Thread: rear main seal??
Results 1 to 6 of 6
    Keepin it Reeeeeeel $gmoney$'s Avatar
    CALIFORNIA
    rear main seal??
    I think mines leaking, Where would the leak be at though?
    I have some coming down both sides of the motor, on the starter and the oil filter (the oil filter is tight), and I belive going all to the bottom of the oil pan.
    I cant say forsure if its my rear main seal though, Do you guys think it is?
    2001 Chevy Silverado 1500, Fabtech 4" spindles on Eagle alloy 063s on 33" bfg all terrains, Limo Tint
    http://www.cardomain.com/ride/3067770
    SE Michigan
    Re: rear main seal??
    Quote Originally Posted by $gmoney$
    if it is leaking down both sides, it is not the rear main, it is either the valve cover gaskets, oil pressure sensor(good possibility) or the rear of the intake(most likely)
    2000 Silverado 6.0 4L80E 2wd
    FSC's Resident Paint Guru Jer's Avatar
    Aug 2002
    In yo kewl-aid, GA
    i thought my seal was leaking on the 88 a few years ago and it wound up being the oil presure sensor
    "In our darkest hour...we look to the sky. With a silent prayer...BELIEVE God's on our side. In the land where FREEDOM reigns...and where eagles fly."
    Aug 2007
    Internets
    Rear main will drip oil down the bellhousing and pan and back towards the transmission.
    CALIFORNIA
    Intake gaskets were replaced about a year ago. I don't THINK that would be it....however i might be wrong.
    The back of the valve covers (both sides) have some fresh oil on them too....i'm thinking it might be the valve cover gasket or the oil pressure sensor?
    If its the oil pressure sensor is that hard to check?
    Diesel Nut justy's Avatar
    Minnesota
    No you can crawl under and see the sensor. If you had a rear main seal. Those will leaky really bad. You would see it in the bellhousing of the tranmission. Also make sure it's not leaking from like your oil filter adaptor. See that sometimes. If you have a warm day. Buy some degreaser and degrease the engine and rinse it off good. Then let the engine run a bit. You maybe able to trace the leak back easier that way. If you have trouble. Could be that when you drive theres enough wind to blow the oil around.
    2007 3500HD NBS Duramax
