Thread: 4L80E Stand alone kit
Results 1 to 20 of 20
    Registered User TOTHEMAX!'s Avatar
    Sep 2006
    Montana
    hi guys im looking to put a 4l80e behind a 427 in my project truck. i heard there is a kit out there that allows me to do this without having a computer control installed? i really would like the 4 gears offered by the 4l80e but dont want to mess with all the sensors and computers.
    my other option is a th400, BUT it only has 3 gears. so i would like to have one more. thanks in advance!
    2003 Chevy SB CC Duramax Diesel
    Edge W/Attitude Monitor
    KD Boost Valve
    Afe Stage 2 Air Intake
    4" Magna Flow Turbo Back Exhaust
    Bilstein Shocks
    High Idle
    1972 Chevy 3/4 Ton Project Truck
    AMSOIL DEALER
    Woodstock Ontario Canada
    Re: 4L80E Stand alone kit
    There is a GMPP, TCI and other standalone computers that will comtrol teh electric 4l80e trans.
    there are also full manual shiftkits that will allow the use of teh 4l80e WITHOUT any computer at all. PATC offers a manual shift kit for sure.
    You have to shift this kit manually. If the selector is in 3rd gear, the trans is in 3rd gear, even at a stoplight. With the manual shiftkit, you will lose teh TCC lockup function however.
    I have seen teh TCI computers go for $350US on ebay before. These usually drive a 4l60e AND 4l80e trans.
    Compushift also makes a 4l60e/4l80e trans control computer is also in the PATC link.
    Here is some info from PATC The manual shift kit is about 1/4 way down the link. Its listed at $295
    http://www.transmissioncenter.net/4l80e.htm
    peace
    Hog
    Registered User 383 silverado's Avatar
    May 2007
    tucson az
    383 silverado 2500 , 4l80e, bassani shorties, coming soon 411 pcm swap & 4.88 gears
    Sep 2006
    Montana
    the whole manual shift thing would kinda suck so i dont think i would want to go with that option. i would really like to have the extra gear offered with the 4l80 but might just end up with a th400. seems like its going to get quite expensive to get a 4l80 up and running
    KD Boost Valve
    Bilstein Shocks
    High Idle
    AMSOIL DEALER
    May 2005
    Broken Bow, OK
    You could look into a built 700r4.
    May 2007
    tucson az
    th400 with gearvendor ?
    http://www.gearvendors.com/
    Sep 2006
    Montana
    Quote Originally Posted by 99-2door
    i inquired about it but was told there spendy to build.
    same deal with adding a gearvendors.
    KD Boost Valve
    Bilstein Shocks
    High Idle
    AMSOIL DEALER
    Intenionally blank b454rat's Avatar
    Dec 2005
    Binghamton NY
    You can also use a diesel 4l80 ECM, from 91-ish to 94, whenever they weren't electronic. I found a local one that is rebuilt, or go with a 4500....
    1999 GMC CCSB eventually get stuff done
    Sep 2006
    Montana
    what would the diesel ecm buy me? could the 4l80 still shift on its own like normal?
    KD Boost Valve
    Bilstein Shocks
    High Idle
    AMSOIL DEALER
    There was NEVER an NON electric 4l80e. Ever since they were used, since 1991 in teh trucks they were shifted electronically.
    The E of 4l80E, means electronically shifted.
    peace
    Pauly
    Dec 2005
    Binghamton NY
    I didn't mean not electonically controlled Imeant that they were either mechanically injected or it was controlled by an ECM, or turbo'd. All I know is that the early ones were like this....
    Registered User Randy_W's Avatar
    Salisbury, MD
    Yes, some diesels used a stand alone controller for the 4L80E, but they are no cheaper than any other one unless you get lucky at the salvage yard.
    RandyW
    '02 Short Bed/ Reg Cab/ LS1/SS wheels,3.73 Gears
    '96 Tahoe 2dr 4x4
    If its broke don't fix it Joe Dirt's Avatar
    May 2002
    S.C.
    The TCI Transmission Control Unit is made by FAST as well.
    1990 Chevy RCSB 1500 - LT1 swap, DJM 4/6
    1994 Caprice 9c1 - Stock, 14.326 @ 94.20 MPH
    1993 Mustang LX Coupe 5.0 - Stock, 79,000 miles
    1986 Buick Regal Limited - Stock, Olds 307
    Sep 2006
    Montana
    so if i found a 4l80 out of an early 90's diesel it would have the stand alone unit with it?
    KD Boost Valve
    Bilstein Shocks
    High Idle
    AMSOIL DEALER
    Salisbury, MD
    Some do but I don't know the details. Wish I could help more but I don't want to tell you wrong.
    RandyW
    '96 Tahoe 2dr 4x4
    Sep 2006
    Montana
    copy that. thanks for the help
    KD Boost Valve
    Bilstein Shocks
    High Idle
    AMSOIL DEALER
    May 2002
    S.C.
    From the little bit of research I did a while back on the 4L80e I read somewhere that the '91-'93 diesels had the stand alone transmission cotrol unit. If you go that route you'll most likely want to tweak that computer as well. If I remember correctly Tunercat has a definition file available for the diesel truck transmission control module.
    May 2006
    Alberta Canada
    theres lots of good 700r4s builders out there that will meet your needs...heres one
    http://www.transmissionhead.com/#Parts
    [Stole/FOUND 13/03/08 :O)
    70 fury 3
    71 sport fury GT
    Sep 2006
    Montana
    Quote Originally Posted by cancritter
    ive heard mixed results about the 700r4. some guys said their good other say their crap. anyone help me out on this one?
    KD Boost Valve
    Bilstein Shocks
    High Idle
    AMSOIL DEALER
    Sep 2006
    Montana
    someone on another site also mentioned finding a th 400 out of a cadilliac. he said the housing was stronger. any help with this?
    KD Boost Valve
    Bilstein Shocks
    High Idle
    AMSOIL DEALER
