Thread: Painting the chevy bowtie black?
Results 1 to 20 of 27
    Registered User dags's Avatar
    CALI
    Hey I drive a black 06 Silverado and the gold bowtie on the grille is killing me..
    Does anyone know the best way to paint it black to match the stock black paint? Or do you know if its possible to buy them anywhere?
    Thanks DAGS
    Feb 2008
    calgary, alberta
    Re: Painting the chevy bowtie black?
    You can try aftermarket light rockguard. It comes in a smoke and is easy to install. You're likely to break the bowtie symbol when you take it off and doing it this way you avoid that. The material inparticular is made by ricochet in Canada.
    knows nothing, needs help xAustin's Avatar
    Jul 2007
    all over
    i need 1 blue =[
    02 5.3 :fsc: silverado
    loud pipes save lives
    Jul 2007
    Suttons Bay
    Quote Originally Posted by captainktm
    How would you break it? Ive had mine off about 3 times to repaint it from rock chips and it comes off real easy.
    07 classic ecsb 5.3
    ford keys, 3" cat back, k&n 77 series, cognito 7-9", 35"toyo's, 4.88's & trutrac, vette servo, zippy tune
    Jan 2007
    South Carolina
    Take it out. Lightly sand it. Wipe it down with some Simple Green. Prime it, paint and clear coat it with Dupli-Color. Mine lasted for years.
    Registered User Black5.3Z71's Avatar
    Benson NC
    mine came off easy too
    Sep 2012
    Oklahoma
    Red face Re: Painting the chevy bowtie black?
    Quote Originally Posted by Black5.3Z71 View Post
    i mean... i agree with you how would it break easy...? and why paint the outside of it? why not take off the gold foil on the inside and paint it from the inside so you wouldnt have to mess with taking it off and re painting it every 6 months or so.....?
    I love chrome SoSoFLY's Avatar
    Feb 2012
    Edmonton AB Canada
    I broke mine. Its a chrome emblem with a colored part inside. I glue it, sanded it, bondos it, sanded it, then painted it. Cant tell now.
    Its the rear thats 2pc, the front was 1pc
    DD -07 Illverado, 5.3, Airaid, 4/6 mcgaughys deluxe drop, HID projectors, LED in/out, colormatched ext/int, chrome U2 55 24x10, 15% over factory, rollpan, RST spoiler, lots of mods
    Jun 2012
    oklahoma
    I just did mine yesterday, I used vinyl took all of 10 min to do. Cleaned it cut the vinyl to roughly the same shape but larger, put it on the front of it and hit it with a hair dryer and moulded it around the corners. Bet of all it was free dude ha some scraps
    Registered User southcarolina13's Avatar
    Feb 2012
    south carolina
    on my silverado i use to have i popped it out and sanded it down and spray painted it with some black spray pant i had laying around and never had any problems with it.
    May 2012
    Atlanta
    Autozone or Advanced Auto or whatever local store around you should carry the colormatch paint. I know you said black but I would still get it for a perfect match. Then a coat of clear and it will look perfect. Did it to my maroon 03 NBS
    GO HAWKS! jtlichty's Avatar
    Jun 2012
    Davenport IA
    if you want it flat black check out Plasti-dip. look it up on youtube. the stuff is amazing
    Mar 2012
    Boston MA
    Plasti dip is the balls I have half my truck covered in it right now
    -Ziggy-
    2002 silverado 1500 extended cab short bed 5.3L
    current mods -
    Aftermarket speakers and aftermarket headunit
    Cree reverse light bulbs
    Custom flowmaster original 40 series exhaust
    Candied tails
    Blackbear Tune
    Future
    Converted cluster bulbs to leds - only turn signals to go
    Registered User Chriscon7's Avatar
    Jun 2011
    Colorado
    I painted my bowtie about a 1.5 to 2 years ago and it hasnt been off since. looks like I just painted it. Make sure to put a clear enamel on it if you don't want to take it off and repaint it
    06-2wd-4.8-5speed-LR4-Z85-40series-Baja 8s-TrueTrac-4.30gears-J&S Performance Tune
    Quote Originally Posted by kyviabama View Post
    Every guy thinks he has an additional 2".
    Registered User ViZ's Avatar
    Austin, TX
    To help it stick and prevent rock chips, make sure you sand to around 320grit then clean with some wax and grease remover, I would even go as far as to use an adhesion promoter like bulldog. Any wax or grease left behind will fisheye the paint or prevent it from sticking...
    Take your time and if you really want to get anal, clear it then wetsand it from 800-2000 grit to knock our the orange peal, then use a polish to shine it up
    00 Sierra Ext. Cab SB, 5.3 V8 Auto
    Oct 2012
    South FL
    I'll third the plasti-dip idea
    Oct 2012
    Minnesota
    i used vinyl since my dad has his own sticker business. i have chrome red on now, and i had flat black on before. works excellent and takes about 5 minutes, but the downside is sometimes rock chips get in there and chips the vinyl away.
    Jun 2012
    Georgia
    plasti-dip is easy and removable in case you ever wanted to take it off. there is no sanding required and it is very durable. I painted my rims with it a couple months ago and have been through numerous mud holes and car washes and it hasn't peeled at all.
    Oct 2012
    Minnesota
    Is plasti dip better than painting rims black? I would think that plasti dip would chip away if something let's say scratched it..
    Jun 2012
    Georgia
    So far, I have been through mud and rocks and pressure washed after with no peeling or scratching. Plus it won't chip like paint and if it starts to peel you can just respray it and it's good as new.
