Thread: front diff diagram
Results 1 to 12 of 12
    oilfield_trash
    Nov 2006
    Olla, La.
    front diff diagram
    Allright, I know on atv's, you can go online and find every single nut and bolt on a diagram. Then buy what part you want .Well for a truck i wonder if this is possible. What i am looking for is a break down of the inside of the front diff, on my 2003 Z71.It is so easy to look at someting on paper that already broken down , then when you get it apart, you can compare what you have to the paper. Then buy what ya need. Does anyone know where i can find this??
    03 GMC Z71, 6" Rough Country,3" body,Add a leaf, 37/13.50/18 Nitto Mud Grappler,18" Helo Maxx 6 wheels,Superchips,K&N cold air,Straights,05 chevy taillights,Billet insert,bailin wire and hose clamps everywhere
    IF IT WONT MAKE IT, BREAK IT!!!!
    Wheeler
    Jun 2004
    Houghton Mi
    Re: front diff diagram
    Will this work for you?
    oilfield_trash
    Nov 2006
    Olla, La.
    yes that does help. thanks much. Hey could you post a link to that on here? Im gonna tear into one of these pretty soon. and it would help to have a place to see the names of the peices and the price. That way i can order!! Thanks again very much!!
    Wheeler
    Jun 2004
    Houghton Mi
    That is my scan from a gm book. Let me see if i can dig up what each number is.
    Edit here you go:
    (1) Front Drive Axle Inner Shaft
    (2) Front Drive Axle Inner Shaft Seal
    (3) Front Drive Axle Inner Axle Shaft Bearing
    (4) Front Drive Axle Inner Shaft Housing
    (5) Front Drive Axle Clutch Gear Thrust Washer
    (6) Front Drive Axle Clutch Gear
    (7) Front Drive Axle Inner Shaft Retaining Ring
    (8) Front Drive Axle Clutch Sleeve
    (9) Front Drive Axle Clutch Shim
    (10) Front Drive Axle Actuator
    (11) Front Drive Axle Inner Shaft Housing Bolt
    (12) Front Drive Axle Clutch Fork Shaft
    (13) Front Drive Axle Clutch Fork Outer Spring
    (14) Front Drive Axle Clutch Fork
    (15) Front Drive Axle Clutch Shaft Retaining Ring
    (16) Front Drive Axle Clutch Fork Inner Spring
    (17) Front Drive Axle Clutch Shaft Bearing
    (18) Front Drive Axle Clutch Shaft
    (19) Front Differential Carrier Bolt
    (20) Front Differential Carrier
    (21) Front Differential Carrier Half Location Pin
    (22) Front Differential Case Bearing
    (23) Front Differential Bearing Adjuster Nut
    (24) Front Differential Bearing Adjuster Nut Sleeve
    (25) Front Differential Side Bearing Cup
    (26) Differential Ring Gear Bolt
    (27) Front Differential Side Bearing
    (28) Front Differential Pinion Gear Shaft
    (29) Front Differential Case
    (30) Differential Pinion Gear Shaft Lock Bolt
    (31) Differential Side Bearing
    (32) Differential Side Bearing Cup
    (33) Front Differential Ring Gear
    (34) Front Differential Half Carrier Location Pin
    (35) Front Differential Bearing Adjuster Nut Lock
    (36) Differential Pinion Gear
    (37) Differential Pinion Gear Thrust Washer
    (38) Differential Side Gear Thrust Washer
    (39) Differential Side Gear
    (40) Differential Pinion Gear
    (41) Differential Pinion Gear Thrust Washer
    (42) Front Differential Side Gear Spacer
    (43) Front Differential Side Gear
    (44) Front Differential Side Gear Thrust Washer
    (45) Front Differential Drive Pinion Gear
    (46) Differential Drive Pinion Gear Bearing Shim
    (47) Front Differential Drive Pinion Gear Inner Bearing
    (48) Front Differential Drive Pinion Gear Inner Bearing Cup
    (49) Front Differential Drive Pinion Gear Bearing Spacer
    (50) Front Differential Carrier Bushing
    (51) Front Differential Carrier
    (52) Front Differential Bearing Adjuster Nut Lock
    (53) Bolt
    (54) Front Differential Drive Pinion Gear Yoke Nut
    (55) Front Differential Drive Pinion Gear Thrust Washer
    (56) Front Differential Drive Pinion Gear Yoke
    (57) Front Differential Drive Pinion Gear Bearing Dirt Deflector
    (58) Front Differential Drive Pinion Gear Seal
    (59) Front Differential Drive Pinion Gear Outer Bearing Cup
    (60) Front Differential Drive Pinion Gear Outer Bearing
    (61) Front Differential Carrier Bushing
    (62) Differential Bearing
    (63) Front Differential Bearing Adjuster O-Ring Seal
    (64) Front Differential Bearing Adjuster
    (65) Front Drive Axle Inner Shaft Seal
    (66) Front Drive Axle Inner Shaft Retaining Ring
    (67) Front Drive Axle Inner Shaft
    (68) Front Differential Carrier Vent
    (69) Fuel and Oil Resistant Hose
    (70) Clamp
    (71) Front Differential Carrier Vent Hose Connector
    (72) Front Differential Carrier Oil Drain Plug
    (73) Front Differential Carrier Oil Drain Plug Washer
    (74) Front Differential Carrier Oil Fill Plug
    (75) Front Differential Carrier Oil Fill Plug Washer
    Registered User silverado_nolan's Avatar
    Braska, Murrica
    I need to start on mine soon
    2001 Green Beast (Bye-Bye)
    2004 CTS-V LS7 (Bye-Bye)
    2010 Cheap Ext. Mods
    2004 Harley Davidson 1200cc
    oilfield_trash
    Nov 2006
    Olla, La.
    thanks a million!!!!
    Ice cold for best results kp1500z71's Avatar
    Sep 2005
    Owensboro, Kentucky
    This diagram is very helpful, but how would you go about ordering part of the differntial? According to the diagram I am in need of #51 which looks to me to be the passenger side of the differential or at least I think. When I put my lift on and cut the ear off of the diff I mistakenly shaved downed the wrong set of fins that help dissapate the heat from the diff. I am getting ready to re-gear from 3.73's to 4.88's and would like to fix this before doing so or should I say while I am having it done.
    6" Fabtech S/L, 3" BL, Ford Keys, 3/4ton TB's, Realift TB Relocators, Bilstien 5100 Shocks, 3/4ton CV's, 37" SSR's on 16x8 AR Chrome Victor, 4.88 Genuine G2 Gears & Eaton Posi LSD, Wait4Me Tune, K&N Air Intake, Flowmaster Exhaust.
    Wheeler
    Jun 2004
    Houghton Mi
    51 is the driver side half of the Case. If you need that then call the dealer. I don't have any part numbers just the sketch and parts list.
    Sep 2005
    Owensboro, Kentucky
    Thats right the driver side NOT the passenger side.
    Now own a 2003 Sierra Z71
    Jun 2003
    va
    Does anyone know which way the front axle drive sleeve (#8 in the picture above) goes. It is beveled on one end. That end seems to fit better against the axle tube #4. When I took out the tube, everything came flying out, so not sure which way it goes. I did put it back together with the beveled end towards the axle tube and everything seems to work fine. Just wondering if I got it right. Thanks for the help.
    Formerly 96Yukon Malathion's Avatar
    Jul 2006
    Earth
    Quote Originally Posted by chevytaHOE5674
    Edit here you go:
    (1) - (75) Front Differential Carrier Oil Fill Plug Washer
    Did you type all that? You are way too nice.
    Wheeler
    Jun 2004
    Houghton Mi
    Well i typed it long ago for somebody else, and happened to have it saved on my computer, it is pretty useful.
