Thread: Location Of Oil Pressure Sending Unit????
Results 1 to 12 of 12
    Registered User slowrider's Avatar
    Jun 2003
    georgia
    The oil pressure gauge in my truck is bouncing around and acting stupid. I have checked the oil level and it is good. I have seen people advise to change the sending unit with this problem. My question is where exactly is it located on a 5.7 Vortec? I can't see into my engine bay well enough to try and locate it and I want to know how involved it is going to be before I ask my brother to help me install it. Thanks to anyone who can tell me where it is located.
    i hate rust!! 1ugly88's Avatar
    Leominster MA
    Re: Location Of Oil Pressure Sending Unit????
    on my motor it's behind the left exhaust manifold near the firewall. just put a wrench on the hex near the bottom of the unit and just unscrew it.
    Jun 2003
    georgia
    Thanks 1. I'll start by looking there. Hopefully that is were it will be on my truck.
    Supporting Member pfk's Avatar
    Jul 2006
    Sk, Canada
    Depending on the year of the truck and if 2wd or 4x4 it could be in 2 different locations. (the differences mentioned below are based on an educated guess as to which vehicles have which sensor location, the locations themselves are accurate though )
    in a 2wd, or vehicles without oil cooler lines, just up from the oil filter on the side of the block as already mentioned
    in a 4x4,or vehicles with oil cooler lines, just beside the distributor on the driver's side.
    (here's a pic I stole from Mjilnor's thread where he broke his sending unit, makes it easy to identify)
    1995 GMC K1500 Suburban, 385cc, .040" over stroker,Patriot heads ,1.6:1 roller rockers,224-236 113 lsa cam , Edelbrock Intake (performer RPM) Holley TBI Adapter, BBC TBI with vAFPR,Transgo Shift Kit, Dynomax cat back with Edelbrock ceramic TES Headers. Paxton SN93 s/c, electric fans 4.10 posi
    Feb 2007
    WA
    i have 2 oil sensors... one for the oil temp and one for the pressure. don't know which is what but one is on the rear block with the brass fitting by the dizzy.... the other is on the lower driver side of the block with a flat tip.
    It's ugly but atleast it's sort of run'n.
    '89 k2500 - sealed beam, gold/red/black, rusted
    Jun 2003
    georgia
    Thanks guys. It is a two wheel drive so it should block. sounds simple enough.
    SWBLS12B long&low's Avatar
    Aug 2001
    Wichita, Kansas
    Since it is a vortec motor it is behind the distributor like in the pic. above. G.M. stopped using the one above the filter back in 1990 and went to a switch and sending unit all in one like in the pic.
    88 Ext. cab longbed TPI 350
    99 Suburban LS Vortec 350
    90 SWB Silverado 5.3l and 4l60e 4 sale will part out
    2003 Z66 Avalanche
    Leominster MA
    i have both of those switches on mine. i thought the one by the distributor was the sending unit for the comp and the one on the block was for the gauge? i have a buddy with a 99 obs 1ton and he has the same setup i do.
    Aug 2001
    Wichita, Kansas
    Quote Originally Posted by 1ugly88
    I am assuming your buddy has a 454 and maybe they did not change them on the big blocks?
    My 99 sub with a 5.7 and the 5.7 vortec I have on the stand has the single sending unit/FPOP switch set-up. Just like in the pic.
    2003 Z66 Avalanche
    Leominster MA
    his is only a 5.7 that's kinda weird...
    Aug 2001
    Wichita, Kansas
    Makes you wonder what is going thru an engineers mind when they design something.
    2003 Z66 Avalanche
    Jul 2006
    Sk, Canada
    Quote Originally Posted by long&low
    That is exactly what I thought however when I looked it up in alldata, they had both listed
