Thread: 5.3 tapping while idling
Results 1 to 4 of 4
    Registered User DuckhunterInTN's Avatar
    Feb 2002
    Brownsville, TN
    I have a 2000 Silverado 5.3 with about 107k on it. When it is idling it has a slight tapping sound. It does not seem to be anything that is harmful, but it is kind of annoying. Does anyone know what is causing this or any way to fix it?
    It does it even after it has been running for a while so it is not the "piston slap at start up" problem. It will go away after you rev the motor but will soon reappear.
    Thanks in advance for your help.
    2004 GMC Sierra 4wd 2500HD CC LLY/Alli
    2000 Silverado extended cab Z71
    1995 Silverado extended cab Z71
    1984 Silverado K10 6.2 lwb
    1972 GMC Jimmy 4x4
    Registered User ruger4d4's Avatar
    Aug 2007
    leesburg,georgia
    Re: 5.3 tapping while idling
    do you think it may be the fuel injectors?
    Diesel Nut justy's Avatar
    Minnesota
    Could be carbon build up. If you like you could try running some gm top end cleaner through it. Available at any gm dealership. Could be sludge in the oil passages.
    2007 3500HD NBS Duramax
    1 Newbie dc96819's Avatar
    Oct 2002
    Tijauana MX
    maybe rockers need adjustment
