Thread: 5.3L pcv valve replacement
Results 1 to 9 of 9
    Jul 2007
    IL
    Question 5.3L pcv valve replacement
    I want to change the pcv valve in my 02 5.3L Z71 and dont know where it is or how to change it. Any help would be great. Thanks
    GONE FISHIN' Trolin's Avatar
    Alaska
    Re: 5.3L pcv valve replacement
    On my 2001 I found it on the drivers side valve cover towards the firewall. Pull it out by hand and pull hose off valve and insert new one on hose and push into valve cover. It will take a few seconds and is a very easy replacement.
    2001 Z71 ecsb -Sunset Orange-
    2002 Tahoe
    Mn
    +1.
    It's way in the back in the metal tube.
    It's not the old rattle type, it's straight through (wierd)...
    Let us know...
    Jul 2007
    IL
    Thank you
    Cape Cod, MA
    If it is the hollow/straight through design then there is no reason to replace. If it is the rattle type then replace it with the updated straight through version.
    Alaska
    I just replaced mine and was sold the rattle type. Is that bad? what is this straight through design you speak of? Is it better? and why?
    2002 Tahoe
    Mn
    Mine is an '03 5.3L and maybe they changed the type of PCV Valve. I was surprised.
    Austin
    Quote Originally Posted by tpitcher View Post
    GM TSB 01-06-01-029B changed the PCV from rattle type to an orifice (small opening) type to resolve an oil consumption issue. The new GM #12572717. You could check your local supplier if they have a cross reference or interchange part available using the GM part #. As mentioned above, if orifice/small opening type is already installed, no need to replace it. If it's clogged, clean it out. Hope this helps.
    Mar 2012
    Boston MA
    I replaced one in my 02 with rattle type and my old one was stuck and didn't do anything, I don't got any open tsb's so it's not all trucks I'm assuming
    -Ziggy-
    2002 silverado 1500 extended cab short bed 5.3L
    current mods -
    Aftermarket speakers and aftermarket headunit
    Cree reverse light bulbs
    Custom flowmaster original 40 series exhaust
    Candied tails
    Blackbear Tune
    Future
    Converted cluster bulbs to leds - only turn signals to go
