Thread: How to narrow rear end....
Results 1 to 9 of 9
    Hillbilly Gangsta layindoor84's Avatar
    Apr 2005
    Port Arthur, TX
    How did you go about narrowing your rear end?
    Bought, not built
    Don't care if you don't like,Thanks if you do
    http://www.myspace.com/ronnieandalisa
    Bagged & Bodydropped
    May 2006
    Tolleson, AZ
    Re: How to narrow rear end....
    Everytime I see someone do it to theirs they usually have it done for some reason...
    EDIT*
    I think its because the axles run about 3-400 and it usually cost about 600-800 to have it done by a shop...
    Apr 2005
    Port Arthur, TX
    I know you can get the shafts directly from moser for 265 pair. I am asking about the housing.
    Bought, not built
    formerly kustomkoncepts ChopandDrop's Avatar
    Oct 2005
    San Marcos, Texas
    Txhardhittaz just got his done. I was wondering the same thing, because of all the axle mounts. The shop sectioned the axle tubes towards the ends, so everything else stayed the same. He uses a jig to keep everything square.
    alaska
    Quote Originally Posted by Marcos
    EDIT*
    I call BS that it would cost 6-8 because you can re-weld axles together.
    A local brake supplier put it on a jig, machine welded both ends. Blammo.
    - B
    1991 Chevy Silverado SBSC 4x4 - Built 305 .496 Lift Roller Cam Setup in restoration to be a DD.
    Soon to Have: PerformaBuilt 700r4, 33's, and a 3" Body.
    May 2006
    Tolleson, AZ
    Quote Originally Posted by 1BadZ71Tahoe
    - B
    I'd rather not have my axle's rewelded but each there own.
    I'd Buy That For A Dollar indiglo5997's Avatar
    Pleasanton
    I am with you, i never even knew that they would cut and re-weld them i figured loping off the end and then re-splicing the ends is SOP, but i would never want/trust re-welded axles
    shave05
    most shops will respline the axles if the axle allows it.
    it keeps cost down.
    they usually just the flange off then take off the amont you want and put the flange back on with new bearings and seals.
    im getting mine done for 500$ drop of axle and pick up. and thats with new axles cuz i cant spline mine
    shave05
    if your axle is bare with no tabs or anything. you can cut it by the pumpking and use straight edges and stands to hold the rear end and tubes. just measure a ****load and use straight edges perpindicular with the flange and measure from end to end. before you weld it up
    and do one side at a time
