Thread: TBI 350 Very Low Idle RPM
Results 1 to 20 of 24
    Formerly Redneck Rebel Dale Gribble's Avatar
    Lima, OH
    My 1992 Sierra is idling at 200 RPM yes that says two hundred. I searched and found this thread and it appears that the general consensus is that a 350 should idle between 600 and 800 RPM. What could be causing the low idle speed?
    I would also assume that this is the reason my battery isn't recharging when I let my truck idle.
    "The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
    ~ Thomas Jefferson
    Random Words repomaster's Avatar
    Nov 2007
    Cypress, TX
    Re: TBI 350 Very Low Idle RPM
    I don't have an answer for you but i'm sure curious to find out what some of the guru's have to say.
    On second thought it could be your fuel pressure.
    95 GMC C1500 Sierra SLT ECSB - L05 - 4L60E - 3.73
    Hold my beer and watch this $hit!
    Registered Woman Pleaser Kick's Avatar
    Mar 2006
    Lakefield, MN/Brookings, SD
    this happends to me every once and awhile, also very low voltage.
    2013 2500HD Silverado.
    2000 Chevrolet 1500, Ranchhand, 285's, 16x8 soft 8's, in dash DVD, 600w JL 10".
    1994 Cadillac STS, 18" MB wheels, eibach pro kit springs, billet grille.(SOLD 8/27/11)
    1992 BMW 325i (SOLD 8/24/12)
    Lima, OH
    Quote Originally Posted by KickAss89chev
    My voltage reads about 13.5 but my RPM's sit right on 200 RPM when left to idle.
    ~ Thomas Jefferson
    maybe you have a stuck iac valve or clogged passage leading to it. ensure your grounds/wires are good to and from the battery.
    Ensure battery is fully charged and load tested.
    remove iac and clean passage ways and valve. dont push in on pintle. to check operation of iac valve while removed and wires connected, ignition on/ engine off, valve should cycle.
    Also ensure your tps sensor has a smooth linear response. with engine off ignition on, voltage should read .5-5.0 vdc(closed throttle to open throttle). use scan tool hooked to diagnostic port or multimeter with needleprobe on dark blue wire going to tps sensor.
    Matching Ninja 500r
    Lima, OH
    Quote Originally Posted by NEUMANNZZ
    Ok now what is an IAC Valve and where is it located? TPS is throttle positioning sensor right?
    ~ Thomas Jefferson
    Mar 2006
    my idle will be real low, volts will read around 10-11, nothing bad, but if i turn on the ac, lights and radio the volts will go way down, and sometimes kill the truck. this doesnt happen all the time either, works normal quite a bit of the time.
    the throttle position sensor(tps) is on the passenger side of the thottle body(opposite side of the thottle lever)
    just behind it is the iac valve it screws in like a spark plug or is held in by two bolts. should be a two wire connector that you disconnect prior to removal.
    Matching Ninja 500r
    Lima, OH
    Thanks for the assistance Neumann I'll check those things out when I have some day light tommorow.
    ~ Thomas Jefferson
    Aug 2002
    Slapoutoftown, AL
    well, your alternator isn't spinning fast enough at that low idle to put out the required amount of charge. your IAC is most likely the culprit, but if not, you could always just adjust the base idle screw. that's not the correct answer, but it would fix the issue...its on the side of the TB, just look at your throttle linkage...
    More trucks than sense... BHB's Avatar
    New York
    Heard somewhere it could be EGR related
    Quote Originally Posted by Big Angry
    Hey ****face, (yes I am violating the rules and flaming you, whaah)
    Jun 2008
    Martinsville, OH
    I have the same problem. It just happened all of a sudden one day, and now idles low after warm all the time. I have changed everything under the hood except for the knock sensor and the fuel pump. I think the knock sensor will make it run like that. It is running just like the timing is retarded. Have you found anything out with yours yet?
    Lima, OH
    Quote Originally Posted by JSchu
    Nothing as of yet, I think I am just gonna leave it be for now since it doesn't really seem to affect anything other than my alternators ability to keep up at idle.
    ~ Thomas Jefferson
    Feb 2004
    texas
    I had strange problems with my '89 TBI suburban and tested and replaced multiple sensors because when i disconnected some of them, things got better. But in the end, it was my fuel pump.
    My point is that the computer can do strange things once a sensor is disconnected and you can maybe use this to your advantage to diagnose your problem.
    I'd say disconnect your sensors on top of the engine one at a time (and reconnect) and see if the idle goes up. That could rule out things like fuel pressure, etc.
    Just my opinion. I'm interested in what others think about that approach.
    Lima, OH
    Quote Originally Posted by aggiedave98
    It goes up when I disconnect the plug thats right behind the thermostat housing
    ~ Thomas Jefferson
    Aug 2002
    Slapoutoftown, AL
    i bet i know what it is. that sounds like your coolant temp sensor. you have one for your computer, one for the gauge. most likely it's telling the motor it's cold all the time so it's compensating and making your idle low...
    TIGERZ TIGERZ's Avatar
    Aug 2008
    Long Beach, CA
    any update? did you figure it out?
    Lima, OH
    Quote Originally Posted by TIGERZ
    yep I changed my oil after 22,000 miles and now it idles around 600 rpm.
    ~ Thomas Jefferson
    Feb 2004
    texas
    what made you change it at 22k??? :)
    JUGS Racing SuperStepside's Avatar
    Jun 2007
    Miami, FL
    Thats just wrong.
    1995 350 "Tool Box Injection"
    Going 4/6 with 20" Billet Specialties
