Thread: How to hook up two amps?
Results 1 to 7 of 7
    Jul 2008
    Ontario, Canada
    Hey guys, i'm new to car audio, and I am wanting to install 2 6.5" door speakers in my 96 swb sierra. I already have a crappy 200 watt amp and 10" sub. From what I have read and figured out, it is best to leave that the way it is and buy a new amp to power the speakers. So....my question is, what is the best way to wire the new amp up to my headset?
    Thanks
    Poor college student Exalted512's Avatar
    College Station, Texas
    Re: How to hook up two amps?
    It depends on the size of the wire and the size of the amp really.
    You can run 2 separate power wires, or, if the power wire you have now is big enough, you can use a distribution block to split the power wire to your 2 amps. You will need to run a new RCA either way.
    -Cody
    04 GMC
    system in the works:
    Pioneer DEH-940MP, RF T8002 on Peerless XLS 8" midbasses, RF T8004 on DLS Iridium 3" midrange and tweeter, RF T40001 on 2 Adire Brahma 12s, RF 360.2 processor
    Jul 2008
    Ontario, Canada
    Quote Originally Posted by Exalted512
    -Cody
    alright...I am probably just going to run 2 seperate power wires. But for the RCA, I already have one running to the head and thats all I can plug into it. So....how would I go about having 2 different ones? Is it just as simple as getting a splitter that branches the wire off 2 ways?
    Btw thanks for the advice.
    Well, in that case, some amps have inputs and outputs for RCAs. You could just run another RCA from the output side of one amp to the input side of the other.
    -Cody
    04 GMC
    Registered User Dyabolical's Avatar
    Vinita, OK
    If you only have 1 set of preouts, just look into getting a cheap Y splitter from radioshack or something. Shouldn't cost more then a few bucks.
    Or as Exalt said, daisy chain the amps. That is assuming your amps have a passthrough connection.
    Jul 2008
    Ontario, Canada
    Alright thanks a lot guys. I really appreciate it. I feel like a dumbass but but how do you take off the door panels? I had a quick look today, but I couldn't get them off without breaking something.
    Take out the 2 screws in the arm rest, pop off the panel for your door lock/window switches (if you have them). If you have a window crank, you will have to push the door panel back where the crank is until you see the silver horse shoe pin behind the crank (on the crank), push it off with a knife or something similar. (be careful, that sucker flies and is easy to lose).
    After that, take off the sail panel, start with the top and pull out, its held in by a plastic clip.
    The same plastic clip holds in the entire door panel. Start from the bottom and work your way up. The top of the door panel is lipped over the metal door frame so once the plastic clips are out, lift up.
    It will sound like your breaking everything do to the sound of the pins popping out, just be careful, but those doors are pretty damn hard to break.
    -Cody
    04 GMC
