Thread: Best way to remove radiator hose w/o getting fluid everywhere?
Results 1 to 15 of 15
    Ding Fries Are Done!
    Oct 2003
    Over there
    I have the entire engine and brackets painted with single stage paint and was wondering the best way to get all the fluid out of the engine w/o getting fluid everywhere? Should I just drain the entire radiator and then crank the engine up for a moment so it'll cycle the fluid through it?
    2000 Silverado Dubyagee's Avatar
    Feb 2002
    US
    Re: Best way to remove radiator hose w/o getting fluid everywhere?
    Aim it nose down and pull the lower radiator hose into a bucket.
    I have a White Eyebrow WhiteBrow24's Avatar
    Twin Cities, Minnesota
    if you have the motor out of the truck you can just dump it out of it, but inside the truck, unsure of the best way, i supposed you could do it the way your thinking but that stuff would be hot as hell coming out if you let it cycle and have the t-stat open so it releases it....
    Brian Threet 3-17-87 - 1-05-08
    Jenna Foellmi 9-15-87 - 12-14-07
    I feel you everywhere I go, I see your smile, I see your face, I hear you laughing in the rain, I Still can't believe you're gone.
    Registered User Kenny C's Avatar
    Sellersburg, IN / Louisville, KY
    You could use some hose crimp pliars to keep the mess down to a minimum. Not sure how to empty the block though. What are you trying to accomplish by removing all of the fluid?
    '07 Sierra Denali - 6.2l L92, 6L80E, AWD w/3.42s, HPTuners, Innovate LM-1, Volant CAI, 160* t-stat, N-Fabs, 2.5" leveling kit and 285/65/18 Nitto TGs
    Oct 2003
    Over there
    Well I don't need to empty it all, but I'm putting on a stainless flex hose up top, polished thermostat houssing, and stainless braided sleeved hose covers on the rest of the parts.
    Strictly Business GarnerZ's Avatar
    Apr 2006
    Garner,NC
    just open the release valve on the bottom of the raditor let the coolant drain for like 5 to 10 minutes, sqeeuze the hose to, upper and lower while draining. then it should not leak but a few drops... good luck
    2011 Summit White LTZ * Need Sig
    Kiowa, KS
    If your wanting to just remove the T stat housing it pretty much traps coolant on top of the t stat and is gonna make a little mess no matter what. As far as draining the block try taking the knock sensor out or there should be another plug on the side of the block as well.
    South Carolina
    Just put a bunch of shop towels around
    May 2005
    Broken Bow, OK
    Drain enough of the coolant to get it below the upper radiator hose and then take the hose off at the radiator. Use a wet-dry vac to suck the remaining water out before taking it off at the thermostat housing.
    Nov 2003
    Oklahoma City, OK
    Pull and run...
    -Grady-
    2001 QS Z06 - 19"/20" Foose Speedsters, Black-Out Kit, FLP Headers, Magnaflow Cat-Back, Cat Deletes, Hurricane Air Intake, Dyno Tuned 380 RWHP & 370 RWTQ
    2bad$doesn't growon trees 96thebossgrnchv's Avatar
    Sep 2005
    lafayette, Louisiana
    Quote Originally Posted by 99-2door
    this seems like the best idea
    latruckscene.net
    98 lsx camaro
    if i read correctly, you dont need to drain the block to put hoses on, unless your changing the bottom one, and if your changing the bottom hose, just do it as fast as you can, either way you do it, theres gunna be a mess.
    Aug 2001
    New Jersey
    The antifreeze won't hurt the paint.....you're going to get some coolant on it no matter what.
    Kiowa, KS
    Quote Originally Posted by CKTA
    If you leave it there and go drive it afterwards the paint might get stained by the coolant but just hose it down and it should be fine.
    Jul 2006
    Az
    Radiators usually have drain ****s in the bottom corners. They can easily be stopped mid stream. (no pun intended) Blocks usually have threaded plugs into the water jackets on each bank, but those are a little tough to stop once they're pulled...
