Thread: Diablo Sport TM questions
Results 1 to 11 of 11
    Registered User BobbyWayne's Avatar
    Nov 2006
    Arkansas
    Diablo Sport says the following about torque management:
    Torque Management
    PLEASE NOTE: Disabling torque management will put greater stress on your drive line.
    TM Abuse Mode time limit:
    This is the time in abuse mode as a function of temperature. Turning it off in conjunction with Upshift Torque reduction and %Torque Reduction vs RPM will eliminate torque management.
    %Torque Reduction vs RPM:
    Torque reduction as a function of RPM, turning it off in conjunction with TM abuse mode time limit and upshift torque reduction will eliminate torque management.
    Upshift Torque reduction:
    Torque reduction control for each individual gear, turning it off in conjunction with TM abuse mode time limit and %Torque Reduction vs RPM will eliminate torque management. However we have noticed that the shift feel when disabling the upshift torque reduction in trucks and SUV's is reduced and therefore recommend leaving it ON for trucks and SUV's.
    I have a 2001 2500HD 6.0L. Why do they recomend leaving on Upshidt Torque Reduction? Is it merely the feel of the shifts or could I seriously damage the transmission?
    I know that if I disable TM in theory I could hurt the transmission, but is iy not tough enough to handle it?
    Got Torque?
    Mar 2006
    Oklahoma
    Re: Diablo Sport TM questions
    The truck still has alot of TM that the predator does not turn off. I have all mine set to off, and no problems. Even though I did have to rebuild transmission at 155k
    2003 GMC Sierra ext cab Z-71 5.3
    Flowmaster 40-series
    DiabloSport Predator Tune
    3.73 gears
    Nov 2006
    Arkansas
    yeah I know, I have turned all three off as well, and then just turned the first two off and didn't really notice any difference. I am just curious if any problem will really occur.
    technut
    Sep 2001
    north little rock, arkansas
    the HD trucks use the 80e transmission... TM elimination does
    make the transmission perform differently. wheather the
    transmission is up to the task is how well the transmission was
    built to begin with.
    if under 300000mi it should be fine... if more than that, thatd
    be teetering on somewhat a risk. why?
    for many miles the trans has been heated, overheated, good habits
    bad habits, whatall... anyway some abuse (maybe unbeknown to you)
    has already occured... how much? dunna know. anyway. making the
    trans shift more aggressively, shorter shift time, etc may
    accelerate the failure, because there is already fatique.
    *** the warning is a disclaimer to cover thyne buttocks. ***
    if it breaks and you used this mode.. dont ask them to pay for
    it... kindda clause
    GM put this TM into their systems to hedge their bet that when
    in force. they shouldnt see you in their warrenty line for a
    busted transmission or driveline issue. and again they were wrong.
    this may have slowed the bleeding, but they still had their
    share of warrenty transmission jobs.
    1. does TM effect the driveline?
    you bet!
    2. will it damage my driveline?
    possibly? depends on how damaged it is now...
    3. can it improve what i have now?
    yes.
    4. i installed the remove TM and now ive got a busted truck, why?
    see answer 2.... fix it (correctly) and retest
    airdeano
    ? horsepower
    ? torque
    will find out soon!
    1965 C10 5.3L (SSR) TH4L60e
    Nov 2006
    Arkansas
    I have 66,000 miles on it. Dodge, Ford etc do not have TM. I know why Chevy has TM, but are there transmissions inferior to others?
    How much TM can the Preditor really take out? From how people describe custom tunes I am under the impression that the Diablo cannot take it all, or even most out.
    technut
    Sep 2001
    Quote Originally Posted by BobbyWayne
    false.. they do also have TM.. ford is kindda the ones to start
    this crap.. late model HEMI has goobs of TM
    i cant speak for diablo.. i dont have one of their files..
    but your stock file states this:
    Abuse mode - starts @ 1400rpm
    Torque Reduction vs Torque vs RPM - from 1200rpm to 6800rpm
    you have stock 55% troque reduction
    Engine TM - maximum allowed calculated torque
    400rpm 275.97656
    800rpm 310.39062
    1200rpm 342.49999
    1600rpm 361.19140
    2000rpm 375.60546
    2400rpm 391.40624
    2800rpm 395.99609
    3200rpm 411.99218
    3600rpm 432.49999
    4000rpm 446.99218
    4400rpm 447.89062
    4800rpm 436.50390
    5200rpm 414.99999
    5600rpm 386.60156
    6000rpm 353.00781
    6400rpm 315.00000
    6800rpm 275.99609
    7200rpm 235.00000
    7600rpm 195.00000
    8000rpm 155.00000
    Traction Control spark retard - 800rpm (20 retard) 6800rpm (32 retard)
    plus the power enrichment mode is set @ 5000rpm @90% TPS this is
    kindda a holdback for performance, too.
    airdeano
    there isnt much to your file thats of TM importance in 2001
    ? horsepower
    ? torque
    will find out soon!
    Nov 2006
    Arkansas
    so you are saying that with my truck whether I turn the TM "on or off" with the diablo it will not make much if any difference?
    technut
    Sep 2001
    no, i am saying i dont know.. i dont know what they do to vary
    their TM settings.
    you might just do small increments of adjustment to adjust to your
    liking.
    airdeano
    ? horsepower
    ? torque
    will find out soon!
    Nov 2006
    Arkansas
    ok thanks. With the diablo though it is all or nothing.
    knows nothing, needs help xAustin's Avatar
    Jul 2007
    all over
    i'd leave tm on, you wont notice a sotp change unless you mod some other stuff with it. Or use a wait4me, whealty, etc tune making your diablo useless :p
    02 5.3 :fsc: silverado
    Chevy Truck Man TC2000's Avatar
    Western Pennsylvania
    Ive had all 3 of my TM parameters shut off for 2 yrs now and it hasn't messed up a thing ... I also quickened shifts by -10% and bumped the shift pressure up +7% for all shifts. If you dont beat the snot out of it constantly you shouldnt have any problems
