Thread: Whats The Best Spark Plug Wires?
Results 1 to 17 of 17
    Registered User drewsky6407's Avatar
    Feb 2008
    Elizabethtown, KY
    Idk wat really the difference is besides the size.
    I usually use bosh. what do you guys recomend??
    79 C10 2wd Short Bed, My Project!!!!
    1994 probe gt, gotta get her ready
    www.myspace.com/speedydrew
    Registered User sLOWrado01's Avatar
    Feb 2007
    Justin/Denton, TX
    Re: Whats The Best Spark Plug Wires?
    i always use whatever comes stock on your vehicle - theres really no guessing to it, you and your truck already knows it works - i went 110,000 miles on my stock ACDelco's so i stick with them.
    sLOWrado
    01' Silverado RCSB - Under Construction
    07' Sierra Classic - 4in Lift, Stock
    Apr 2005
    Minnesota
    I just bought a set of Jeg's Pow'r 8mm Performance wires for my 91. Good wire and great price.
    http://www.jegs.com/p/JEGS/758101/10...ll=item7&pos=7
    Sep 2001
    Detroit
    On your 85 with a stock ignition setup, got with OEM wires
    The Bad Guy Gran Patron's Avatar
    Mar 2003
    Houston,Texas
    I just changed mine out with OEM. I went 198k on the originals.
    96'RCSSB 5.0L Cammed LS1 or 6.0 Coming Later
    03'RCSSB 5.3,3:73's,G80 SOLD!!
    Mn
    PHAT:
    Good wires, or really good? If they're about the best I can get for the money, I'll order them when I hear back...
    Apr 2005
    Minnesota
    They are going to be better than like a $30 set from your local part store. Plus I got mine in two days shipped from OH. I ran MSD super conductors on my 98 and 04, but the money in the "go fast fund" wasn't there this time. I would highly recommend these wires.
    Went 240k on stock wires before changing my plugs again and the wires literally fell apart when I pulled them off. I bought Bosch so we'll see.
    dave94K1500
    8.5mm MSD superconductors.. best EVER! for OEM i like Bosch premium wires, their plugs suck.
    I little place called Macungie, PA
    I've had no luck with MSD wires on my mostly stock truck. Both times I've installed them on my truck and within a year I was missing on a number of cylinders. Using a multimeter to ohm out the wires each time proved that a couple of wires had failed, with no visable damage to the wire. Shame on me for trying the same brand that failed twice. In the same breath I'm not sure what is the best wire. I used to buy wires from a local guy (Scott Performance Wire) but he moved and I can't seem to find his stuff any more.
    dave94K1500
    i never had a single problem with MSD on multiple vehicles. wires dont fail unless they are burnt through or old (cracked)
    I Don't Like Food Anymore GMCSierra99's Avatar
    South St. Paul, MN
    Stock OEM will be just fine if you have not done anything to the truck. I did get Tylor 10.4mm for my stock 99 sierra so I did overkill it a bit but they have worked just fine for me.
    99 Sierra 5.3L, K&N CAI, Duel Exhaust, More go fast goodies to come.
    Sep 2006
    fairborn,ohio
    I've been using Accell 9000 because of headers with good luck.
    Unregistered User RFT's Avatar
    Nov 2007
    British Columbia
    If you don't go with Delco, the best OE-type replacements I've found/used are NGK. They are an 8mm wire, with a silicone shroud, and they're bright blue lol. I've never had a problem with them, and almost all of the shops around town specifically ask for these. They aren't the cheapest wires, but they are less than a set of Delcos.
    EDIT:
    Oh yeah, and I have used Bosch, and I never will again. I get too many sets back at work because they can't even be bothered to put the right length wires in the box. I bought a set to use on a Cherokee I used to have and one of the wires was too short, and there was nowhere else that it would fit.
    04 Sierra ECSB - Cranked on 33s - 6000K HIDs
    Registered User FF477's Avatar
    Dec 2007
    Castle Rock CO
    Quote Originally Posted by dave94K1500
    I have the MSD's also, I was getting a hum thru the radio with engine rpm on my factory wires, went away with the MSD's
    07 2500HD
    bowtie88
    i think im gunna go with the jegs...the value is just unbelievable
    but what should i go with the 8 mm red hot or the 8.5 mm ultra power?
    http://www.jegs.com/c/Ignition-Elect...10691/10002/-1
    Registered User jake760's Avatar
    May 2009
    USA
    I went with carquest wires
