Thread: Vibrating Fuel Gauge
Results 1 to 16 of 16
    Kansas
    I have noticed the fuel gauge on my 1999 Chevy K1500 Suburban starting to vibrate a lot. I believe it is probably still accurate, but the needle dances around aabout 1/16"-1/8". When I start or turn off the ignition it jumps all around for a few seconds.
    What might cause this? ...is it an easy fix? I figure it's just a matter of time before it goes out completely at this point and it's getting a little noisy.
    Thanks
    "ALWAYS".....M1 full syn.
    Bad Axe, MI.
    Re: Vibrating Fuel Gauge
    My '99 does the same thing it's in the gas gauge it's self,
    i was told you need to send it in to be fixed or find another
    used one..
    if you could find a new stepper motor you couls change
    it out and it would be fixed.
    -1999 GMC SEIRRA 3500 4x4 SRW
    - Vortec 454 / Mustang 5.0L Bosch 19LB fuel injectors,yellow top
    - G80
    - FF/4:10's
    - 4L80E / Valvoline Dexron-VI ATF / Magnefine ILF
    - Regular Cab long box
    - Western Unimount electro touch 7'6" snow plow
    - 98,000 miles all stock
    - Mobil 1 0w30
    Kansas
    How long has yours done this? Also, does it still read the fuel level even though it's vibrating, meaning does it still work or should I plan on mine going out?
    What's a stepper motor? ....where is it located and how hard is it to change out?
    Thanks for the reply
    Bad Axe, MI.
    Well i fixed my problem,it was as i described bellow
    it's the gas gauge it's self,i picked one up off
    ebay and checked it with my old one and like i said
    it had no resistance(drag)to the needle when i moved
    it with my finger,i switched over the odometer and
    installed the new cluster and the gauge works
    perfect!!!, so i would suggest you guy's may want to
    do the same.
    somehow the stepper motor that runs that gauge burns
    up and just moves freely and that's why it shakes.
    Quote Originally Posted by daman1
    i tore the cluster apart and checked each
    needle(gauge)if you take you finger and gently
    move the needle you can feel a little drag(resistance)now i believe this is what keeps the needles from shaking
    because they all have this resistance but the gas gauge and
    that's the one that shakes..
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    Kansas
    Is there any chance you have checked this place to see if they have anything that might work?
    I am googling Stepper motors but I see what you mean, they are hard to find for this year. I did find some on ebay for an '03-'06, I wonder what the difference is. I guess I need to pull my dash off and write down what it says.
    Bad Axe, MI.
    Quote Originally Posted by MASTER Brian
    Yea i emaid that guy with the '03-'06 steppers and he said they will not work and he odes not have any for our year, if you find any thing let me know i'm looking too.
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    Kansas
    Will do, I emailed him as well.
    great and eminent junkie
    NC
    I have a '99 tahoe which does this, and my buddies '99 Z71 does the same thing. Interesting. I'm subscribing to this tread :).
    J.
    Bad Axe, MI.
    E-mail sent...no response
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    Georgia
    My '99 Z71 Tahoe does this as well and has for over a year now. It has done this since I purchased the truck but still registers the correct amount of fuel. It appears to be a known problem with that year and model. ...just another thing I will have to repair on my aging beauty. :)
    Louisiana
    My 99 sierra does it as well, the fuel, oil pressure, and battery.
    Feb 2007
    Forsyth, GA
    My 98 has been doing it since i replaced the fuel pump. It still reads correctly so im gonna wait till it goes out, I'd like to find out how to fix it with out spending to much
    Registered User 87Iroc's Avatar
    Nov 2003
    Southern Indiana
    I had a 98 1500 that did this after about 6 months of ownership(I bought it in 05 with 160k on it).
    One time when I was under it, I saw a black wire with a tab on the end of it hanging beside the fuel tank. It was the ground wire lug had broken off the fuel sending unit. I never did fix it, but it should have been an easy fix...just needed to ground the tank properly.
    Not sure if its the same story on the NBS's or not. My truck just exhibits the damn bad fuel sending unit problems I've read about... Getting annoying and I've only owned the truck for 9 days.
    GregF
    87IROC
    05 GMC Crew Cab 1500 Z71
    Registered User Prospect62's Avatar
    Upstate, NY
    My 99 Yukon does this too, just thought I'd toss my hat into the ring. Started doing it about two years ago but has registered the correct amount of fuel this whole time. The needle just buzzes.
    1999 GMC Yukon 5W5
    Bad Axe, MI.
    do the same.
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    NC
    sweet! I'll go shopping.
    J.
