Thread: 92 Chevy Truck 350 Tbi To 350 Carb
Results 1 to 8 of 8
    Feb 2008
    Georgia
    I have a 92 Chevy 1500 Stepside Single Cab truck (Manual stock 5 speed manual transmission). I have recently replaced the original stock engine(350) with a 330HP GM Performance engine. After having this engine installed, I now find out that I can't get the TBI, computer, and the CAM in the engine to run correctly. Every engine shop tells me that in order to get the engine to run correctly, I will have to change to a carb or replace the cam which would void my warranty. So I replaced the TBI with a holley 650 carb. I also had a fuel regulator installed because of the TBI fuel pump.
    My problem now is that whenever I shift and accelerate the throttle respone has hesitation. Anytime I accelerate, the hesitation is there and then it picks up. I've been told by several shops that the fuel pressure is fine. I have changed everthing but the fuel pump that was the original TBI fuel pump.
    NEED HELP????. Any help would be greatly appreciated.
    Tbi-MAX
    Re: 92 Chevy Truck 350 Tbi To 350 Carb
    welcome to FSC...
    dude you just got stiffed for your money, you should have come here 1st before listening to a shop and them telling you to go to carb...
    the 350HO engine can easily be made to run with TBI pcm and stuff... Im sure 91chevZ71 will chime in and help you in a few. further more if your trans is the 4l60e then its confused as hell on what to do. i think the 60e started in 93, but who knows if it had that option in 92. then again your trans cable could be all off as well..
    all you had to do to begin with was install the engine:
    then get a vortec to carb/tbi intake manifold, and/or a tbi adapter plate.. simple as can be! then you would have got a mail order or local dyno tune of the pcm. computers learn to do whatever they are programed to do... its plenty bigger and badder engines running off the pcm and tbi stuff.
    Registered User Blue71's Avatar
    Jul 2007
    Kansas
    Quote Originally Posted by bigdog2733
    Not true, it will run very well on TBI or Port Fuel.
    93 Z71, 350HO, $OD 7427 in PFI mode, LC-1 WB, Hooker ProComps, MSD, 4L60E 2500 Stall, 4:56 Gears on 33's
    Registered User getsideways's Avatar
    Feb 2005
    AZ
    yea, you got some bad info about the tbi. there isnt to many shops that tune tbi so they just say it cant be done. there are lots of people running that exact engine with tbi in trucks and camaros. putting on a carb is like going backwards. it will run better, start easier, and get better miliage with the tbi (if tuned properly). as far as the hesitation with the carb, it just might need a jet change. if its not popping thru the carb on hesitation, it could be to rich, like to much pump shot. what did you do with the ignition after you got rid of the tbi? you probably just put a regular one in? what is your timing at with the new dizzy? where is your timing coming in at. maybe you just dont have it coming in soon enough.
    95 1/2 ton short bed, 350 .02 over,world torquer s/r heads,edelbrock 3704 manifold, comp roller 210/214 (.510,.472) 114 sep, comp pro magnum roller rockers, 2" tbi, 65lbs injectors, walbro 190 pump, ceramic coated shortie headers. msd blaster coil.
    Feb 2008
    Georgia
    I still have the TBI intake for the Vortec heads and I keep all the TBI parts when it was converted.
    Do you recommend going back with the TBI setup. Are there any shop recommendations that may convert my truck back to the TBI thats in the Albany Georgia area.
    91 GMC Sierra ST gmc406's Avatar
    Jan 2008
    Canada SK
    I would go back to TBI. The best decision I made was sticking with the TBI when I built my engine. I don't regret it one bit.
    Feb 2008
    Georgia
    Aany shop recommendations that may convert my truck back to the TBI thats in the Southeast Georgia area.
    Formerly Redneck Rebel Dale Gribble's Avatar
    Lima, OH
    Subscribing to this thread... I also have a 92 stepside w/ 5 speed manual and am interested in that GMPP 350HO
    "The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
    ~ Thomas Jefferson
