Thread: Transmission cooler lines - which is return?
Results 1 to 13 of 13
    Apr 2004
    MI
    Guys, shop overfilled tranny and I need to get some out. There are bubbles in the fluid and from researching on here, that's one symptom. The fluid level is the only thing they messed with.
    So, which transmissin cooler line is the return, top or bottom? I'd assume bottom, but have been know to be wrong before :~(( Is this the easiest way to get fluid out?
    Master Certified Tech performabuilt2's Avatar
    Jul 2007
    Pennsylvania
    Re: Transmission cooler lines - which is return?
    the bottom is out to cooler top is return from coller
    LOOK AT THE GOOGLE AD
    Apr 2004
    MI
    Quote Originally Posted by performabuilt2
    I didn't word that very clear - I was referring to the lines that enter and exit the cooler on the side of the radiator. I guess I can get under the truck and hopefully be able to see them to trace.
    Jul 2007
    Pennsylvania
    may be different from on vehicles you will need to trace them
    SE Michigan
    bottom port on trans is the outlet, top is inlet
    top port on the cooler is the INLET, bottom is outlet(design of a heat exchanger, top is always inlet)
    2000 Silverado 6.0 4L80E 2wd
    indiana
    Take the bottom line off and you will get fluid from one side or the other. I had a suction gun with a long tube that I could remove fluid from the dipstick tube. RW
    V8 S15 Jimmy member slammins15's Avatar
    Feb 2005
    canada
    If you look at my pic you will see that hot fluid comes in the bottom and out the top.
    Apr 2004
    MI
    Thanks guys - even though there are contradictions:~)
    Just so I'm sure - a proper ATF fluid level check should be done with hot fluid, vehicle idling on flat ground and after having cycled the trans through all the gears (pausing for a few seconds in each) - that right?
    It was always my understanding to be careful not to allow bubbles (aeration) in tranny fluid - that correct?
    indiana
    Correct on every point.Hydraulics dont work good with air. RW
    Apr 2004
    MI
    FWIW - inlet to the transmission cooler on my ('97 K1500)truck was at the bottom. Seems like the pump is working against gravity too that way.
    Feb 2005
    canada
    Thats why when you see ASE certified 9 times out ten you should Ask Someone Else.
    dave89iroc
    USA
    Man I'd be pissed.
    96 Z71 ECSB: F44, 14SF, 3.73, G80
    70K MILES
    87 4x4 loaded & all original, 63k original miles
    Apr 2004
    MI
    Quote Originally Posted by weider1717
    Man I'd be pissed.
    About what?!?!?
