Thread: How noisy is your 383 ?
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Registered User smiles383's Avatar
    Jan 2008
    Trail ,BC ,Canada
    I built and installed a 6" rod 388 in my 1997 K2500 . It has so much piston noise that it sounds like a diesel . Iknow the forged pistons are noisier than cast or hyper but this is rediculous . It's now back at the machine shop because when I changed the oil with 800 kms on it the oil looked like metallic paint . The pistons have .0035 clearance KB forged .
    http://s291.photobucket.com/albums/ll290/smiles4571/?action=view&current=100_0886.flv[/IMG]
    Anyone have this problem with their 383 ?
    1997 K2500 NV4500 3.73 ECSB 388 Westers tune (sold)
    1991 Z28 350 Stealth Ram 3.42 5 speed
    2004 GMC Sierra 2500HD 8.1 Allison
    Curt 1992 chevy 5.7l
    tennessee
    Re: How noisy is your 383 ?
    sure its not valvetrain related like did you get the valves adjusted propley...top of the lobe then 1/2 to 3/4 turn preload.....i mean thats jsut super noisy.....
    92 5.9l full roller,fully forged,scatt crank.AFR 190cc heads,Crane 2032cam,nv3500,S2 6 Puck clutch.Hurst Short Shifter,14-bolt,auburn 4.11.Carbed
    Dec 2004
    Elkhart IN
    .0035" sounds about right. does it change when it gets warm? it is a forged piston engine, and they're going to make a little more noise when cold.
    Dec 2004
    Elkhart IN
    Quote Originally Posted by 1500chevy5.7l
    :nono: valves should be adjusted on the base circle of the cam. :read:
    Jan 2008
    Trail ,BC ,Canada
    I've readjusted the valves at least 5 times . Took off the roller rockers and put stockers back on . Changed the lifters .It does quiet down a little when warm . The machinist is trying to tell me it's the Ram Jet /HT383 cam thats making all the noise .I'm thinking of going to 5.7 rods to try quiet this thing down .
    tennessee
    thats what i eant could not think of the name ya base circle its the top back part of the lobe.....
    Tea, SouthDakota
    Quote Originally Posted by smiles383
    Sounds like they didn't clearance the pistons properly. I have a setup similar to your KB forged pistons, full roller setup and a pretty healthy cam. Aside from a lopey idle I have zero valvetrain noise, and zero piston slap(even when it was -20F up here)
    99 Tahoe
    built forged 383 4 bolt
    LTs
    built 4l60e
    EFILive
    Registered User bowtiefreak's Avatar
    Eastern PA
    I have an HT383 in mine and it is the same way
    Tooned by xZoomerZx
    1997 Tahoe 2 Dr., 4x4, GMPP HT383E, JBA Headers, Magnaflow cats, Borla Muffler, K&N FIPK, PCM4LESS custom tune.
    DC 6.5" lift, 6" procomp rear springs, 35/12.5/17 Procomp extreme ATs, Yukon 4.56 gears
    Tbi-MAX
    :nono:
    should sound like this or similar... you can hear the birds chirp... this is via the dolby 5.1 sound on my camera.
    these are 5.7 rods, and i also think im tad low on oil.
    here is the other 1
    Tbi-MAX
    your link is broke so i fixed it for you.
    now that i seen that, its sounds like the valvetrain is messed up. my builder had his technique to get everything perfect without even starting my truck. so i suggest you find another shop before they cause more damage.
    Dec 2004
    Elkhart IN
    yeah, that's valvetrain for sure. rotating assemblies have a much deeper knock.
    Jan 2008
    Trail ,BC ,Canada
    It was a brand new "take out " cam and the numbers on the back of the cam were the last 4 numbers of the GM Part # . I couldn't get a cam card anywhere so I degreed the cam with the intake centerline at 106 degrees instead of 109 . I checked all the opening and closing when I degreed the cam and it worked out to the 196/206 .431/.451 109 centerline that the Ram Jet cam is supposed to be .I'm using LT4 springs and everything seems OK
    Could this just be camshaft noise ?
    Dec 2004
    Elkhart IN
    or that you're just not adjusting the rockers properly...
    Jan 2008
    Trail ,BC ,Canada
    I've tried every different way including with the engine running . I've set them according to the factory sevice manual , by the directions in the Crane roller rockers and by setting them at tdc firing for each cylinder . Take out all the freeplay add1 full turn . I even set them at 1 full turn with the engine running .
    Bow Down Justin_Inc's Avatar
    Aug 2007
    Garson, Manitoba
    now that the lifters are pumped up you cannot add that '1 full turn' or you'll start to open valves.
    **Flat Broke Racing**
    1989 Chevy RCSB Stepside, 427 LSX block, PT106 turbo, Lenko 6spd Manual, Moser M9 rear, tube chassis, full cage, NBS front clip, rear step shavers, Zo6 seats, A/C, 1050hp street tune and daily drivable!
    Jan 2008
    Trail ,BC ,Canada
    they'll bleed back down after you adjust them
    tennessee
    jsut by chance i ahve seen it happen do you have the right lenght pushrods check to make sure your psuhrods are not touching the guide holes/plates at all look for scratch marks on the sides of them and make sure there the right lengs....cuase if you went from a falt tappet toroller cam you need shorter rods...cuase when i amde mine roller i did....but you miught have to short..by chance
    Jan 2008
    Trail ,BC ,Canada
    no the rollers for the roller rockers are running in the center of the valve and the pushrods aren't touching anywhere
    Jan 2008
    Trail ,BC ,Canada
    Well I changed the pistons and rods .I'm now using Probe FPS series pistons with 5.7 rods .These are an offset pin design piston . All I changed was the pistons and rings . Piston clearance with the KB's was .0028 , the Probes are .003 after a little touch up honing . The difference is amazing . Almost no piston noise at all . You could barely hear the forged pistons at startup , once it's warm almost nothing .
    Registered User 94Blazer383's Avatar
    Sep 2006
    Bardstown, KY
    Still sounds noisy to me, but every 383 that I have ever built has been noisy. Makes me feel a little better about how noisy the motor is in my Vette. I have a video of it running when its cold but have never posted it. Most of the videos I have made are of it running warmed up, when its fairly quiet.
    The Vette has Mahle forged pistons and 6" eagle rods, piston clearance is .002 to .0025. Mine is so loud I have considered tearing the motor down, but the way it runs is whats keeping me from doing it. :rocking:
    My truck has Speed Pro hypertectics with 5.7 rods, its nowhere near as loud as the Vette.
    4 bolt 383, World Product SR tourqer heads, Lunati Voodo 60101, 1.5 RR, Short headers into custom 2.5" Y piipe to 3" Magnaflow, all TBI mods, Bored out 2" TB, 454 80 lbs/hr injectors, built 4L60E by me, Tune by me, RCX 4" lift, Micky T Baja ATZ's on 20" wheels. Whole truck in Raptor Liner
