Thread: How long to replace intake manifold gaskets?
Results 1 to 19 of 19
    May 2007
    Somewhere
    I searched and found lots of information on the job, but nobody says how long a job it is. I know it's subjective, but I'm just curious about how long I should expect this job to take. I think it's in the process of letting go - I've been a bit suspicious it was on its way out for some time now, but the small puddle in the driveway after my wife left has me extremely concerned about her even being able to make it back home tonight (she's about 60-70 miles away). What I believe to be the original gaskets have 145k miles on them.
    FWIW, I'm a moderately experienced shadetree mechanic type. When I replaced the water pump on the truck, it took about 1.5 hours of actual work (I spent significant time trying unsuccessfully to come up with a substitute for the wrench to get the fan off). Most of what I've worked on has been German, so I don't have a good feel for how long different common V-8 GM jobs ought to take. Full day? Half day? Full weekend?
    '97 K1500 Suburban/5.7 Vortec, BTW.
    elkton,maryland
    Re: How long to replace intake manifold gaskets?
    Full day on the safe side but prolly 5 or 6 hours. You never know what troubles you might run into.
    97 Gmc Sierra 1500
    05 GTO upgrade.
    Apr 2004
    I agree with a full day. If you have all the tools, parts and have to make limited trips to the parts store.
    elkton,maryland
    I forgot to mention if you havent replaced the heater hose fitting that might be a good time to do that as well.
    97 Gmc Sierra 1500
    SE Michigan
    a full day if you haven't done one before
    2000 Silverado 6.0 4L80E 2wd
    Ohio
    Plan on a day (full 24 hours) just because the RTV your going to need requires 24 hrs. to fully cure. The actual job shouldn't take more than 5-6 hours - if you know where everything (including bolts) goes back. Label connectors and screw bolts back into threads so you don't lose and know exactly where they go. Will help speed things up. You can even take some digital photos as you go along. Be absolutely sure you put some o-ring lube back on the o-ring going around the fuel injector plub harness. I've seen too many guys not do this and the upper intake manifold won't seat correctly and when you start your engine the vacuum leak will sound like a 707 taking off. You'll need to take off the valve covers so plan on replacing these gaskets also. I agree with dalejrfan8 - replace hoses - with antifreeze being drained it makes it much easier. Also replace the distributor ring gasket - it cost like $.50. If you mark the distributor, when you reinstall - the small torx screw, closest to the manifold, holding the cap down - it should just be kissing the manifold - maybe like 1/16th - 1/8"th gap. This will keep your cam retard within spec.
    Jul 2006
    Colorado
    Quote Originally Posted by tjk1812
    a few hours, but you should let the RTV cure overnight, then reset base timing and go. Make sure you burp the air bubbles out of your cooling system.
    91 K1500 ECSB
    LQ4/80E/241/60/14SF/4.88/38s
    EFILive
    98 2Dr Tahoe
    L31/0411/60E/241/4.10/285s
    EFILive, NBS 10b w/discs
    Chicago
    Quote Originally Posted by dalejrfan8
    Not to mention make sure thats not the problem to begin with !!!
    USA
    what do u guys use? rtv ALONE, a gasket kit, or both?
    Jul 2006
    Colorado
    You need the kit for all the gaskets, as well as some RTV for the areas where the lower manifold mates to the block directly (oil valley). Put a healthy bead on there, and let it tack up for a few minutes before you put the lower intake back on
    91 K1500 ECSB
    EFILive
    98 2Dr Tahoe
    Ohio
    Quote Originally Posted by weider1717
    definitely both - intake gaskets along the heads then run a bead of RTV along the front and rear of block and up the heads about 1/2" to make sure nothing leaks.
    naked women and beer pimprider's Avatar
    Aug 2003
    Gainesville,Georgia
    5 to 6 hours id take pictures of all angles so theirs no question where everthing goes back i did mine in 3 1/2 hours
    SOLD
    94' 1500 4.56 gears, Rancho 6" Realift torsion bar risers, 3" body, 10"procomp leafs, 37 TOYO on 18 diesels, 350, motorvation injection, 4L80e, 1 ton t-case
    May 2007
    Somewhere
    Thanks for lots of great input. My wife is on her way home now (should be getting close). No issues, and I had her add some water to the overflow bottle on the way to be safe. I'll top it off and take a good look at everything to see where it's coming out before I rip off the manifold, but considering the mileage, I'd almost be surprised if it's not. Sounds like it's not too bad a job though.
    The best part is I was telling her about what I suspected to be the problem when she was leaving to head home, and I mentioned I couldn't find my service manual. She instantly told me what box it was in, and where in the garage the box was located.
    Homesick NBer
    Quote Originally Posted by blue70beetle
    you let you wife near your stuff in the mans area(garage). lol.
    Rest In Peace #3 intimidator4x4's Avatar
    Dec 2007
    Southeastern Indiana
    Just did my dads about 6 hours
    V INTIMIDATOR has been SOLD V
    98 RCLB Z71 all stock
    May 2007
    Somewhere
    Quote Originally Posted by kenman1717
    Only because she knows her way around. She doesn't generally get involved in doing the mechanical work, but we completely remodeled a completely trashed house we were in prior to this one, and she did a ton of the work on that.
    She made it home fine, having put a total of (I think) 5 16-oz bottles of water in when she stopped for supper, and when I checked the level, it was still just over max on the overflow, and the radiator was full. Maybe it's not as dire as I thought, but this morning she ran to the store and back (1 mile each way) before she took off for Indy, and when I took the kids to church less than an hour later, there was maybe a 6-7" dia orange puddle where she had parked. I just added probably 2.5 quarts of coolant/water within the past week.
    oklahoma
    If you can be careful with the heater hose fitting on the rear of the manifold, stock ones are junk. Mine broke(made of pot metal) and it took a while to get the remaining part out and clean the threads really good. But I would definitely replace it, only like 12 dollars at your GM dealer. Good luck.
    Dec 2007
    pa
    Before you go to all the trouble, make sure it is in fact your manifold gasket. I went through the hassle of replacing the gaskets on a 1999 5.7L vortec Suburban, and they were fine. I wasted $50 on gaskets, and $90 on a Craftsman inch-pound torque wrench, not to mention all the coolant.
    I had a leak at the water pump where the previous owner's mechanic just put RTV without a gasket.
    The quick connect heater fitting on the front of the pass. side intake manifold was leaking also. It ran down the valley between the valve cover and intake manifold and was dripping off the back of the motor, looking just like an intake manifold leak. (If you do this, I couldn't find a 1/2" NPT to 3/4" barb fitting at Lowes or Home Depot. I had to get a 1/2" NPT to 7/8" barb, a length of 7/8" heater hose, and a 7/8" to 3/4" reducer in the brass plumbing section, to step it up to the stock 3/4" heater hose where I cut it. Hope this saves you a trip to the hardware store.)
    If you get a schrader valve that would go in a regular car rim, it jambs neatly on the barb directly below the radiator cap. This is the barb that the overflow tank hose hooks to. Pressurize your system with a bike pump up to about 10 psi, and you can locate the leaks.
    If I had done this, it would have taken me 1 day to replace the quick connect fitting and water pump gasket. Instead it took 2.5 days to replace the intake manifold gasket needlessly, put it all back together, cry about it still leaking, locate the real leaks, buy the parts, and get it fixed correctly.
    Homesick NBer
    Quote Originally Posted by ryenol
    i just bought a new one today, but when i went into parts i specifically asked for one that wasn't made of that, i wanted a steel one, so our walking parts manual, thats what we call one of the parts people cause he is basically a parts catalogue, he can tell you exactly what you need without even looking it up.
    he said the one i wanted comes on early 90s cavaliers, same fitting, except its steel, they put pot metal ones in the trucks for some reason, so if your going to replace it get this one, only thing you need to check, is the size of the hole in the seal, make sure its the same as the one you take out, there are a few different ones, if you get to small a hole it could cause problems.
