Thread: Best gear ratio for 40" tires?
Results 1 to 20 of 31
    Feb 2007
    Lufkin, Texas
    Hey guys, I'm planning on putting some 39.5x18x16.5 Boggers on my truck and I'm wondering what gear ratio I need to install. I don't do very much highway driving at all and I rarely go over 55MPH. I want good acceleration! Also, how much does it cost to change the gear ratio? Any help is appreciated, thanks.
    Legend HDhoss's Avatar
    Sep 2005
    texas
    Re: Best gear ratio for 40" tires?
    5.13
    2005 chevy 2500hd x-cab swb, 6.0, 4.10's, k&n fipk, 285-75-16 nitto terra grapplers wait4me tune. 2000 4x4 reg cab 7.5 inch fabtech 3inch Bl, 35/14/16.5 ground hawgs, 4.10 gears. fipk. wait4metune, other goodies.
    "I dont get stuck, only temporarily delayed."
    I'm so much cooler online Mark13's Avatar
    Nov 2006
    Northern, Illinois
    7.17 would work wonders:LOL:
    2006 Chevy 2500HD
    Boss 9.2 Poly V plow
    BigRed05
    What truck is this going on? Is it a diesel or gas? Do you Tow? What axles do you have?
    Feb 2007
    Lufkin, Texas
    It's a 2000 Extended Cab Z71, 5.3 gas engine, I don't ever tow anything and I have stock axles as far as I know.
    -"NONO"-
    May 2007
    Eagle River, Alaska
    40" boggers are going to destroy your axles. If you're set on running a 40" tire and the stock running gear, I'd get a 40" MTR. Hell, 40" boggers break D60's and you're not even in the same ballpark for strenght.
    BigRed05
    Quote Originally Posted by datboyroy12
    Ok man, dont mean to bust your bubble or anything. But i think my truck is pushing the limits right now. You will need a new rear axle. Your going to want to put a 14SF axle. I am rebuilding one from a 89 2wd 2500. Now your front end. My buddy derrik Has these on a jeep, Do you know how heavy these tires are? And you are going to have to run a huge offset wheel with wheel spacers. Just thought i would let you know. But 5.13s would be your best bet. And it will cost you between 1,200and 1,800 for gears. You will want a locker in the rear also. Add bout 500 at least. What lift are you going with?
    Registered User red o4's Avatar
    Jan 2007
    Kinston N.C.
    40 inch boggers on independent front end is going to be sudden death. And the rear axle is going to break soon. The best route would be 1 ton front and rear axles.
    04 z71
    3 inch body lift
    305/70/16 MTZ's
    16x10 Ion's
    Wheatley 93 tune
    K&N 77 intake
    :fsc:
    Z71
    Ontario, Canada
    go with 35's and 4.56 or 4.88....that be a nice setup
    sig is too big please edit to smaller size FSC STAFF
    2002 GMC ecsb z71
    Straight Duals Exhaust
    Hypertech Programmer
    Rough Country 6" Series II, with keys and add-a-leaf
    35x12.50x17 Toyo mt and XD Spy 17x9
    http://s166.photobucket.com/albums/u102/davis4x4/
    BigRed05
    Quote Originally Posted by burly_bus
    Every person and their grandmother has this set up, got to be a little different.
    Registered User HD4Mud's Avatar
    Palm Bay, FL
    Where would you get 7.17s. The steepest I've seen on the we are 5.38s
    Dec 2003
    Washington
    I think i've posted this a million times but check out this gear chart
    http://www.4lo.com/calc/geartable.htm
    Quote Originally Posted by BigRed05
    If your gonna go through the time and trouble putting in a new axle might as well go with a 14 FF
    BigRed05
    Quote Originally Posted by taSk
    Not if he wants to keep 6 lug front and rear so he can Rotate his tires. And a 14SF is the strongest 6 lug that is decent priced.
    Jan 2007
    OH
    I've snapped a D60 axle with 35x14.50 boggers. 40's are certain death for your axles and tranny if looking for "acceleration"
    Milk The Cow The_Law's Avatar
    Nov 2001
    Baton Rouge, La
    5.13's for sure. I'd get a 14ff or D60/70ff rear. I'd skip the 14sf because it's strong but still a c clip axle.
    "When life gives you too short of bolts, don't put thinner nuts, replace the bolts."- The_Law
    Nov 2006
    Northern, Illinois
    Quote Originally Posted by HD4Mud
    I found them on a site somewhere for sled pulling trucks.
    2006 Chevy 2500HD
    Intenionally blank b454rat's Avatar
    Dec 2005
    Binghamton NY
    Go ahead and put them on, just show pics of all the busted peices. Dana's and 9" can run some steep gears, mostly Dana's for industrial equipment. Gonna need a 60 up front, and either a 14ff or a Dana 70 in the rear. If you change your t-case to a pass drop, you can run a GM/Dodge 60 and a D70 rear, you can get steaper than 5.38s.
    Registered User bggrnchvy's Avatar
    Apr 2004
    Bay Area, CA
    7.17's exist for D60/70's. 5.38's are the lowest offering for the 14FF and the 8.25 front only goes to 5.13. Id go as deep as you can with 5.13's.
    An 8 lug full floater would be nice, paying for those 6 lug hubs and turning the axle shaft flanges is pricey though.
    1997 K1500 ECSB LQ9/80e/241/D60f/C14FF
    2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
    RBz OFFROAD
    Sep 2002
    Ponchatoula,LA
    5.13s and run it till she blows. Boggers are the **** what lift are you gonna run???
    -2003 GMC ECSB 2500HD 4x4 496 8.1L, Allsion, Volant CAI, Helix Power Tower, Granatelli MAF, Dual 3" w/ X-pipe no mufflers/no cats,3" PA BL, 8" Fabtech, Custom Steering with 3/4 Heims, 42 TSL SX IIs, 20x10 MT Classic IIs.
    Registered User TAHOE GUY's Avatar
    Dec 2005
    sunny california
    bggnrchvyWhere can I find some 6 hug hubs to put on a 14FF axle and how much? I would like to go with that route my self.
