Thread: V6 4.3 vortec to 5.7 engine swap?
Results 1 to 10 of 10
    ALASKA
    I need a new engine in my truck, its a 97 silverado v6 4.3 2wd. I would like to put a 5.7 in instead but im not sure how much extra work, time, and money is involved. Any suggestions? If its gonna be too much trouble im gonna go ahead and just replace the v6. Also any suggestions on where to buy a good turnkey v6 4.3 vortech?
    Obama/Biden 2008 sbc2008's Avatar
    Feb 2008
    San Antonio, TX
    Re: V6 4.3 vortec to 5.7 engine swap?
    Quote Originally Posted by paulwaul1369
    The 5.7 Vortec is a direct swap from the 4.3L, 5.0L even 7.4L. If can find any of these engines with everything with them....pcm, wiring harness, and belt driven accessories it should be simple as dropping the 5.0L, 5.7L, or 7.4L in place of your 4.3L and getting your pcm custom tuned to any of those engines your switching too. Oh and no extra work besides what I just said! Simple stuff....Drop and Go! Hope this helps you.
    (Sold!)'97 Chevy RCSB
    Vortec 350|Vig 2600 Stall|Vette Servo/4th Servo|TransGo HD2|Bullet Proof 4L65E|4.10s|JBA Short Tube Headers|Westers 91/93|K/N CAI|Dual Magnaflows|Audio: 12" Memphis M3 2.2 cuft Ported to 30hz
    ALASKA
    Sounds good, so the motor mounts will line up with the v8? Also where is some good websites to do all my shopping? So what exactly will i have to change out? Im thinkng the transmission, the flywheel, the computer, and the wiring harness... whats ur suggestion?
    Feb 2008
    San Antonio, TX
    Yes the motor mounts should line up with the v8. You wont have to change out anything except the wiring harness and computer unless you get the wiring harness and the computer from the v8 your getting. Transmission is the same in both v6 and v8 same with everything else you listed. As for websites for shopping, what type of shopping do you mean?
    ALASKA
    Shopping for a turnkey engine. Thanks for all your advice, i have a truck exact year and color as yours. Man ur truck is sweet. Im thinking black paint and an air bag system, so how much did you drop your truck front and back? Im thinking i will go with 4 in the front and 6 in the rear, a tunno cover and a new grill. i want it to be all black except for the rims which will be chrome. Thanks again, ill be putting up some pics of the truck in about 3 weeks.
    fresno
    wow would my '99 nbs be able to swap a 4.3 V6 to 7.4L so easily also? I didn't know it was that easy it makes me want to get a motor today ha ha...I have the 5-speed nv500 or something like that I think. Thanks
    Woodstock Ontario Canada
    Quote Originally Posted by mattdogg8
    You should swap to a 4.8,5.3,5.7,6.0 or 8.1(496).
    peace
    PAuly
    fresno
    Pauly do u know if it's the same swap for the 8.1 because I believe that's a big block so it doesn't seem like it'd be as easy to do.
    The bellhousing patter is teh same as the smallblocks. Depending on year, the 8.1 used the same PCM as the smallblock GEN 3 engines did, just with a different cal. file flashed into it. I can see teh motor mounts being differnt.
    Rumoured that there is a problem with teh 8.1 not fitting in the 1/2 tons frame rails, but I cant confirm nor deny this. It has something to do with teh 2500HD and 1500 frames being different.
    Its much expensive to get big power out of the 8.1 without using nitrous.
    Here is some 8.1 performance parts.
    http://raylarengine.com/index.html
    Going to a 6.0L engine with L92 heads L92/L76 intake and cam can net almost 550hp for little cash outlay(comparativley).
    peace
    Pauly
    fresno
    What all is needed to drop a 6.0L in place of a 4.3 v6 in a 1999 nbs 4x4 5-spd silverado? I am thinking of buying a car so that I can build my sivlerado up a little more without worries of downtime
