Thread: Whats your timing set at on your 5.7L?
Page 1 of 3 123 LastLast
Results 1 to 20 of 59
    Mudder Phucker BMac4x4's Avatar
    Mar 2006
    Jupiter, Florida
    I had mine set at 4*btdc and recently advanced it to 8*btdc and it runs a little better. just looking to see what everyone else has thiers set at and the results they find at different settings.
    4/6 dropped Silvy on 22s
    C town Illinois
    Re: Whats your timing set at on your 5.7L?
    My timing was once a few degrees back and I did not know. I got it timed to 0 degrees and what a difference in power. It could now spin the tires with ease. I have not tried advancing it though. I have heard that the truck will feel better with advancing the timing a bit.
    Has your fuel mileage changed since you advanced it?
    BANG YOUR HEAD!!!!!! Mental Health's Avatar
    Dallas
    Mine was sluggish at 0 so I moved it to 4 BTDC and it made a big difference have not tried to go more but I think I will try 6 tonight
    Supporting Member sharp94's Avatar
    Jan 2007
    Lewiston,Mi.
    Mine was sluggish at 0 also , bumped to 4 , better , to 8 even better , to 12 did'nt notice anything sooo , back to 8
    Mar 2006
    Jupiter, Florida
    Quote Originally Posted by 94stepside5.7
    Not sure about the mpg because i havnt driven but a couple miles yet but ill let you know.
    Canuckastanie cpt. canuck's Avatar
    Jan 2007
    Toronto Canada
    subscribed
    Colt 6920/ AR15
    Noveske 16.1" barrel ,Timney target 3 lbs trigger,Colt new style m4 stock,ARMS S.I.R. rail,Trijicon ACOG TA31 sight,ARMS 40L back up sight,Vortex Flash Suppressor ,Knights ARMS Forward Grip,REDI-MAG Spare Mag Holder ,Surefire combat light,Laser sight
    and a GMC pickup too
    C town Illinois
    Quote Originally Posted by BMac4x4
    Thanks, I will probably be trying 8 degrees advance this weekend.
    Jul 2006
    Hanna, Alberta
    Whats involved in changing timing on a TBI? never done it before and would like to try it out.
    formerly Tmoney Trevor350's Avatar
    Georgetown/College Station, Texas
    Quote Originally Posted by Carl94
    wondering the same thing...how do you advance it?
    3" BL / 2.5" CCM / 305-70-17 Terra Grapplers / 17x9 Procomp 1089 / 4.56:1 / Magnaflow
    C town Illinois
    You need a timing light and you need to loosen up the distributor so that you can turn it to the desired degree. You also need to disconnect a wire that is either behind the glovebox or in the engine compartment. Do not mess with it if you dont know. find someone to help you out.
    Mar 2006
    Jupiter, Florida
    yeah i never disconnected any wire because i couldn't find what i was supposed to disconnect. I've set the timming several different times too.
    Dallas
    To adjust the base timing you MUST disconnect the above mentioned wire. If you don't then the computer is still in control and will adjust the timing while you are making changes so you really have no clue what it is set at:gone2far:
    Mar 2006
    Jupiter, Florida
    well nobody could seem to tell me where it is so i never did anything about it and havn't had any problem setting the timming. one person posted a pic and circled the map sensor claiming that that was it. haha. so if you can explain it more clearly then please do so.
    Dallas
    What year is you truck by the way? On my 89 the connector is close to the firewall and on my 91 firebird it is close to the A/C dryer. It is just a single wire brown with black strip IIRC I'll get some pics up today for you.
    Mar 2006
    Jupiter, Florida
    its a 93 so i should be the same as your 89. Pics would be sweet.
    Massachusetts
    In my buddies 93 it was in the cab behind the glove box. Simply unplug it, time the engine and plug it back in. Took us forever to find the damn thing, thought it was supposed to be in the engine bay but ended up it wasn't.
    1975 K10 Stepside- Tow vehicle and toy
    1964 Nova- Straight liner
    1956 Chevy 150- Cruiser under construction
    Mar 2006
    Jupiter, Florida
    So what is it? there are several things behind the glove box.
    Nov 2004
    Thunder Bay Ontario
    Its generally on the fat wiring harness near that plastic cover on your firewall.
    95 Silverado RCLB Z71 3/4 ton
    6" ProComp 3" BL
    38x15.50x20 Nitto Mud Grapplers on 20x10 Eagle Alloy 064 Series
    06 LQ9 6.0L, NV3500, 14SF with 4.88's
    True Duals, Mangaflow Dual-in Dual out with 45's
    Preferred Vendor justin's Avatar
    Aug 2001
    San Diego, CA
    If you've got the big plastic junction box on the passenger side of the firewall, then the connector will be back there. If not, then it's behind the glove box. Look for a single tan wire with a connector on it. It may or may not be in a loom. Under the hood I believe it is a tan wire with a black stripe, behind the glove box, I believe it's either a purple wire, or the same tan/black as underhood.
    Justin
    EFI University's EFILive Course Instructor, Black Bear Performance
    2003 Silverado SS. Radix. LS6 Cam || 2002 Trans Am WS6. Quasi-For Sale || 2008 Trailblazer SS
    C town Illinois
    On my 94, it was under the dash on the passenger side.
