Thread: 700R4 in place of a 4l60E?
Results 1 to 7 of 7
    miss you Rachael tatoodkelt's Avatar
    Bowie, Maryland
    The 4l60 is shot in my 94 Silverado. In looking for a new one I have seen tons of 700R4's for pretty cheap. Is this even a viable option? I dont know much about the 700 in a 4x4 truck application, I've seen plenty in street cars though built pretty strong. Is it a weaker/stronger/about even trans?
    What do you guys think?
    70 Chevelle * 73 Chevelle * 87 K5 * 94 RCSS * 95 2dr Tahoe * 99 Suburban * 03 Yukon
    70 Chevelle rebuild here
    Quote Originally Posted by JWolfe75 View Post
    I'm also a pop-in-pooper......
    Bowie, Maryland
    Re: 700R4 in place of a 4l60E?
    Also would that work with the T case from a 700 or will the one matched with the 4l60 work?
    6.0 swap starting.. Nickleahy23's Avatar
    Sep 2005
    Portage / Menomonie, WI
    the 4l60 in your truck is controlled electrically..the 700 wouldnt be obviously...the 4l60 is basically a turbo 400 tranny..i would imagine it would be a little different for the tcase and the drive shaft. the 700r4 was what was in trucks pre-4l60e, so theres a chance it would bolt up fine..
    2000 Tahoe
    24" Boss 330, 295/35/24 Nittos , 3/5 drop
    6.0 LQ4 swap, BB 93, Magnaflow, e-fans, CAI, Built 4l65e, Yank TT3000 Stall
    18" BTL w/ Kicker 2500.1 2703 watts,Optimas,Pioneer 4100 DD, Esky Cluster
    Bowie, Maryland
    Quote Originally Posted by Nickleahy23
    Right. I know that it will physically bolt up to the motor. I know the 4l60 is controlled electronically, that's my main concern. I'm just wondering would I have to do something to the computer? Maybe get a computer from like a 90-92? If I got a 700 in it's place and just left off the plugs that normally go to the 4l60 will that throw codes that wont let it be driven?
    Bangor, ME
    4L60 is not a TH400. 4L60 is the electronically controlled TH700. You would better off not to attempt this swap. I would stick with a 4L60. There was something unique about them for the 93 and 94 years, maybe the PWM. Not sure. Either way, putting a TH700 in place of your 4L60 will be more hassle than you think.
    Oct 2002
    Bright, IN
    Whoa!! Too much misinformation in this thread. If you have a 4L60 in your '94, it's not electronically controlled. The 4L60 is for all practical purposes a renamed 700R4. They are interchangeable as long as the 700R4 is a post-86 model with the upgraded front spline count. Other than that, just pay attention to the obvious things for a tranny swap like the TV cable hardware and speedo calibration. The 4L60E is the electronically controlled version of the 700R4/4L60 and would not be a good idea if you're currently running a 4L60.
    PCMFORLESS.COM 87 octane tune
    14.30 @ 92.2 on motor
    13.47 @ 99.2 w/ a 50 dry shot
    '96 ImpalaSS
    stock bottom LT1
    Sep 2006
    fairborn,ohio
    Your 94 has the 4L60E and you'd be better to rebuild...
