View Poll Results: Do fuel injector cleaners work?
Voters
139. You may not vote on this poll
  • Yes works great
    42 30.22%
  • Yes but not much of an improvment
    63 45.32%
  • No doesn't work
    20 14.39%
  • Never used it, never will
    14 10.07%
Thread: Fuel injector cleaner. Does it work for you?
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
    Registered User chevy_rider88's Avatar
    Oklahoma
    I'v tryed the liquid fuel injector cleaner that you put in your gas talk before you fill it up and it cleans the carbon deposits in your engine and/or cleans your fuel injectors i'v felt a little bit improvement.What do you guys think about it, whats it done for you?
    02' Chevy Tahoe,projectors/angel eyes,CAI.
    91' GMC Sierra step-side
    88' Chevy Silverado step-side,new paint,all new interior,blue neon,LED taillights,chrome pipes
    http://www.cardomain.com/ride/2658628
    Registered User Z71Nutty's Avatar
    May 2005
    MN
    Re: Fuel injector cleaner. Does it work for you?
    It has to be dirty to work...used it on on my trucks/cars the only time that I noticed a real difference was on my old '77 Scottsdale it was running like poo and a can of Sea Foam fixed that instantly!!!
    :rocking: Red 2004 Silverado Z71 ECSB, 17" Alloys, 265 Dueler Revo's, Spectre Cold Air, No Name Dual Exhaust, TruXido Lo Pro, Westin Nerfs, OnStar, XM, TomTom, Bose, USA Spec iPod interface, Sprayed in bed liner and Valet Remote Start!
    May 2007
    Michigan
    I used Lucas injector cleaner in my cars and it works pretty well considering the miles on the injectors.
    Oklahoma
    thats the one i used, i also tryed a chevron one it was more but i think it was just because of the name
    Registered User qayak's Avatar
    alaska
    i have tried a few different brand they all seem to cure the pinging when carbon builds in combustion chamber.
    Supporting Member Chevyboy96's Avatar
    Jun 2004
    Longview, WA
    I use it, usually at oil change time. I read somewhere that the Chevron stuff had more cleaner than the rest, most of it is just liquid bottle filler. Seafoam works rally good IMO
    '96 K1500 Ext. Cab, 5.7 w/Upgraded Spider Injectors, S&B CAI, 6" RCD, Flipped BJ's, 35" BFG M/T's On Ultra Xtreme's, Yukon 4.56's & True-Trac, Dual Flow 40's, Wet Okoles, Line-Xhttp://www.cardomain.com/ride/1281046/1 Sig By alphaecho4386
    Woodstock Ontario Canada
    The most effective way to clean MPFI injectors used in teh 1996+ trucks is to disabel teh fuel pump, atach a feed hose to the fuel pressure test port, and use some GM Cleans or TEC(top engine cleaner) in a pressurized container mixed with some gas. Start teh truck and have the engien run off teh cleaner gas mix. I beleive Kleenflo or some other company actually makes a pressurized cylinder which comes with teh tets port fitting and teh cylinder is pre presurized and filled with cleaner. Simply disable fuel pump, attach hose and start truck.
    be careful, some injector cleaner isnt the best to pur into teh tank as it can harm some fuel pump seals and parts.
    peace
    PAuly
    May 2005
    MN
    Do you know how to spell...THE^^^^ LOL!!!
    Ill cut you... MeanGreen95's Avatar
    NC
    I usually use it every oil change just to keep the gunk down in my fuel system. I really dont notice that big of a difference because i use it often though.
    Oklahoma
    Quote Originally Posted by Z71Nutty
    my bad
    May 2007
    jersey
    i've used it in a few of my vehicles when i thought it was running crappy like stalling/poor idle/misfiring/etc. i don't think it made a significant difference though.
    Feb 2004
    Vancouver WA
    Seafoamed my pinging engine, no more ping!
    Now I have a more aggressive tune and still no ping!
    I Also Drive A Ram!! CahtasZ's Avatar
    Wesson, Mississippi
    im pretty much the same i try and run Sea Foam every oil change in my 05 just to keep it from not tearing up really. no much on being able to noticed something but i dont really wanna have to notice it is the truck is running great lol.
    !!!FIRST TO GO LAST TO KNOW!!!
    94 GMC Sierra 4x4. work in progress..stock.
    07 3/4 Dodge Ram,CUMMINS,4wd,35 Open Country's
    Tbi-MAX
    Quote Originally Posted by chevy_rider88
    those liquid injector cleaners are watered down mixtures... I like mine concentrated.. what I do is put .3-.4 gallons of kerosene mixed into my tank... this is a super dose of cleaning power. Most injector cleaners contain some sort of kerosene in them. And they come in small bottles; this is nothing compared to .3-.4 gallons! Ive done this on all my injected vehicles with good results. Maybe 2 times a year. I do notice the fuel will burn even longer, while it cleans deposits in the tank, lines, injectors.
    Call me stupid, but several old school mechanics thought me this... When I droped my gas tank with original pump and 202000 miles, to install my 255 walbro pump. That damn tank was ultra clean, and had no build up at all, strainer was even clean. but I replaced it all.
    Beauty & Horsepower! SilveradoSexy's Avatar
    May 2006
    The middle of SW-VA
    It probably works better as a maintence thing, as stated above. Once you are having problems it might help some but not remedy the problem. I use it with every oil change.
    '03 SS AWD 6.0L Radix 112 S/C w/ 3" pulley
    Palma non sine pulvere... FarmTruk's Avatar
    Jan 2007
    Wallburg, NC
    I agree with SilveradoSexy. I consider it a regular maintenance issue, a can each oil change. Like someone said above, I imagine most of the off-the-shelf stuff is fairly diluted, and is likely not aggressive enough to really make a difference if there's already a problem.
    1968 CHEVY C10
    Registered User SpeedDevil's Avatar
    St. Louis
    Quote Originally Posted by Tbi-MAX
    so just straight kerosene from say walmart or something right in the gas tank?? I may have to try this.
    Apr 2004
    Grand Rapids, MI
    I didn't really start doing it until my second car, a '92 Lumina, and it seemed to help. I got religious about it when we bought the '97 Cutlass from my parents. It had 46k on it, and has 190k on it now, and FI cleaners seemed to help keep the fuel economy up. The plugs lasted forever in that thing, although they did have deposits on them. I switched to using Seafoam about 2-3 years ago, and I don't know if that will improve the deposits, but it has worked well for me in both the car and truck.
    Also worth noting IMO, switching to synthetic in the Cutlass really seemed to clean the carbon out of the crankcase. For the first few oil changes, the oil came out extremely black. At this point, even at 4k-5k miles, it has good, albeit dark, color.
    2001 Chevy Silverado LS EC/SB Z71 | TB Crank | 5.3L | 3.73 | 285/75R16 BFG KO2 | Dick Cepeck DC-2 16x8 | MBRP XP Series S5018409 T409 Cat Back Dual Split Side Exit
    Jun 2003
    Waxahachie, Texas
    I use Lucas at each oil change.
    2002 Silverado LS 2 wheel drive
    Flowmaster 50 with twice pipes out the back
    K&N FIPK
    Granatelli MAF
    Hotchkis sway bars
    Line-X
    Slim Top
    "A sewer worker is like a brain surgeon. We're both specialists."
    Ed Norton
    Apr 2005
    Minnesota
    I use a can if seafoam with every oil change. Works well.
