Thread: Ignition timing 1994 Chev. 5.7L
Results 1 to 14 of 14
    Hyde Park
    How do you set the timing on a 1994 1500,5.7L?
    Ohio
    Re: Ignition timing 1994 Chev. 5.7L
    Bring the #1 cylinder to TDC and chalk the harmonic balancer where the metal tang is showing the degrees you want. Hook up a timing light to spark plug wire of the #1 cylinder and start the motor. If the timing is off (you'll see with the timing light flashed) rotate distributor cap clockwise or counter clockwise untill the timing flash is flashing on your chalk mark.
    SE Michigan
    you will need to disconnect the wire under the dash to set the timing, it is a tan/black wire, disconnect the inline connector near the blower motor
    this is through the glove box with the insert removed
    2000 Silverado 6.0 4L80E 2wd
    Ohio
    Talking Re: Ignition timing 1994 Chev. 5.7L
    Quote Originally Posted by dave89iroc
    Good point! Forgot about this. Glad to see someone else is always helping. Good man dave89iroc!
    Jan 2004
    Dixon IL
    that is on the 95s, 87-94 should be on the fire wall in the engine compartment, and use white out to color in the one single line on the harmonic balancer, then set timing as normal with the gun, these motors like about 6* advance, then plug the wire back together, if you forget to, a check engine will go off.
    Quote Originally Posted by vic_V8
    they moved it to the glove box in 94 see above pic.
    Matching Ninja 500r
    SE Michigan
    Quote Originally Posted by NEUMANNZZ
    yup, that pic is my 94
    Jan 2004
    Dixon IL
    thats odd, I have a '94 in my shop right now with it in the engine bay
    The Flying Dutchman neevnav's Avatar
    Jan 2007
    Stouffville, Ontario, Canada
    My 94 is in the glove box too.
    1994 K1500 350
    K&N Open Element, MSD 6A, Cobalt SS E-fans, BFG A/Ts, Cat-back duals, TSX HID retrofit
    Quote Originally Posted by Jim
    I'm out of state withno Internet. I had to fix the forum with my iPhone. Sorry guys
    Not My Pants
    Nov 2007
    MA
    Is this true? Ive always heard set it to 0*
    factory timing is zero degrees with est wire disconnected.
    Matching Ninja 500r
    Black And Orange Beast $cotty's Avatar
    Jun 2010
    Erie, Pa
    sry idk how old this post is i found it on Google but i have a 1990 and i tried to set it to zero but the engine shook violently and almost stalled would that be because of a bad fuel pump ?
    Quote Originally Posted by $cotty View Post
    could be. or worn out valve train.
    Matching Ninja 500r
    somewhere else
    Did you disconnect the tan/black wire first? If you didn't, and tried to set to zero, you're actually setting it WAY retarded past zero - anywhere from roughly 12 to 20 degrees.
    And on the subject of "where the tan/black wire is" - there's no 100% absolute answer to this, but on 88-93 it's USUALLY on the engine compartment side of the firewall, passenger side, near the black plastic electrical convenience center cover. On 94-95 it's USUALLY either behind the glovebox insert or under it, often hidden taped up in the harness bundle. Tends to be a smaller inline disconnect on 94-95 so it's harder to see. Have worked on way too many of these for this to be a debatable subject.
    Richard
