Thread: What happens when the serpentine belt breaks?
Results 1 to 18 of 18
    Princeville IL
    I'm arguing with my boss over the importance of replacing the cracked, stretched and worn serpentine belt on one of our company trucks. To help my case, I'd like to be able to tell him what happens when it breaks.
    The obvious answers: You lose your A/C, alternator and power steering. This truck is an '02 with the 4.3L with a belt-driven fan... so it would lose that too. And there's the big risk that it will tear up your radiator, hoses and other things on the way out. Is there anything else to mention?
    Black SS 97S10SS's Avatar
    Seattle, WA
    Re: What happens when the serpentine belt breaks?
    Serp belt breaks, no coolant flow. You will overheat your engine and blow head gaskets, crack blocks, any number of things. If that doesn't open his eyes over a $40 belt, nothing will :)
    Member at S10forum.com. 1997 Chevy S10 SS, lots of mods, 15.1 1/4 mile. New ride: 1991 Chevy Van 20. 5.7 V8- Bass Boat puller/ Shaggin Wagon.
    Registered User Grif's Puma's Avatar
    Dec 2007
    Blood Gulch
    i keep a spare belt tucked away in the back of the truck, never really thought about what it does on its way out. i figured gravity and centrifugal force would make it spit out the bottom
    165K , 3.73 , 15 MPG, 32 Gal, TBI Spacer, airbox!, Flowmaster. http://www.cardomain.com/id/94scrmnchkn
    USMC
    G-FORCE FinalBreath's Avatar
    Milwaukee, WI
    When my belt snapped when my tensioner went, it just threw the belt out the bottom. Didnt do any damage to anything. Maybe I got lucky tho..
    88 K1500 5.7 220K SOLD
    95 K2500 5.7 336k SOLD
    96 K2500 6.5 171K
    06 Trailblazer LTZ
    You Fartknocker!!!!! TribalVision's Avatar
    Jul 2001
    A, A
    when mine looks questionable I replace it. I keep the old belt stuffed under the seat just in case i need a spare.. Or someone else with a fsc needs one...
    Tribalvision has Risen!!!! Those who have heard it Know!!
    Click It Dammit!!!!
    GONE FISHIN' Trolin's Avatar
    Alaska
    This last summer one brok on my boat that is a 350. It was squeelin' and when it quit I noticed the volt gauge going down and temp going through the roof shut her down to find the belt in bottom of bilge. Came home on the 9.9hp yamaha.
    2001 Z71 ecsb -Sunset Orange-
    2002 Tahoe
    Wheeler
    Jun 2004
    Houghton Mi
    I broke one and it came out the bottom and flopped on the ground.
    TN
    You will lose the fan, power steering, water pump, ac, alt, power brakes on a hydro boost system.
    If it overheats, you have all of those problems, and their is the chance it can hit the radiator or coolant hoses on the way out.
    05 Cavalier
    Because I Said So... srlbotanical's Avatar
    Saranac, MI
    Mine just dropped out of the bottom as well. I drove it home 10 miles with no power steering. It was starting to get warm by the time I got home.
    • 97 Chevy 4x4 extended cab 5.7L, the Daily Driver
    • 97 Jeep TJ locked and heavily modified, the Toy
    • 99 GMC Suburban SLE, the Family Tow Pig
    • Check out my ABS Override Switch.
    TN
    Hears my question,
    If you drive something long enough to have the belt break from age, what does the rest of your truck look like?
    05 Cavalier
    Saranac, MI
    Quote Originally Posted by kcb37
    Hears my question,
    This was a truck that I owned about 3 trucks ago. It was an 86 c1500, more rust then paint.
    TN
    It was just a comment to make everyone think, not argue, and I know you didn't arlbotanical, I just wanted to add that.
    Also my origonal thought was, if you look, you will see/ or hear about quite a few cars that shouldn't be on the road. At least until they are fixed.
    If something so simple as a belt is left to break, what is getting fixed/taken care of on the truck/car in question?
    05 Cavalier
    Apr 2005
    Minnesota
    I replaced my belt and idler about two months ago. Good think I did because I think the belt wouldn't of lasted much longer.
    Wheeler
    Jun 2004
    Houghton Mi
    I broke mine because the tensioner seized up and melted the belt, no squealing or anything just poof broke. Not from a lack of regular maintenance but a freak occurrence.
    Alaska
    I just switched out both my belts and tensioners with Gatorbacks and the little squirrel noise in the morning is gone. I had 70K on factory belts and tensioners and they didn't look that bad, but it was time. That little belt for the AC was a B**CH.
    2002 Tahoe
    Dec 2004
    South Florida
    you lose everything like the others said, and when it snaps, it might just break and fall off, or it might shred, slap the hood (possibly strong enough to dent it), cut one or both radiator hoses, or get wound up around one of the pullies, usually the crank. when youve got that much torque wrapping a nylon reinforced belt around a pulley, believe that its wound tight. PITA to get off usually.
    06 Trailblazer SS AWD - Grocery getter 6000 - No times yet
    97 S-10 Stepside 6.3L 5MT - "Stock"
    02 Nissan Maxima 6MT - "Grocery Getter 5000" - Bolt ons and spray, 13.50s @ 106 (SOLD)
    ASE Master/L1
    GM Master tech
    Princeville IL
    Thanks for the posts everybody. It sounds like the belt harmlessly falling out is more common than I thought (but still not worth the risk.)
    I was able to talk my boss into replacing the belt with a $50 Gates, instead of the $20 generic one. I had to argue with him a while longer to convince him that it was INSANE to take it to a garage to have that done. After I bought the belt and replaced it right in front of him in less than 3 minutes I think he believed me. But... 10 years and 200k miles from now when that belt breaks... he'll blame it on me :/
    Thanks again!
    Pittsfield, MA
    Odds are good that nothing will be physically damaged by a belt breaking, but you will lose all acessory power and your truck will be running on battery power to the ignition only. You won't have very long to get where you need to go.
    Tell you boss he's being penny-wise adn pount-foolish. He's saving himself a $40 maintenance item thats eventually going to cost him $400 (figuring he's oging to have atruck down, at least one guy down without a truck, the actual belt and the possible cost of a tow.
