Thread: What tucks on a bagged truck..OBS and NBS info in here
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 126
    6.0 swap starting.. Nickleahy23's Avatar
    Sep 2005
    Portage / Menomonie, WI
    Ok well ive seen a few people suggest it but noone has made a thread about it all..This could be made into a sticky sometime. Only post up your truck style, wheels size, tire sizes, offset and backspacing. No questions in this thread just info. Mabye throw up a picture to show how they sit compared to the bedsides/fender. Once people start postin I can compile a list in this first post for reference.Ill start it off.
    OBS Trucks
    Boss 304's 22x9.5,+16 mm offset 5.810" backspacing Chrome 5 on 5. Tires are 265/35/22. Tuck with no problems
    Eagle Alloy 026 20x8.5" +14mm with 5.2" backspacing, 6x5.5 bolt pattern, 255/35/20 Tires. Tuck with EASE
    American Racing Motto MT-100 20x8.5 4 3/4" backspacing 0mm offset 255/35/20 tire.Barely tucks, rolled front fenders.
    OEM 2007 Yukon/Sierra 20x8.5 6" backspace with 31mm offset 275/45 tire,6 lug comversion,tucks nice.
    Intro Pentia 20x8.5 5.5" BS 255/40/20
    Intro Pentia 20x10 6.25" BS 275/40/20 (Rear)
    Cruiser 357c 20x9 with +20mm offset on 255/35/20
    NBS Trucks
    22x8.5 Boyd Coddington Slayer with Nitto 420S 265/35R22 6 inches of b/s
    Rear Only
    22x10 Boyd Coddington Slyer with Nitto 555 285/35r22 with 7.5 inches of b/s
    1992 c1500 2wd, Boss 304's 22x9.5 Chrome 5 on 5 +16 mm offset 5.810" backspacing. Tires are 265/35/22. Tuck with no problems
    2000 Tahoe
    24" Boss 330, 295/35/24 Nittos , 3/5 drop
    6.0 LQ4 swap, BB 93, Magnaflow, e-fans, CAI, Built 4l65e, Yank TT3000 Stall
    18" BTL w/ Kicker 2500.1 2703 watts,Optimas,Pioneer 4100 DD, Esky Cluster
    www.subsonickustomz.com ikon's Avatar
    May 2006
    Cottage Grove, MN
    Re: What tucks on a bagged truck..OBS and NBS info in here
    Eagle Alloy 026 20x8.5" +14mm with 5.2" backspacing, 6x5.5 bolt pattern, 255/35/20 Tires. Tuck with EASE...
    .:Subsonic Kustomz Minnesota Prez:.
    Bagged & Bodydropped
    May 2006
    Tolleson, AZ
    OBS
    American Racing Motto MT-100 20x8.5 4 3/4" backspacing 0mm offset 255/35 tire
    He is a pic of it on symonds truck. BD.
    Here is a pic of how close it is on my truck
    Dec 2005
    NB Canada
    OBS Hoe
    OEM 2007 Yukon/Sierra 20x8.5 6" backspace with 31mm offset 275/45 tire,6 lug conversion,tucks nice.
    formerly jonmcc0417
    May 2005
    Lubbock, TX
    My old truck. 2002 Silverado.
    -front-
    -rear-
    both fronts and rears tucked great
    Praise The Lowered adversary's Avatar
    Aug 2007
    Saratoga Springs, Ny
    Clean truck red02chevy! Those wheels really set it off.
    Quote Originally Posted by kdyjonbama
    If guns kill people does that mean pencils misspell words
    formerly jonmcc0417
    May 2005
    Lubbock, TX
    Quote Originally Posted by adversary
    thanks a lot man.
    Jan 2005
    Alberta, Canada
    Ikons eagle 026's have the same measurments as the eagle 025's which is what I have in 5on5 bolt pattern. And the eagle 025's in 22's have to be +40mm offset and 6.785" backspacing. I run 255/35/20 tires on my 20's but i believe I can run 245/40/20. Not sure what else for tire sizes are avaliable since I havn't looked.
    RPM Graphics GoNDown's Avatar
    Apr 2004
    new orleans, la
    20" intro pentia's
    front:
    20 x 8.5 with 5.5" BS(i think)
    255/40/20
    back:
    20 x 10 with 6.25" BS
    275/40/20
    rear fenders are rolled
    BUILT, NOT BOUGHT!!!!!!
    YOU DROP YOURS......... & I'LL DROP MINE!!!!
    http://www.myspace.com/rpm_inkz
    Registered User silverado2nv's Avatar
    Jul 2006
    amarillo
    2000 silverado
    panther realm emr 280
    ............. 22x9.5 +10mm offset 5.64 bs
    hankook ventus 285/35/22
    front tucks nice
    narrowed rearend 4"
    [IMG][/IMG]
    [IMG][/IMG]
    Static Addict bignick31985's Avatar
    Sep 2004
    Charleston, SC
    Not bagged, but will still tuck great in front and rear.
    20x9 Cruiser 357c with +20mm offset on 255/35/20
    Tucks nice on static, and would tuck nice on bagged I'm sure of it.
    Decent rear shot:
    fknlow cajundragger's Avatar
    Apr 2004
    louisiana
    its a game of front spacing, NBS need 4" or less.
    2000 ECSB, 5.3, magna flow cat back, some beat in the back and a killer front stage
    Apr 2004
    louisiana
    if you have the rim and tire to measure you..
    lay the rim face up.
    Pull off the lug cover or hub cover
    lay a straight edges across the wheel/tire
    stick a tape measure thu the center of the wheel
    pull up so the tip gets caught on the wheel flange
    measure to the bottom of the straight edge.
    Or
    If you looking at a new set of wheels...
    Look at your offset of the wheel, say its +40.
    Divide the width of your tire by 2. Ex. 265/2
    subtract the offset of the rim with half the width of the tire. Ex. 132.5-40=92.5
    92.5 would be the front spacing, which is about 3.6" and this would tuck great on a NBS.
    this is all assuming that your tire is the right size for your rim. Ex 265 wide tire for rims up to 9.5
    Apr 2004
    louisiana
    using bignicks specs, he has 107.5mm of front spacing and he says it looks like it will work great. thats like 4.25".
    numatk_07
    Front spacing is the measurement from the outside edge of the wheel (the face side) to the mounting surface, which is the same as wheel width minus back spacing.
    Apr 2004
    louisiana
    Quote Originally Posted by numatk_07
    not so much for a few reasons
    tires usually hang out further than the rim, this increases front spacing
    wheel width minus backspacing will put you .5" off since the wheel measures 1" wider than advertised. backspace takes .5 of this 1" in account for, so the other .5 must be included in the front space.
    texas
    anyone got info on 18's?
    Dec 2005
    NB Canada
    Quote Originally Posted by Nickleahy23
    Man this thread started off very well now it a mess. Just thought everyone might want to read the first post again.I'll delete my post in a few days to try to keep this one clean.
    Sep 2005
    come on guys i know there are more people that are tuckin wheels out there..post them up..
    2000 Tahoe
    texas
    Quote Originally Posted by 3-UP
    people are gonna have questions. its a ****ing message board. if someone starts a new thread asking a question you get your panties in a wad. live with it.
    now, like i said before, anyone got info on 18's?
