Thread: So if my truck is burning/losing oil..
Results 1 to 20 of 23
    6.0 swap starting.. Nickleahy23's Avatar
    Sep 2005
    Portage / Menomonie, WI
    It just started running like **** after haulin a uhaul up to school. Theres 160k on the motor and im sure it wasnt babied its whole life..I just checked the oil and its barely on the stick.It was full when i left for school last week so whatever happened while pulling the trailer musta gotten the oil..should I run some thicker oil? Im going to run a bottle of lucus with the oil to hopefully help the problem..any other ideas? I can really smell oil when im decelerating down a hill..(no cats, true duals so I can smell everything)
    2000 Tahoe
    24" Boss 330, 295/35/24 Nittos , 3/5 drop
    6.0 LQ4 swap, BB 93, Magnaflow, e-fans, CAI, Built 4l65e, Yank TT3000 Stall
    18" BTL w/ Kicker 2500.1 2703 watts,Optimas,Pioneer 4100 DD, Esky Cluster
    Jun 2008
    South East
    Re: So if my truck is burning/losing oil..
    Is the motor smoking? Blue smoke would indicate oil getting in to the combustion chamber. One thing to try is misting COLD water into the intake (with the air cleaner off) using a spray bottle. The mist will steam and expand and reseat any valve seals that may be slipping. You could have anything from a bad valve seal to a bad piston ring.
    1990 GMC C1500 RCLB 5.7L
    Sep 2005
    I dont see any smoke..but I can smell it, but only when its decelerating..like going down a hill on the interstate..Im going to change the oil here in a little bit and go from there
    2000 Tahoe
    73-98 trucks for life...
    Sep 2006
    Mesa AZ
    I would guess a ring as deceleration pushes the rings oppasit direction and might be un-seating them.
    78 c10, shortbed/stepside: 5/5" drop, muncie M20, 388 stroker. Playtoy and first vehicle.
    98 gmc x-cab: 5.7L, 17"s, 5/6" drop, flowmaster,K&N, air ride helper bags, kicker sterio.
    06 Honda CBR600F4i: freakin rocket ship
    ----------Disclaimer: I can't spell-----------
    Sep 2005
    Well I know its down a cylinder now..Since i have true duals i can check the exhaust on each bank..the pass. bank sucks on my hand when i put it against the exhaust..What can i check now? I know its one of the back 2 because i can hear some clatter..Pull the plugs to start with? compression test? what else? Damn looks like that 5.3 might come sooner then i had hoped.
    2000 Tahoe
    S.E. Wi.
    Quote Originally Posted by LMarshall73
    ok tell me how it will reseal the valve seal when the seal is on the head side of the valve versus the port side? The water never touches the seal.
    S.E. Wi.
    Most likely you have sludge built up in the oil return holes in the head and that is causing the valve area to fill up with oil and then it dumps the oil past the guides and fouled a spark plug. Run engine for 20 minutes then pull both covers off quickly to check for excessive oil retention under a cover. Clean returns out if you find this to be the case and replace the fouled plugs.
    Jun 2008
    South East
    Quote Originally Posted by mudbuddy
    Don't know why it works, just that it does. At least it has for me for the past 20 years.
    Sep 2005
    i pulled the cover off..what holes are the oil return? the 2 holes..one in front and one in back? how do i clean those? coat hanger? there is a small puddle of oil in the rear lower corner..I cranked the motor and everything is working correctly as far as i can see...Im going to pull the plugs and check that
    2000 Tahoe
    Sep 2005
    2000 Tahoe
    S.E. Wi.
    yes there is a small return hole at the front and back they can be cleaned out with a piece of wire.
    Sep 2005
    Alright thats what I did..The plugs are pretty nasty looking so im going to replace them today..3 of the 4 were very white and some brown..and the #2 cylinder was very black..
    2000 Tahoe
    Keepin it Reeeeeeel $gmoney$'s Avatar
    CALIFORNIA
    No smoke when it first starts? Or do you have to crank it more than once for it to fire? My buddys TBI valve seals were shot and his truck would never fire on the first crank...always had to try 2 times and when it started a bunch of blue smoke with it.
    I think by lookin at the pic below your valve guide seals are shot to. If a plug was black.
    2001 Chevy Silverado 1500, Fabtech 4" spindles on Eagle alloy 063s on 33" bfg all terrains, Limo Tint
    http://www.cardomain.com/ride/3067770
    S.E. Wi.
    I never heard that valve seals would keep a engine from starting before.
    Sep 2005
    ok well my plugs were oil, carbon, and worn..theyve been in for 15k and i daily drove it through the winter when it was below 0 alot..im replacing them tomorrow..i cleaned the oil one when i pulled them the first time and it runs like a champ now..still the smell of oil..
    2000 Tahoe
    Aug 2008
    KENTUCKY
    So you are burning oil on deceleration. That would mean that the sudden vacuum of the throttle body closing is pulling oil somewhere. I would start with a compression check. If it comes back good then you can look further into the problem.
    Sep 2005
    good plan..I will get a compression tester before I do the plugs..would I just pull the fuel pump fuse and the coil main wires to do this?
    2000 Tahoe
    TN
    On my 83 Sierra Classic the valve guides were so bad I was rotating plugs in a small gatorade powder container with gas to clean them, with the one's currently in the engine every 1 1/2 to 2 weeks. Other then that it ran great, but once it hit that 2 weeks at most it wouldn't start cause the plugs were covered with oil.
    05 Cavalier
    Aug 2008
    KENTUCKY
    Some trucks just have guide problems for some reason. I still haven't got a good reason in my head as to why. Some are pretty low mileage also when it happens. But other engines with lots of miles have good looking guides.
    I usually disable the fuel system, pull all plugs, and disable the ignition system. Then turn the engine over roughly 5 times a cylinder. Has always worked for me.
    CALIFORNIA
    Oil in the combustion chamber = Hard starts
