Thread: Converting from Dex-Cool to green?
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    Apr 2006
    Louisiana
    Are there any reasons you can't flush the system and start using regular anti freeze in a system that was using Dex-cool? Even if it has a sticker that says use Dex-cool only?
    Registered User churd69's Avatar
    Jan 2007
    Michigan
    Re: Converting from Dex-Cool to green?
    Quote Originally Posted by Bruce_B
    I believe that dex-cool is supposed to be anti-corrosive which is good when it is passing through aluminum parts. I'd keep with the dex-cool and just make sure your system is full.
    -Rich
    05 GTO upgrade.
    Apr 2004
    As long as you force flush the system it will be fine.
    Apr 2006
    Louisiana
    Quote Originally Posted by TITANIUM
    Thanks. Would it be enough to drain it, fill with plain water, run it up to temp with the heater on, reapeat a few times, and then go to regular anti freeze?
    05 GTO upgrade.
    Apr 2004
    Yep. As long as what is coming out is clean water.
    ohio
    does changing void a warranty if warranty is still in effect?
    Jul 2003
    Dallas, GA
    Quote Originally Posted by mavericki8r
    Probably. You change the coolant to a non specified coolant. Why would they cover it.
    Keep the dex.
    D/D-2006 HHR 1LT 5-Speed.
    Nov 2001
    Newcastle, Texas
    There is no valid reason to switch from Dex to green.
    ----------------- Chuggs's Avatar
    Nov 2001
    Southern Virginia
    Compromise -- go yellow! :assclown:
    Feb 2007
    AK
    Why do you want to swap back to an inferior product?
    If I were going to make any change I would look and changing to Caterpillar ELC or Cummins Coolant as it is some of the best stuff out there. http://www.cat.com/cda/files/165927/7/PEHJ0067.pdf The newer coolants like the dex-cool and other extended life coolants are designed and ph balanced for Aluminum engine components. Not to mention a lot of the better coolants don't contain any silicates in them so sludge and hard water calcification in the radiator are eliminated. In the long run you won't be saving any money by swapping back to the old standard antifreeze.
    And you can bet your boots that if you don't run a antifreeze that at least meets the minimum standards of the manufactures recommended coolant that you will not be covered by warranty if a problem should arise.:bawl: :bawl: :bawl:
    Nathan<><
    I Hate You All, Equally.
    Hell, Frozen Over.
    Talking Re: Converting from Dex-Cool to green?
    i switched to green because dex cool is too expensive and i heard that dex cool may lead to intake manifold gasket and water pump failure. on my 98 sierra i encountered both expensive problems and i feel that i am not losing any cooling performance due to it. in my town of goose bay labrador the temp. ranges from 30-45 degrees celsius. to -40 to -60 in the winter (like the last few weeks. and i have yet to see a downside. thats just me though. piece of mind matters more i think than scientific data.
    May 2006
    rochester ny
    dex cool eats intake gaskets period!
    Registered User ATMINF's Avatar
    Dec 2003
    All over the place(military)
    The only time that Dex Cool runs into problems is when you don't flush it regularly (every two-three years)and monitor the acid/PH of it. I know it says its good up until 150,000 miles, but what you really have to check is the acid/PH factor of it as it ages. Alot of times the acidity of the coolent gets compromised and people do not realize that the 150,000 is a BEST Case senerio.
    Its funny how the same people will be religous about changing their motor oil at 3,000 miles but not think about the other fluids in their cars/trucks.
    So in my case I have always flushed my system every two years and used some DEX Cool, distilled water and water wetter. When I took my 95 Camaro LT1 apart at 114,000 miles, the block and heads were clean like brand new. There was NO rust or "gunk" in the water passages at all. Its pretty easy to flush your system at home. All I did was to get the prestone flush kit and flowed the instructions and was good to go. Just my two cents!
    2001 Burban 3/4 ton-SOLD
    68 Camaro (still building)
    95 Camaro Supercharged and other stuff-SOLD
    2006 2500HD Silverado LS ExtCab 2WD 6.0L
    Mar 2006
    cincinnati
    Quote Originally Posted by 97Silverado
    Take apart a few motors that have ran dex their whole life and take particular not of water pump and intake gaskets. 'Nuff said.
    Just finished swapping over my Saturn while getting my truck to start running.
    Flushed the system using garden hose water about 4-5 times. Still have this feeling that I need to replace the heater core, it's marginal at best...
    Anywhose, it's cheaper, more widely available, lets gaskets remain pliable, and still protects iron/steel/aluminum just as well.
    For you folks with dexcool, get a multi-meter, and put the negative lead on the negative post of the battery, and the positive inside of teh coolant resivior (or radiator if that's closer).
    .2-.5v reading means it's good
    .5v-.7 is borderline
    .7 and greater means replace it asap.
    Campus policies left students shooting back with camera phones. Life's worth more than pictures. www.ConcealedCampus.com
    St. Paul, MN
    Quote Originally Posted by frank88chevy
    great info there, care to elaborate how you came to that conclusion? :twak:
    Hell, Frozen Over.
    Quote Originally Posted by 98GreenMachine
    found a link on this very site on the ad bar up there referring to a pending class action lawsuit regarding dex-cool. so don't judge me, judge the site if you want to but i am not taking the chance. i've never heard of green coolant eating up water pumps and intake gaskets cuz i have used it in my 97 civic,caprice, cavalier (which was all ****ed except the cooling system) and my diesel jimmy, my dads 86 chevy. never had one problem.
    Noob StepsideLM7's Avatar
    Jan 2007
    Roseville
    Dex is fine if properly maintained...i've seen how some people take care of their vehicles so it doesn't surprise me that there's complaints about it.
    A lawsuit doesn't mean anything...people sue now-a-days for spilling their own coffe on their laps at Mcdonalds. No one wants to take the consequences for their own actions...including lack of maintenance and it pisses me off.
    Registered User 4 Speed Dave's Avatar
    Apr 2005
    Connecticut
    Quote Originally Posted by StepsideLM7
    I fully agree. Before anybody makes a judgement on Dex-cool. Go and take a motor apart that has had only Dex-cool running thru it. Quit reading all these internet horror stories and making assumptions without even seeing the true results if used properly.
    When I replaced my 98 350 with a 383 I did just that and the coolant passages are very clean. Dex-cool doesn't eat anything. However you must make sure that there is not air in the system otherwise it does create a crusty substance and get thick. i.e. make sure your coolant recovery tank is full and you don't have any leaks.
    There is a problem when people do not maintain their vehicles and then want to blame someone for it. Now the vortec motors DID have an intake gasket quality problem which leads to them requireing to be replaced usually prior to 80,000 miles. However Dex-cool didn't eat them. The gaskets were faulty.
    I believe more people nowadays know how to maintain their computers better than their cars.
    2006 Chevy LBZ/Allison CCSB
    69 Nova: 3480 lbs Full interior with bench seat, 406, Jerico DR4 10.22 @ 130.45 mph
    St. Paul, MN
    Quote Originally Posted by Koots
    My comment wasn't even directed at you pal, so don't fire off some lame excuses why standard coolant works for you in all your vehicles that don't use Dex-Cool to begin with. Dex-Cool is a superior product to standard coolant, but like anything on your vehicle, it has to be maintained.
    Nov 2001
    Newcastle, Texas
    Here we go again.....
