Thread: Rattling Brake Pads!
Results 1 to 19 of 19
    Wilburton, OK
    Ive owned 2 chevys now.. an 84 and an 04,, and on both of em,, the brake pads rattle every dang bump i hit.. It didnt bother me so much on the 84,, well, cuz it was an 84,, but on an 04 it dont seem right... how do you make it STOP! its annoyin as heck ridin around with the window down and every bump ya hit its, ching ching ching ching ching... pisses me off.. and i know its the pads,, cuz i can move em with my fingers,, and it dont do it when im on the brakes.. any ideas? thanks
    Registered User GWolfe67's Avatar
    Feb 2008
    Wichita, Kansas
    Re: Rattling Brake Pads!
    Sorry no ideas, but I was about to post with the same problem on my 2004. I was wondering if was because the pads were getting worn.
    2004 Crew Cab Silverado Z-71
    Black Bear Tune
    Mar 2006
    Oklahoma City
    I have had the same problem. Since it is always the outside pads that rattle, I use CRC Disc Brake Quiet. You just put a dab on the back side if the pad that sets against the brake caliper.
    Never Finished probuilder1's Avatar
    Jul 2007
    Tenessee
    I also have an 04 that has the rattling pads. Its so damn annoying.
    2004 Z71 5.3, ProComp, Blackbear, Pacesetter, Trutrac, Yank, Transgo
    Wilburton, OK
    any ideas anyone?
    I finally have a 4wd NorTex4x4's Avatar
    Nov 2006
    TEXAS
    turn the rotors and buy new pads
    2009 Chevy Silvy
    4.8 rockin' 2WD!
    Airaid goodies, JBA shorties, CCM spacer
    nothin to brag about
    gave up a big 4x4 to hopefully build a prerunner
    Wilburton, OK
    its done it as long as i can remember, even new. The rotors and Baer eradispeed rotors. New pads and the rebuild kit didnt do anything on the 84, Pads rattle on my r1 too. anyone ever put some silicone or something on em to keep em from moving ?
    Registered User chevybowtie's Avatar
    trout
    most of the time its your front disc pad springs are bad.
    98 z71, 6" RCX lift, 3" body lift, 37/13.50/18 mud grapplers, Helo maxx 6's, superchip programmer, throttlebody spacer, K&N cold air intake. straights
    When the blacktop ends, the fun begins.
    2500 HD Rickl1968's Avatar
    Aug 2008
    Thunder Bay, Ontario, Canada
    Angry Re: Rattling Brake Pads!
    Has any one found a fix?
    I have an 06 2500HD and have the same problem.
    I brought mine into the dealer to get this fixed, and they did temporarily. They installed premium brake shoes with new clips........BUT they don't last.
    Somebody has to have a fix, Please help us out or we might go MAD!
    Dec 2004
    Earth
    I would always bend the 2 tabs on each of the
    outter brake pads to reduce the amount of free play between the caliper and pads.
    May 2005
    Reno, NV
    I have never had any issues with my 02. OEM pads on Powerslot rotors. Works great and I got 67000 miles on the factory pads
    Registered User scruffiest1's Avatar
    May 2009
    tomball ,tx
    mattillac has your answer. i own a 91 c1500 and a 90 sub and unless you buy dealer pads you will need to bend the tabs a little bit. the sub did it first and drove me nuts ,they would rattle till you hit the brakes ,take off and they rattle .ride the brakes wouldn't rattle .they both are rattle free,hope that helps
    Jan 2007
    Nebraska
    yea id check the retainers/clips...they're probably missing or worn
    Aug 2008
    Hey guys, I spoke with a friend of mine that is a mechanic, after inspecting my front brakes, he noticed that the calipers were worn on the bolts. He told me the fix would consist of buying new calipers, bolts and brackets.
    Not that I don't trust him, but has anyone heard this?
    And does anyone know where can I get a good cheap set of calipers? (online)
    Thanks
    GONE FISHIN' Trolin's Avatar
    Alaska
    My 2001 does this too and has for about 2 years. It started shortly after I replaced my front rotors, calipers, and pads. I used new napa rotors, and pre-loaded napa calipers. Got about six months and now my pads rattle everytime I hit a bump unless I ride the brakes. Took it to the dealer(one of two shops on the island i live on), and they told me I needed a new nickel plated slip-yoke. The guy said it was the same sound as the clunk I hear when I go from reverse to drive at a stop. I told him not to get me started because that was a whole different rattle that I'm use to hearing.
    Long story short I have learned to live with it. After the dealer trip I used some high temp insta-gasket to adhere the pads to the calipers but it didn't last. If anyone has a fix let me know. I replaced the rear brake backing plates cause they rotted away and now there seems to be noise in the rear too. ughhh.
    2001 Z71 ecsb -Sunset Orange-
    2002 Tahoe
    I Hate You All, Equally.
    Hell, Frozen Over.
    Replace the slide bolts and install anti-rattle shims or kits. It should fill up that extra little space that causes this noise.
    IM MIKE D foreman00081's Avatar
    Rochester, NY
    i helped a guy fix this problem but it was on a pathfinder. turned out he was missing a retainer clip.
    03 GMC 2500 HD CCSB duramax, 6" full traction lift. 37/13.5/20 Toyo Open Country MT's, ATS E-Power tuner, AEM intake, Stage 3 allison
    452 RWHP/755 TQ verified on superflo dyno, 7/19/08 (ATS level 10) :fsg:
    Hell, Frozen Over.
    I've done the anti-rattle clip fix on my 98 and my dad's 2500HD. it certainly helps alot and should have been something they had from the factory LOL
    I'd also make sure your caliper mounting bolts are properly torqued as well. I had a rattle on my civic. when i checked to see what it could be it turned out i was rather stupid and didn't torque the bolts down to spec and they were allowed a little bit of play and rattle. Which meant it rattled alot, cuz it was lowered and had a very stiff yet extremely fun suspension.
    Registered User usajay38's Avatar
    Feb 2005
    tampa, fl
    i think i have the same rattle from my right rear brake. it happens when i hit a bump going slow.
