Thread: 4.3 V6 Extremely high oil Pressure?
Results 1 to 19 of 19
    None of Grady's Business
    I've searched the forums for an answer...and the two answers that come up are:
    1) Bad stepper motor-must pull cluster
    2) Faulty oil pressure sending unit
    The questions that I have are...if it's the sending unit...where is it located (I found enough posts about the V8 location)...what about the V6 location?
    My gauge reads WAY past 80...if the gauge was a clock...it fluctuates between the 3 o clock position and 5 oclock.
    Occasionally it will read NORMAL...for a second or two...
    Could this be a loose wire running to the sending unit, too?
    Any help is greatly appreciated!!!
    Dealership Mechanic 05truckster's Avatar
    Jun 2007
    texas
    Re: 4.3 V6 Extremely high oil Pressure?
    Does the gauge in the cluster drop to 0 when you engine is off or does it seem like it gets stuck?
    2005 Silverado 5.3l lm7 maroon, Airaid system, Hypertech programer, and 3.73 gears! Is destined to be great!
    When the engine is shut off...the needle goes to near the middle mark of the gauge...it doesn't go to zero.
    while the engine is running...the gauge fluctuates with the engine RPM...it's just reading from about 70 to way off the gauge to the right...
    BTW...about two years ago...the chevy dealer had to replace the whole cluster...when the whole thing went dead...right out of warranty. The dealer actually covered it under warranty!
    Any thoughts?
    Keepin it Reeeeeeel $gmoney$'s Avatar
    CALIFORNIA
    Maybe you just have really high oil psi.
    Sounds better than having too low oil psi.
    2001 Chevy Silverado 1500, Fabtech 4" spindles on Eagle alloy 063s on 33" bfg all terrains, Limo Tint
    http://www.cardomain.com/ride/3067770
    Jun 2007
    texas
    You have a bad cluster! not sending unit.
    yesterday we had to replace 5 cluster. there just a really poor design.
    Austin Texas
    Yeah, that sounds like a gauge. My truck runs a little higher than half way on the gauge, over 30 psi. You'd think if it was really that high then you would have a problem and feel it or know it. The gauge should go to zero like the others when you kill the ignition.
    "ALWAYS".....M1 full syn.
    Bad Axe, MI.
    Engine off key on...... does it go to zero?
    -1999 GMC SEIRRA 3500 4x4 SRW
    - Vortec 454 / Mustang 5.0L Bosch 19LB fuel injectors,yellow top
    - G80
    - FF/4:10's
    - 4L80E / Valvoline Dexron-VI ATF / Magnefine ILF
    - Regular Cab long box
    - Western Unimount electro touch 7'6" snow plow
    - 98,000 miles all stock
    - Mobil 1 0w30
    Quote Originally Posted by daman1
    Nope....it seems that the zero point is the mid point on the gauge...
    Bad Axe, MI.
    It should go to zero with EOKO.
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    Jun 2007
    texas
    Its a cluster. it jumped out of range.
    CALIFORNIA
    my cluster goes on the white needle before 40 psi. Never hits 0 when the keys out.
    Thanks guys...I really appreciate the help...
    Traded it in on a new 2007 Silverado...I like the V8 much better...along with the better mleage!
    Bad Axe, MI.
    Quote Originally Posted by xplantdad
    That one way to fix a problem. LOL!!!
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    Yep...other things were starting to go wrong, too. I'd rather put my time, money and effort into my 66 Chevelle...
    Bad Axe, MI.
    Yep, good luck with your '07, nice truck!! :o)
    - G80
    - FF/4:10's
    - Mobil 1 0w30
    Yes, I have a FSC as well X-Runner's Avatar
    Georgia
    My truck runs 60 idle lol
    CALIFORNIA
    Quote Originally Posted by Tech Guy
    Warm?
    Mine runs like 55-60 cold
    18-21 idle
    30-40 crusing
    Georgia
    Quote Originally Posted by $gmoney$
    Warm?
    18-21 idle
    30-40 crusing
    All the time, I think my gauge is broke. New cluster and sending unit and same thing. Im getting a real gauge today.
