Thread: Can Oxygen Sensors Be Cleaned??
Results 1 to 10 of 10
    Registered User slowrider's Avatar
    Jun 2003
    georgia
    This may be a stupid question but has anyone ever tried cleaning an Oxygen sensor? I am curious as to wheather or not it may be possible to clean one with an electrical parts cleaner. I have never changed one so I don't know what they look like or what causes them to fail. Thanks for any information.
    Jul 2003
    Dallas, GA
    Re: Can Oxygen Sensors Be Cleaned??
    Odds are you would damage the sensor tip. They just get old and dirty after time.
    D/D-2006 HHR 1LT 5-Speed.
    Registered User 98[GMC]z71's Avatar
    Nov 2007
    Gower, Missouri
    you use a cuttin torch and a porta power...
    lol never heard of any one cleaing them so im not sure
    "Sex is like a casino, liquor in the front, poker in the back"
    98|GMC|Z71|5.7|CAI|TrueDuals|31/10.5/15|Eagle Alloys|4 HI headlight mod w/ 8000k HID's|RockfordFosgateT300-2|PioneerHU|Kenwood:fsg:
    2006.5 LBZ Duramax|4'' MBRP|Diablo Predator|Resonater Block off|L.E.D. pod gagues |
    Jun 2003
    georgia
    Yeah I have never heard of anyone cleaning them either. I was just thinking about spraying them down with a parts cleaner and blowing them dry. I guess if they are already screwed I can't do too much damage.
    need a bigger hammer brokeagain's Avatar
    Jan 2007
    apex, nc
    I've used a torch on them before. I forget who it was, but one of my buddy's said it would work. I couldn't tell a noticeable difference, even with the live data type scanner. Never tried parts cleaner though...
    98 K1500 'Burb / 2" blocks + TB crank / 3" PA BL / bed-lined rockers and flares / 35x12.50's on 15x8 wheels /
    Jun 2003
    georgia
    If a torch works could it be a carbon buid up type issue. If so, I would think some type of cleaner might do some good. I guess it isn't going to cost anything to try to do something with them.
    Jan 2007
    apex, nc
    Quote Originally Posted by slowrider
    I agree with you. This wasn't on my truck though, it was my z28 and the sensors were cheap enough that I wasn't going to mess with the old ones too much. Still a possibility for it to work...
    Cape Cod, MA
    I have never done it but I have heard that you can remove them, heat them up with a propane torch and then dunk them in cold water. I would think a good soaking with parts, electrical, or brake cleaner would do the trick but it sounds like the torch method does a better job. O2 sensors are supposed to be self cleaning but enough time spent in the exhaust system is bound to make them fail.
    Speaker Pod Wizard KillerB's Avatar
    Spartanburg SC
    If it is carbon build up, couldn't Bake-off oven cleaner work?? Just a thought. It would be great to find a solution.
    '03 Cadillac Escalade (I know it's not a Chevy, but the price was right :aniteef: )
    Cape Cod, MA
    The most recent O2 sensor that I removed came off of a V8 equipped Grand Cherokee that was sending a code due to a faulty oxygen sensor reading before the converter. I was expecting the sensor to be caked with years of carbon buildup but it was actually very clean. I am of the opinion that O2 sensors fail due to age and heat abuse and not because of huge amounts of carbon buildup. I just replace them when the check engine light tells me to. But that oven cleaner is some seriously potent stuff that ought to clean a part like this up very well.
