Thread: HELP!!! Oil not registering on stick
Results 1 to 20 of 28
    Dec 2007
    Midwest
    Just bought this truck and this is my first oil change that I've done. It's a 2003 Chevy 4.8 4x4. I put in 6 full quarts of Mobil 1 and it doesn't register at all on the dipstick. Not sure what is up with it, all I can think of is maybe it has a bigger oilpan than others. It registered full before the change.
    Am I right that it's suppose to hold 6qts?
    ***no oil on driveway - registers 40lbs pressure - motor hasnt blown yet***
    Kansas City
    Re: HELP!!! Oil not registering on stick
    are you sure its not just really clear cause its new?
    Are you sure you put oil in it
    2006 Tahoe Z71
    Dec 2007
    Midwest
    yep, positive it's in there. I can start it up and it's all over the stick, and it's good and clean. I'll get a few more quarts tomorrow and see what fills it up. Dipstick looks stock.
    Supporting Member
    WI
    check the owners manual and see how many it says you're suppose to put in there. too much oil can be a problem when it starts foaming up.
    Lanark, Ontario
    How much did you drain out when it was reading correctly on the stick?
    mine takes 6 quarts and it registers halfway on the dipstick with mobil one.
    Matching Ninja 500r
    Feb 2002
    Tulsa
    I wouldn't put more than 6 qts in there....
    Dec 2007
    Midwest
    I'm not sure how much drained, filled the drain pan though. I will measure how much the drain pan holds in the morning. A few other things I noticed when I changed oil is that the filter I took off was larger (taller) than the filter I put on. I will get the model numbers in the morning. Also, my oil pressure is running a little higher (gets closer to 60psi on take off), probably the smaller filter.
    The owners manual on Chevy's website said 6qts. I've checked my options in the glove box and do have the 4.8L. I am curious how much oil a 5.3 and 6.0 hold.
    Dec 2007
    Kentucky
    4.8, 5.3,6.0 liter all hold 6 qts. If it's a stock 4.8, with no addons like a bigger oil pan etc. Then it takes 6 qts. As far as the oil filter goes, some 2wds take the smaller filter, and some of the 4wds take the longer one. Same filter diameter. SHould make no diffrence in the oil quanity. I wouldn't put any more oil in there. It's probably either really clean or you could have a "brain fart" and put 5 in there.
    94 K2500 350 TBI, CUSTOM INTAKE, FLOWMASTER TRUE DUALS- NO KITTIES,MSD BLASTER COIL,COMPLETE TBI MODS TUNE UP, MOST OF THE ULTIMATE TBI MODS DONE, NEW CAB CORNERS. PLAN ON DOING SOME MORE MODS SOON.
    Kiowa, KS
    Even the 8.1 only holds 7 quarts so no I wouldn't go dumping more oil in it. Somethings wrong.
    SE Michigan
    someone else with a 4.8 needs to measure their tube and stick length, so you can compare
    2000 Silverado 6.0 4L80E 2wd
    Dec 2007
    Midwest
    Quote Originally Posted by grantfire319
    nope, pretty careful with my new truck w/50k miles on it and I put (one) 5qt jug and (one) 1qt 'bottle', so noway it could only be 5qts in there. I will go compare parts (dipstick and pan) with another truck asap. everything seems to be fine with 6qts for now. The guy that had it has added a few things so no telling whats on it as it went thru two dealers before it got to me. i will have to look for aftermarket oil cooler and stuff also.
    Thanks for the info so far.
    Formerly White_Stealth Stealth HD's Avatar
    OKC/Moore, OK
    The 4.8 just takes 6 quarts like everyone else said, the higher pressure is because of the smaller filter(I noticed that on mine as well). Are you sure you are putting the dipstick in all the way? Drain the oil into something clean and measure it and make sure you put 6 quarts in before you go adding more oil into. Then you will know for sure how much you put in.
    EDIT: I'd measure mine, but it's kinda pouring outside.
    Kentucky
    Quote Originally Posted by Jeremy11
    This may sound dumb, but anyway, are you sure it was a 5qt jug? I use Pennzoil and their "jugs" are a gallon=4 qts. Just eliminating the obvious stuff.
    Pin it to win it! Rod726's Avatar
    Anchorage, ALASKA
    Quote Originally Posted by Stratosman
    I got screwed up one time thinking mobile 1 jug was a gallon haha
    SE Michigan
    Quote Originally Posted by Rod726
    I've seen both 1 gallon(4 qt) and 5 qt jugs of Mobile 1
    Homesick NBer
    Quote Originally Posted by NEUMANNZZ
    only half way, i do oil changes every day on 4.8s, 5.3s, and 6.0s, both the 4.8, and 5.3 show just a tad over with 6 when i do it, right on the full line with a 6.0. and a litre is just a tad less than a quart, .945ml is a quart.
    Registered User 79Shortbox's Avatar
    Feb 2005
    Missoula, MT
    Did you fill the oil filter with oil before you put it back on there? Like those other guys said I wouldn't put anymore oil in that thing...camslap sounds awesome!
    99 K1500 Silverado 4x4 6" RCD 315/70/17S
    97 K1500 ECSB Z71 Cepek Stage II 315/75/16s, Bulletproof Steering, 210k, leaky exhaust, 3 different colors. DD/work in progress SOLD
    78 K10 SB 12" Superjunk 39.5" TSLs SOLD
    Florida Panhandle
    Agreed, check your jugs that you put in and make sure you put the oil filter/oil plug back in too (maybe it drained out already)IDK
    Registered User Z71Truckin's Avatar
    Dec 2007
    Miami
    Wow im having the same problem with my 99 4.8l 4x4. I changed it with Mobil 1 oil & oil filter. I bought 6 1qt containers. Drained out all the oil. put oil in the new oil filter. & my change engine oil still comes on & no oil on the dipstick. its rly weird. i wantd to add more but dont think i will after readin this.
