have the pos, and neg terminals and the coil wire plug.
    Dec 2002
    /home/andy
    I looked at mine today when I did my cap and rotor. Its got the main high tension lug, and then 4 other terminals. Looking from the front of the truck, theres a pair on the left that goes to the distributor, those aren't the wires you're looking for. The terminals you want are on the right side, whose wires disappear in to the loom. Those are the 2 side lugs marked on the drawing above. I checked my coil and I got about 9kohms between the big lug and a side lug, and about .67 between the two little ones. A little bit out of spec but it runs great...
    Rest in Peace Jason Payne
    autozone has the procedure go here:http://www.autozone.com/servlet/UiBr...3d80085d3a.jsp
    Indiana
    Will this tell me if it is weak or just bad?
    it will tell you to replace it if its not within specs.
    Nov 2014
    United States
    I'm not the original poster, but I found this thread in a search, so I'm sorry if I'm bringing a dead thread back to life. When i test my coil with my multimeter I get 0.00 ohms. I'm assuming this is why I get no spark, but is it normal for it to suddenly quit? It drove fine the night before, but this morning it wouldn't start and it's giving me 0. 00 resistance. Could something have fried it, or since it's OE was it was just time to die?
