Thread: 98 Vortec 350 stock cam with 1.6 rockers
Results 1 to 7 of 7
    Smokin 38s SuperChevy17's Avatar
    Sep 2006
    Southeast Texas
    Is there any benefit pairing 1.6 rockers with a stock vortec cam?
    95 Chevy 2wd TBI Vortec 350 5spd. *Ultimate Budget Engine Swap*
    Engine: 98 4-bolt Vortec 350|Scat Crank|LT4 Production Cam|1.6 Proform Full Roller Rockers|Edelbrock EPS Intake|454 Throttle Body|Hedman Elite 69840 LT|ZOOM Perfection Clutch|Custom Tune by TBIChips
    98 ecsb 4x4 38" TSLs
    Oct 2002
    Bright, IN
    Re: 98 Vortec 350 stock cam with 1.6 rockers
    Sure, but you'll need better valvesprings and retainers, otherwise you're piZZing in the wind.
    PCMFORLESS.COM 87 octane tune
    14.30 @ 92.2 on motor
    13.47 @ 99.2 w/ a 50 dry shot
    '96 ImpalaSS
    stock bottom LT1
    Registered User chevy7398's Avatar
    Feb 2008
    nc
    you have to drill the pushrod holes to a larger size when running a 1.6 rocker on vortec heads, you dont need to change springs and retainers if using the stock cam, springs depend on the cam, and retainers are retainers thers no real difference about .480 lift and with a stock cam and 1.6 rockers your still not close to that
    2005 2500hd duramax crew cab 4x4
    1998 ext cab z71 silverado 8in sas 35's
    1973 silverado 9in 38.5 boggers
    1985 gmc siera 4in 36 tsls
    Obama/Biden 2008 sbc2008's Avatar
    Feb 2008
    San Antonio, TX
    How do you go about drilling the pushrod holes? We are talking the pushrod holes in the heads right? I'm interested in upgrading to 1.6.
    (Sold!)'97 Chevy RCSB
    Vortec 350|Vig 2600 Stall|Vette Servo/4th Servo|TransGo HD2|Bullet Proof 4L65E|4.10s|JBA Short Tube Headers|Westers 91/93|K/N CAI|Dual Magnaflows|Audio: 12" Memphis M3 2.2 cuft Ported to 30hz
    Sep 2006
    Southeast Texas
    Maybe I should have worded that differently... What kind of performance gain would you get running a 1.6 rocker with a stock cam. I know you can pair them up, I was wondering if there would be any benifit to doing that.
    Whippled 99bluetahoe's Avatar
    Apr 2004
    Fremont, CA
    Quote Originally Posted by sbc2008
    You need to pull the heads off and drill the pushrod holes bigger. You should drill them to a 1/2 inch diameter. Also if you have the heads off, you should also swap the pressed in rocker studs for screw in ones.
    http://www.chevyhiperformance.com/te...ift/index.html
    1999 2Dr Tahoe 4x4 - 5.7L L31 Marine intake w/39lbers, Whippled@8.5psi, A2W Intercooler, Alky, Tunercat, LTs, FLT 4L60E, PI 2800, Belltech drop, MSD6A, Dual 3" x-piped, 9.5" 14bolt w/4.10s & Auburn, hotchkis, efans
    13.911@96.516 mph
    Registered User 19doug90's Avatar
    Edmonton AB
    Quote Originally Posted by SuperChevy17
    about 10 cfm of air flow is what youll get from the added lift 5-10 hp
