Thread: Does AC compressor cycle in defrost when cold outside?
Results 1 to 20 of 27
    Because I Said So... srlbotanical's Avatar
    Saranac, MI
    Does the AC compressor cycle when I have my defrost on? I couldn't get it to come on today even with the AC on. Its cold as heck right now, does the compressor cycle when temps are real low?
    • 97 Chevy 4x4 extended cab 5.7L, the Daily Driver
    • 97 Jeep TJ locked and heavily modified, the Toy
    • 99 GMC Suburban SLE, the Family Tow Pig
    • Check out my ABS Override Switch.
    houston,tx
    Re: Does AC compressor cycle in defrost when cold outside?
    I know mine does but we consider 40 to be cold here in houston,tx
    Lanark, Ontario
    Mine does.
    2000 Chev Silverado 5.3L excoelis's Avatar
    Nov 2006
    Edmonton,Alberta
    Mine doesn't and it is -20 degrees here
    Saranac, MI
    Well, i am hoping it works again when it gets warmer...
    I have a feeling its toast.
    The Bad Guy Gran Patron's Avatar
    Mar 2003
    Houston,Texas
    I think it's so suppose to cycle at all times when it's on the defrost mode. Everytime I put mine on defrost,no matter the temp outside, it has turned on.
    Funny cause I had a lady come is the service drive and ask why the compressor kept coming on when on the defrsot mode. I told her it was suppose to do that.
    96'RCSSB 5.0L Cammed LS1 or 6.0 Coming Later
    03'RCSSB 5.3,3:73's,G80 SOLD!!
    Pennsylvania
    I think when it's low on oil, it cycles on and off. Thats what I was told.
    Saranac, MI
    I did a little checking around and the compressor should cycle in defrost. No doubt about it.
    My next step is to see if I am low on coolent oil, and all the electrical conectors are in place...
    You spent what on tools?!
    Dec 2005
    Essexville Michigan
    its supposed to cycle on, the way gm does it is they bring in the moist ouside air, run it thru the ac system to dry it, and then super heat the dry a/c air to defrost your windshield. i litteraly learned about that on friday. it doesnt make sense, but then again... it does lol.
    Pittsfield, MA
    Every car on the road made in the last 6 years or so that has an air conditioner works this way. The idea is to dry the air so as to not cause condensation.
    maliburacing freak J-Rod's 85sb's Avatar
    Jan 2007
    Kansas city MO
    Quote Originally Posted by tdoyle
    Quote Originally Posted by campaug86
    X2 it aint broke dont fix it. wait till it gets warm to see if it stays on. it will cycle also on cooler days 60s-70s should stay running the hotter it gets. the only real way to check is to see what the pressures are. mine will cycle on a 90deg day but will blow 40 deg out the vent it all depends
    Nov 2006
    Henderson, Co
    You probably need the ac system serviced. there's a safety switch that keeps the compressor clutch from engaugeing when the system is low on freon.
    Don't wait get it serviced.
    This is a safety item. Not just a summer comfort thing. It does make a big differance in defroster performance.
    Gold Member Sierra Stud's Avatar
    Dec 2005
    Colorado
    I remember reading somewhere that the a/c won't kick on below a certian temp... i.e. 40*f. I think I read it on here somewhere or in my '06 GMC manual.
    2006 GMC 1500 Z-71, RC Leveling kit, 285's, Line-x'd bumpers.
    Saranac, MI
    Just a quick update. I did a pressure test and it was fine. I also picked up a can of NAPA recharge coolant/oil and it took the whole can. So, I either have a leak and the system was totally empty, or I need a new compressor... Me thinks.
    Steve
    Knuckle Buster Coefficient's Avatar
    Jan 2007
    US of A
    When the compressor goes bad they make lots of noise. With your motor off try turning it with your fingers. You should be able to grab the clutch in front of the pulley and give it a turn. If it turns your good, if it don't... well. If your system has a leak, that oil will be all over the fittings or even the compressor.
    1994 Silverado K2500, 5.7 L, ECSB, 4:10's, Flowtech LT headers w/ FM 50 BB, Volant CAI. :fsc:
    Florida
    Quote Originally Posted by Sierra Stud
    Correct - you don't want the darn compressor running when it's super cold outside.
    The pressure switch went out on my Blazer, started up with defrost on @ 5 degrees F, blew the compressor to pieces due to thickened oil in the system.
    When it's cold, I always turn the A/C off before starting just to be safe.
    1997 Chevy Silvy Z71 Ext Cab 350
    2008 Chevy Corvette coupe
    Proud to be part of a family buying GM products since 1956
    2004 1500 SILVERADO
    Feb 2007
    Maui
    If the pressure checked out ok you can rule out a leak.The system will still take and extra pound.
    Sounds like the LOW PRESSURE SWITCH is acting up. It's located on the acumulator, thats the big silver tank on the pass firewall. Give the switch a few light taps, if it starts running
    the switch is bad. To check the whole elec system jump the connector with a paper clip. If it runs the the entire elec system is eliminated. The prob lies with either a bad switch or low sys press. Since the pressure is ok looks like the switch.
    Pressures should be around 40-60 psi low side and around 150-200 psi high side. Pay no mind to the low side watch the high. If below 100psi system is low........hope this helps
    Jan 2007
    Pa.
    On my Ford it said right in the owners manual that below 30 deg the compressor will not run when set to defrost. Cold air is dry air. It doesn't need dehumidification. Thats why people put humidifiers on their house heating systems. Cars without AC (If you can still find one) defrost just fine in the winter. Now I don't know about my Chevy, but there really isn't any need for it to run when it's below a certain temp.
    houston,tx
    yea right come to houston where cold air is humid air.lol
    Dont Worry, i'm a pro ;) gmcman7202's Avatar
    Brew City, Wi
    ya but to you cold air is warm air to me....
