Thread: Code Po178
Results 1 to 5 of 5
    diehrd
    Code Po178
    Any one have any idea what this code is , I read it is a fuel compensation sensor circuit low voltage .(PO178)
    Ummm what the He## is that LOL...
    diehrd
    Re: Code Po178
    BUMPY .. BumPY .... bump
    Registered User Red Devil's Avatar
    Mar 2006
    The Stix, TN
    Re: Code Po178
    Sure it's not a fuel composition sensor? Is your truck a flex fuel 'equipped' one? Should be the sensor that tells a flex fuel vehicle what mix of fuel you are running.
    Re: Code Po178
    the sensor is next to the fuel filter,fuel lines and an electrical connector attach to it.on 4wd models Ive seen wires by the front driveshaft rubbing on the shaft.if thats not the case probably a bad sensor.about 600 bills at the dealer.
    diehrd
    Re: Code Po178
    Thanks , I think I had an issue because I had a low battery and was snow plowing , I cleared code and it never came back , so hopefully I am set
