Thread: dual fuel tank problem
Results 1 to 20 of 36
    livinhigh
    Mar 2006
    Jacksonville, AR
    I have an 87 swb tbi 350 with dual tanks. my left one works the right one doesn't. I can hear the left fuel pump come on. but when i switch it to the right one i hear nuthing. Is it the switch or the fuel pump. or is anything else i can check. any help would be appreciated.
    2004 Dodge Ram 1500 quad cab. yea its got the HEMI.
    1987 chevy R10. 305 TBI with TH400. Dakota digital gauges. (And yea it smokes the HEMI)
    Jul 2007
    Missouri
    Re: dual fuel tank problem
    does the truck stay running when switched? i beleive the 2 tanks use 1 fuel pump. check too see if you have clogged lines
    livinhigh
    Mar 2006
    Jacksonville, AR
    Quote Originally Posted by trickedout420
    nope it dies instantly
    Jul 2007
    Missouri
    check to see if te valve is actually moving. have someone flip the switch while your under holding it to see if its getting power. then check for plugged lines and i guess check to see if it has a pump
    Huh? jaredself's Avatar
    Jul 2004
    BFE, West Texas
    My '82 has the same problem but has mechanical fuel pump. I finally got fed up and siphoned out the gas from the right and put it in the left. For sure check the wiring, then the switch, etc.
    2007 NNBS CC Z71-Magnaflow, K&N CAI, 2.5" level, Cooper 285's
    1999 C2500 Suburban-New L31
    1974 K20 Cheyenne-350/TH350/NP203
    Sep 2005
    Finleyville, Pa
    an 87 tbi will have a fuel pump in each tank, if you hear nothing when you switch, its probably the fuel pump. I have an 87 LWB 350 tbi and i can hear both pumps running
    06 Intimidator SS
    90 454 SS
    87 Chevy 4x4- show truck with NOS
    67 lowrider- flame-throwin daily driver
    Z62 ON-ROAD 78 Chevyrado's Avatar
    Aug 2007
    Auburn, GA
    It has two fuel pumps on tbi. When mine did that, I took the switch apart and cleaned the contacts (They were corroded and filthy as hell) and put new die-electric grease in it and it worked fine ever since.
    Kenny
    1978 C-20, 350/400, 3.73, Graystone Metallic, Raceline Renegade 8 Wheels - 18x8.5, 275/70R18 BFG KO's
    Rockin' it old-school! NovaMan's Avatar
    SW Michigan
    Quote Originally Posted by Porno Joe
    I would have thought the opposite.
    Pete
    1987 V20 Silverado RCLB: 350/SM465/NP208/10-bolt/14-bolt SF
    I know enough to know that I don't know enough.
    livinhigh
    Mar 2006
    Jacksonville, AR
    thanks guys i appreciate it. i guess im gonna check the switch before i drop the tank and change the pump.
    Jul 2007
    Missouri
    well thats good i didnt know it used 2 pumps good info to know for next time. i have a fuel cell mounted in my tool box (20 gallon) and have a holley red pumping it up front. works good and the original fuel tank still works thougt about making some sort of duel tank setup for it.
    Sep 2005
    Finleyville, Pa
    i dont have my truck with me to look, but on the tbi trucks, doesn't the power to the pump go thru the valve(so that when you switch tanks the power goes to the other pump)? You might want to try cleaning the connections at the valve to if this is the case
    06 Intimidator SS
    90 454 SS
    Sep 2005
    Finleyville, Pa
    Quote Originally Posted by NovaMan
    Its just like when you turn on the ignition but dont start the truck, you can hear a fuel pump running in the tank, same thing here, if you switch to the tank and the truck dies, turn the truck completely off and then turn the key to "run" and listen for a fuel pump.
    06 Intimidator SS
    90 454 SS
    livinhigh
    Mar 2006
    Jacksonville, AR
    yep did this and heard nuthing. say i need to check the connection at the valve as well? where might the valve be?
    Sep 2005
    Finleyville, Pa
    the valve is on the frame under the pass side door
    06 Intimidator SS
    90 454 SS
    Aug 2002
    Slapoutoftown, AL
    before determining that "just because the switch is pushed and the pump isn't running its the FP" you have to first get around the switch (like jumper wire the switch...take the switch out, figure out which wires in the plug do what and jump the one that would make the truck think it's using the right fuel tank...a Haynes manual should tell you this) to make sure it's not just the switch not doing its job. if you jump it and it STILL doesn't come on, then you've narrowed it down to either the pump or the wiring...because if i'm not mistaken the valve just changes the fuel flow...the SWITCH is what activates/deactivates the FPs...i think...lol
    Sep 2005
    Finleyville, Pa
    Quote Originally Posted by FordeatinZ71
    I believe on the tbi trucks, the power for the in tank fuel pump is routed through the switch and the valve, again i'm not 100% on this.
    06 Intimidator SS
    90 454 SS
    livinhigh
    Mar 2006
    Jacksonville, AR
    yea that was my next move. i was thinkin last night just to try to hook the right fuel pump up direct. thanks again guys. i gonna try that tonight if it dont rain.
    Aug 2002
    Slapoutoftown, AL
    yea, i dunno...the only trucks i've personally owned with dual tanks were carb'd. but i have worked on an '89 V3500 crew with dual tanks that messed up...i just can't remember how it goes...a manual with a wiring diagram should clear things up...
    *edit-i looked in my Haynes manual (man those aren't good for crap nowadays are they? i remember back in the day...yea, i'm only 24 but i love old stuff so i collect old manuals/car stuff...when a Chilton's manual was almost the same as a factory service manual...nowadays the manuals SUCK) and it only shows a single tank wiring diagram so i guess you're gonna have to find another source...i'll keep looking
    *edit2-nothing found so far...i'll look again later when i have time or hopefully someone else will come up with something! good luck man!
    livinhigh
    Mar 2006
    Jacksonville, AR
    thanks. yea i brought my haynes manual with me to work and it does suck. i can't find anything about the switch on the dash nor the valve.
    Sep 2005
    Finleyville, Pa
    I have the original wiring diagram that came from GM back in 87, unfortunately its at home and im away at school
    06 Intimidator SS
    90 454 SS
