Thread: Exteme 4x4 14 Bolt FF Front Axle
Results 1 to 12 of 12
    Do Work Son! thebigo432's Avatar
    Jan 2007
    Toledo, OH and Houghton, MI
    Did anyone watch Extreme 4x4 this week where they started to build the scrambler. They used a 14 B FF front and rear. They converted the 14 B to a front axle somehow, I missed most of it to the end. How did they do it, anyone know where the a write up on it. I cant use the search on Pirate so i cant find anything out about it.
    Easily annoyed by FNG's Tank's Avatar
    Jun 2002
    backwoods of arkansas
    Re: Exteme 4x4 14 Bolt FF Front Axle
    Case High clearance I believe is the company that builds the all of the necessary hardware for the conversion.
    Snap-On Whore LPG PWRD's Avatar
    Dec 2007
    Medina, OH
    is it worth it though?
    DD: 2001 Silverado 1500 ECSB 5.3L
    Project: '94 GMC ECSB - SAS resto project
    Jan 2007
    14 bolts are a pretty stout axle, the only thing that could be an issue would be the pinion angle.
    Bush 1sxychvy's Avatar
    Jan 2008
    Muskegon,MI
    I tivo'd it but havent watched it yet... Interested to see this...
    85 RCSB k-10= Under Construction!
    08 Subaru Wrx= Fun DD
    10 Mazda 3= Wifes
    Dec 2007
    Medina, OH
    and a D60 isn't stout?
    Jan 2004
    Dixon IL
    Quote Originally Posted by LPG PWRD
    but the 14 bolt is a 10.5 ring gear
    Registered User chevy7398's Avatar
    Feb 2008
    nc
    you can get a 60 and rebuild it cheaper than doing that to a 14 bolt but it is still a cool idea. only bad things i can think of is major loss of clearance and you would be driving with the coast side of the gears while going forward so gear strength would be somewhat less.
    2005 2500hd duramax crew cab 4x4
    1998 ext cab z71 silverado 8in sas 35's
    1973 silverado 9in 38.5 boggers
    1985 gmc siera 4in 36 tsls
    Dec 2004
    Elkhart IN
    Quote Originally Posted by thebigo432
    since they dont have Cs on them, you can weld them in any position you want. pinion angle is the easiest of issues to address when tackling a project like this.
    Jan 2007
    Yeah, i just thought it was interesting. I have no plans on doing it just wanted to know how they did it
    Jan 2007
    I know a D60 is stout, but a 14 bolt is a little stronger, but i dont know after doing all this work if it still going to be as strong. I was more curious as to how they did it and where they got all the parts to do it.
    Registered User bggrnchvy's Avatar
    Apr 2004
    Bay Area, CA
    The bonus is the 14 bolt cnetersection strength. The downside is the lack of clearance unless you turn down the ring OD and shave it pretty heavily.
    Once you go to Longs in a 60 the ring and pinion become the weak link. It would get annoying breaking 60 pinions more than once. A 70 centersection would be more fitting IMO though, a 14FF housing up front just looks wrong
    There's nothing weaker about building a hybrid axle than a stock unit, aside form the inherent strength of the parts your using. It's not like the factory doesn't press fit and weld the inner C's to a turned tube. The biggest issue is the cut splines in the custom inner shafts instead of the rolled style that require a much more expensive tool than a special fly cutter and a small scale manual or CNC mill.
    1997 K1500 ECSB LQ9/80e/241/D60f/C14FF
    2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
