Thread: Jerking in overdrive under throttle
Results 1 to 20 of 27
    Registered User yukondave's Avatar
    Oct 2003
    Michigan
    Question Jerking in overdrive under throttle
    What could be the cause of jerking or missing while under throttle in overdrive at rpm of 2k and higher? If throttle is heavy enough to downshift to 3rd it won't jerk, but when od kicks in, it will. I am not getting any codes and no pending codes. Is this a trans problem? It's a 98 Yukon, 5.7L with L460E. Tranny was rebuilt 3 yrs ago.
    Re: Jerking in overdrive under throttle
    what year truck and what tranny is it?
    Matching Ninja 500r
    Oct 2003
    Michigan
    Jun 2002
    Wisconsin
    When it starts jerking, touch the brake pedal just enough to get the tcc to disengage-rpms will jump 2-300 rpms, if the jerking stops, its a possible tc shudder. You may want to get a scanner on it and check the cam retard- it may indicate distributor gear wear if its negative without any work done on intake manifold or anything else that needs the distributor removed
    Oct 2003
    Michigan
    I'll try it. Just to make sure: tcc is throttle control circuit? Thanks!
    May 2005
    Broken Bow, OK
    I had a 97 2wd that did that same thing. Under light accel or just at cruising speed it was like the engine would miss or hiccup. Never did it under med to hard accel. Turned out to be the ignition coil. Changed it and it never did it again.
    Minnesota
    Quote Originally Posted by yukondave
    TCC is the torque converter lockup. If you do what the other poster said about touching the brake and the shuddering stops then go to the auto parts store and buy a can of additive. They sell all different brands now, but it is for torque converter shudder. It is actually common and usually can be fixed with the additive, but not always. Don't keep letting it do it or it will only make it worse.
    Supporting Member sharp94's Avatar
    Jan 2007
    Lewiston,Mi.
    Quote Originally Posted by 99-2door
    My 94 k1500 350 also would do this in OD going up a slight hill or light acceleration, turned out to be the plugs on mine.
    lund posterchild! Pyrite Z's Avatar
    Jan 2005
    Southern Illinois,in B.F.E.
    on mine (97 k 1500) with the 4l60e it started shuddering like you mentioned but it also started acting like it was running out of fuel I do have the shift problem and the trans component slipping code. after I change plugs and wires it hasn't done it again....
    02 SILVERADO mine/01 SUBURBAN hers
    "ALWAYS".....M1 full syn.
    Bad Axe, MI.
    Change plugs, wires ,cap, rotor, should fix the problem, it's
    a cylinder miss i bet..
    Good luck!!!
    -1999 GMC SEIRRA 3500 4x4 SRW
    - Vortec 454 / Mustang 5.0L Bosch 19LB fuel injectors,yellow top
    - G80
    - FF/4:10's
    - 4L80E / Valvoline Dexron-VI ATF / Magnefine ILF
    - Regular Cab long box
    - Western Unimount electro touch 7'6" snow plow
    - 98,000 miles all stock
    - Mobil 1 0w30
    LS1 > You UCABlackChevy's Avatar
    Mar 2006
    Arkansas
    Quote Originally Posted by daman1
    Good luck!!!
    Thats what mine was back in December. Ended up being the distributor cap was worn, cracked and corroded.
    this thread might help diagnose the problem also. http://www.fullsizechevy.com/forums/...d.php?t=217771
    1998 Pontiac Trans Am WS6 | ASC #2698 | #22 of 32
    DD: 1991 Chevy Silverado w/190k miles.
    Bad Axe, MI.
    Yup mine too,,seems like these distributors corrode amd
    cause a miss quite often..
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    Oct 2003
    Michigan
    I did the trick with the brake, the rpm's went up a little and the shudder stopped. It returned when I let off the brake. I'll be checking the distributor and looking for torque convertor additive. Thanks all, for the advice.
    Joliet,IL
    Well I am just going to put my 2cents in this. I have a 99 tahoe with almost the same jerking problem but only in 3rd gear on hi rpm. In overdrive above 2500 rpm I did the whole plug, wires, cap, and rotor deal still the same problem. Then I hear someone say on here that the wearring on the dis. may be wornout and the timing may be off. So I work for a Internationl Dealer in town and we had a "snap on" scanner. I guess this is how you check timing on the chvey they say on here so i gave it a shot and my timing was off by -6 we got it back on time, you have to be -2 or +2 some where in there then i took it for a ride and that took care of it.
    May 2010
    Nevada
    My 1998 Tahoe began having the same overdrive jerking problem at about 143,000 miles. The spark plugs had been in since 100,000 miles and the shop said they were fine. After finding this thread I replaced them and all seems good, though it's just been a couple days and I haven't been up to 70mph yet; just a 55mph highway with hills. Feels like I have a little more power, too.
    The engine was also hiccuping while idling at intersections, and that has gone away with new plugs.
    Registered User Turkmod's Avatar
    Jul 2010
    Brandon, Manitoba
    my silverado did the same thing going up hill i wasnt forcing it or anything it wouldnt downshift unless i made it to get the revs up so it wouldnt do it......... turned out to be my plugs
    May 2010
    SFLA
    you guys have been hitting all around it, just want to add that any engine problems are magnified when in OD with the Torque converter clutch applied
    Jul 2010
    Brandon, Manitoba
    mine did it under any stress especially up hill. i dont think the truck is supposed to jerk like it does.
    Dec 2001
    nixa, Mo
    My 98 ext-cab Z71 has been doing the same thing lately but my ignition components area all fairly new. My distributor is original though but I have a billet aluminum one to put in some time. I was thinking it had to do with my tranny. My truck only has 115,000 miles on it.
    Wayne
    Sep 2010
    Nebraska
    hey I need some help i have a 1996 burban with 228,000 and mine shutters i guess you could call it after i crest a hill and let off the throttle i just purchessed this truck like 3 weeks ago the first thing i did was replace the plugs and put a K&N air filter in it i need to change the oil but it feels like my tranny might hit the ground any second but its strong every other time except when it does this and when this first started it threw a code of a intermittent MAF sensor so i pulled it out and cleaned it and it went away for a day or so and now the light is on again havent checked to see what the new code is any helpful hints?
