Thread: how do i set timing on a 1997 k1500?
Results 1 to 5 of 5
    Jan 2008
    Canton, MA
    i recently rebuilt my friends 1997 chevy k1500 5.7l. when the engine went back together we learned ignition timing could only be set at the dealer so we just did a couple of trial and error runs while turning the dist. truck now has some slight driveability issues and needs the base timing set properly for a proper diag. does anybody know of any other alternatives other than bringing to truck to the dealer?
    Minnesota
    Re: how do i set timing on a 1997 k1500?
    Quote Originally Posted by Neil814
    The cam retard can be set with many scanners besides the dealer. Do you know anyone with a scanner ?? Most auto shops will have a scanner to set it. The cam retard needs to be set at 0 degrees + or - 2 degrees.
    Jan 2008
    Canton, MA
    thanks, im sure i can find someone with a snap on scanner. i tried to set it with a gm tech 2 a while ago,but i could not find the where to set the timing on the scan tool, the tech 2 hasnt been used in at least 10 years so i dont even know if it has the right software installed on it.
    Jan 2008
    Canton, MA
    and the last time i tried to hook it up it would not communicate with the ecm. bad cable i think
    Minnesota
    Snap-On MT2500 can do it.
