Thread: Vortec 350 to Vortec 454 Swap?
Results 1 to 15 of 15
    Obama/Biden 2008 sbc2008's Avatar
    Feb 2008
    San Antonio, TX
    Exclamation Vortec 350 to Vortec 454 Swap?
    How much trouble is it to swap my 97' 350 with a 96-00' Vortec 454? I heard it's drop in and no trouble no grim, but I just want opinions and help from you guys and how easy a swap to a Vortec 454 is? Will I need to change the tranny from 4L60E to a 4L80E or can a 4L60E handle a stock Vortec 454 with a little bit of programming and air intake upgrades?
    Long live the big block heavy454's Avatar
    Feb 2007
    Washington
    Re: Vortec 350 to Vortec 454 Swap?
    im no expert on these things but i would imagine a stock 4l60e wouldnt last very long up against a 454 if you were to mash the throttle very often. you might want to upgrade the front end suspension a little to help out with the extra weight. other than that i would imagine the swap might be pretty straight forward, even getting all the computers and electronics to work might not be too much of a pain
    1996 K2500. Vortec 454, Whipple supercharger, Ford Racing 42lb green tops, Walbro 255, Westers tune, headers, and now 265 BFG KM2 Mudders on GM factory 16" pyos
    Feb 2008
    San Antonio, TX
    Quote Originally Posted by heavy454
    Well the PCM for the 350 can control the 454, but it would be recommended to tune the PCM to the 454. As for the tranny, I've heard of people using the 4L60E on 454's but not the performance of it and how long they last. I plan on changing to a 4L80E or a built up 4L60E a little while after I intall the 454, I just wanted to know how a 4L60E is with a 454.
    (Sold!)'97 Chevy RCSB
    Vortec 350|Vig 2600 Stall|Vette Servo/4th Servo|TransGo HD2|Bullet Proof 4L65E|4.10s|JBA Short Tube Headers|Westers 91/93|K/N CAI|Dual Magnaflows|Audio: 12" Memphis M3 2.2 cuft Ported to 30hz
    chevy boy
    e-shore maryland
    i know the 4l60e would not last long at all from the torque of the big block. and i know the 454 vortecs have seperate injectors for each cylinder instead of the spider injection like a 350 vortec has so i would imagine as long as you have the complete 454 harness you could tune your 350 pcm for the 454. but if you cant get a 454 harness you can probably get the computer from it.
    and on a side note, what is the reason for putting in a 454? i had a 96 chevy with a 350 vortec and my buddy has a 454 vortec and my truck walks all over his.
    Feb 2008
    San Antonio, TX
    Exclamation Re: Vortec 350 to Vortec 454 Swap?
    Quote Originally Posted by loudpipes
    Well changing the intake/injectors is hell of alot easier, performance parts can really wake the 454 vortec up. BTW is your buddy's 454 vortec in a 3/4 ton or a 1/2? Cuz I'd say a 1/2 ton 350 vortec would smoke a 3/4 ton with a 454 anyday.
    I also thought about stroking my 350 vortec to a 383 vortec at one point, I've heard the Vortec 383's are niice too.
    Registered User Busted Knuckles's Avatar
    Reviving this thread, it's a swap I'm currently considering. I own both complete trucks, so I can scavenge anything I need. As long as I have the complete harness and both have a 4L80E tranny, shouldn't this be a fairly easy swap? I hate wiring and chasing problems with them, how easy or difficult is it to pull the engine/tranny wiring harness? I'm hanging onto the one from the 350 truck, it may end up in a K-5 Blazer project I'm working on.
    Woodstock Ontario Canada
    the Vortec 350 stock has 1 injector per cylinder, just like the 454 Vortec does, except that all 8 injectors are in a centra pod or are in teh center of the spider, with tubes that have poppet valves on each end. the Vortec 454 use a conventional fuel rail injector setup. You will simply need to wire each injector hot wire and ground to the 454 Vortec injector plugs.
    The 454 and 350 BOTH use the exact same PCM, just with a different calibration file in it.
    I owuld simply install the 454 in teh 350 truck, use teh 350 harness and PCM. You only need to run 2 extra wires from teh PCM to the 4l80e trans to make it work.
    Vortec 454
    290 hp
    410 lb/ft torque
    Vortec 350
    255hp
    330 lb/ft torque
    This wont be a diffuicult swap at all, esp. since you have BOTH donor trucks.
    peace
    PAuly
    Pauly, is it difficult to remove the complete engine harness? If I can, I'd like to keep the 350 unadulterated harness along with the intake, distributor, etc. for a future injected project.
    Thanks for the info!
    Shouldnt be too difficult.
    peace
    PAuly
    Aug 2007
    Forest Grove
    ive been looking into the swap aswell. i blew a head gasket in my vortec 350. now im going big block with a cam intake and exhaust. well see how tax returns go, a whipple is possible
    has spent double what his truck is worth
    Registered User Chevelle45466's Avatar
    Mahomet, Illinois
    The knock module inside the PCM is also different. if both the trucks have the 4L80E you should be good if not have a re-flash. While they are at it delete the torque management and rear 02 sensors, top speed limiter and shift points firm up. Also rear gear and tire size.
    S/C Z71
    The spider had 8 injectors therefore it does have seperate injectors for each cylinder. :aniteef: You don't need a different KM either.
    Mar 2006
    Canada
    i am currently looking at the same swap, have you done yours allready and how did turn out, did the 350's harness mostly work for the 454? what other problems did you run into?
    Arkansas
    Sweet, gonna be keeping up with this!
    Praise JESUS!!!! 98 1500 scsb lowered, cowl hood, roll pan, shaved molding, tailgate handle and antena. 305 vortec , electric fans, 411 pcm swap, hp tuners, 117 shot n20, 4l80e . Super slow
    Indiana
    I have also considered doing the same. I pull a gooseneck a lot and a little extra power would be nice. Let us know how it goes!
