Thread: TBI injectors HELP - 454 vs 350
Results 1 to 10 of 10
    Tbi-MAX
    now whats the difference in the 454 TBI injectors?
    ive heard they are smaller than the 350, but run at a higher psi... I dont want that! (smaller)
    I want it to flow more than the 350 with the same psi... granted im still raising the psi...
    just would like to know what part number, or what year vehicle or whatever i need to tell them at autozone... thanks...
    what injectors in other words is going to feed my 383 the best??
    Kiowa, KS
    Re: TBI injectors HELP - 454 vs 350
    http://www.fullsizechevy.com/forums/...t-numbers.html
    I ended up getting 46# injectors with my 454 TBI which is fine (better spray pattern) and with enough pressure will still fuel my engine ok.
    all throttle no bottle
    philadelphia
    running 68# cop injectors in a modified tbi with spacer from cfm-tech . running 12 1/2 psi on an adjustable regulator from extreme fi . feeds my .30 over 5.7 . i thought the 454 injectors were like 90# ?
    1992 K2500 w/ reworked 355 - for fun
    2003 2500HD utility - for work
    2005 Denali tahoe- for the bride
    Kiowa, KS
    Quote Originally Posted by bowtiejack
    They are either 71 or 74#, I've seen both numbers stated as being a 454 injector. The 454 SS supposedly used a 90# injector. Then again the later 454s used a 46# injector at 30 psi which is what my 454 TBI has. A smaller injector can still deliver enough fuel, it just takes more pressure. The more pressure the finer the fuel spray is and better it can burn.
    Born and Raised Chevrolet YenkoST's Avatar
    Apr 2005
    Georgia
    Well, 80 lb/hr was a 454 injector and 90 as well. So, GM #17112560 is a 80 lb/hr injector from the 91-93 454 TBI set at 12.5 psi and GM #17113080 is a 90 lb/hr injectors set at the larger pressure (23 psi) from 94-95 years.
    The 90ss used a 90 lb/hr but GM #17111784 and the 91/92/93up used a 80 lb/hr set. Both of those numbers we set at 12 psi.
    1990 Chevrolet C1500 Sport
    *The Hot Rod
    2011 Chevrolet Silverado 6.2L
    *Airaid MIT, Custom 2.5" true dual exhaust, 2/4 lowering kit, HIDs 4300k, HP Tuners
    2012 Chevrolet Tahoe 5.3L
    *Airaid CAI, HIDs 4300k, HP Tuners...soon to be lowered
    Jul 2006
    Colorado
    I use the 90 lb/hr inj's at 15 psi for my setup, only because I didn't want to change the fuel pump. Otherwise I would have kept my stock 350 inj's and just cranked up the FP after I put a new pump in.
    I've had no issues at all with the 90's. THey work great, idle is great, passed emissions w/o egr and on a rough tune.
    It took a while for me to figure out the quirks (increased offset) but they work great.
    I have the PN 17113080 inj's
    91 K1500 ECSB
    LQ4/80E/241/60/14SF/4.88/38s
    EFILive
    98 2Dr Tahoe
    L31/0411/60E/241/4.10/285s
    EFILive, NBS 10b w/discs
    Tbi-MAX
    thanks guys, alot of great post in this thread.. it is very confusing with all the different type of injectors, and the different part #s that are always changing!
    im looking for the 90 lbs for the earlier 90-93 tbi's rated at the low psi... im going to run them a good bit higher...
    Florabama
    How hard are they to swap out? If going bigger when is it to big?
    Kiowa, KS
    Quote Originally Posted by tabasco
    Take the injector pod hat off and pry the injectors out of the injector pod body. Install new orings and screens on the new injectors and install them. The most time consuming part is scraping the gasket off the pod body and hat. Unless you have done some extensive mods to the engine you really don't need bigger injectors. Most simple bolt on mods can be compensated for with a slight increase in pressure.
    Tbi-MAX
    its not hard at all, just 2 different types torx bits screws to seperate the pod itself... i normally just take off the entire tbi itself, its easier... along with a full tbi rebuild gasket set which runs about 30-35$ to assure NO leaks... cause it sucks, when you turn on the ON position and fuel sprays like a hydrant all over the place.... especially with high psi setups...
    im getting a great deal on some 90#s. but im still going to have to get on the dyno with the 350s for now at a high psi...
