Thread: 700R4 high rpm shift
Results 1 to 8 of 8
    St Marys Ga
    Question 700R4 high rpm shift
    I just replace the 4.3 motor in my 93 1500 also replace the 5 speed with a 700R4 the trans has a 100,000 miles on it it out of a 89 astro van
    it start out good but need to build up high RPM to shift in 2th there it go in to 2th at about 22 mph just need alot more rpm to do it
    the TV cable is right is there any thing I can do to fix this? it sifft in 3rd good most of the time :fsc:
    May 2006
    Alberta Canada
    Re: 700R4 high rpm shift
    think you need to modify your govener in the tranny...know you can buy spring and wieght packs for the r4 ....could always grab one out of the same vehicle gm truck at a wreckers and just swap it in..may get lucky...look for vehicle with same motor and gears ect
    [Stole/FOUND 13/03/08 :O)
    70 fury 3
    71 sport fury GT
    Sep 2006
    prairieville,La
    time for a rebuild
    St Marys Ga
    if I swap it out with a Turbo 350 what can I do about the speedo cable or VSS in this case
    Basterdization Specialist mousemotorman's Avatar
    Jun 2007
    Olympia, Washington
    I think (and I may be wrong) you need the ECM/PCM from the donor car. Every swap like this I have been involved with, we took the computer with the motor/trans. In this case, I would imagine the harnesses would be a direct match. Just speculating, is the donor still around ?
    No rats just mice
    96 Z-71
    83 S-10 V-8
    06 Hemi Commander
    MI/AZ
    He used an 89 700R4 not a 4L60E. The governor only controls WOT shifts and the adjustment is critical for normal driving up shifts.v The engines prior to the 4L60E have no control over the transmission. The 87 - 92 used a ECM not a PCM.
    Try getting the TVS cable adjusted correctly. Push down on the tab and pull the rear outer cable rearward as far as possible release the tab and without starting engine push throttle to the floor. It should be correctly adjusted.
    Supporting Member
    Nov 2006
    memphis, tn or thereabouts
    Quote Originally Posted by redvett01
    gatliff,
    What redvett01 said is the correct techinal procedure. Sometimes on older trucks it doesn't always work just right.
    If you're getting late shifts, after depressing the adjustment tab, move the tv cable housing forward about 1/8", or so, at a time until it shifts like you want. Vice versa, for early shifts. Forward for quicker, softer shifts, rearward for harder, later shifts.
    Hope this helps. If this doesn't work, you may have other problems.
    Good luck,
    Buddy
    73 Chevy PU, 350
    78 Corvette, orig owner, 48K miles
    87 Chevy PU, TBI, Lunati 256/262/108 Deg, Hyd flat, Custom chip
    98 Lumina, V6, commute
    03 Tahoe, wife's ride
    and the only Ford ever owned, 1965, 3000 w/6' finish mower.
    St Marys Ga
    Smile Re: 700R4 high rpm shift
    I went back and readjust the cable I had to back it off some, I did it the first time the way the book say but I didn't notice it was out to far
    it shift nice now , Thanks for the help
